Really helpful thank you. I was going to try taking it out with my wrench at different settings to see what it had been set atThey are 6 mm bolts going into aluminum so it should be around 7 ft-lbs. If you go much higher, you risk stripping the threads in the case!
There is no reliable way to measure the installed tightening torque by measuring the loosening force. Static friction vs dynamic, bolt stretch, corrosion, heat/ cool cycles, etc are some of the many variables.Really helpful thank you. I was going to try taking it out with my wrench at different settings to see what it had been set at
