- Joined
- Jun 19, 2015
- Messages
- 1,662
- Reaction score
- 661
- Points
- 113
- Location
- Surrey, BC (Canada)
It looks like the far wood block is under an oil pan bolt. That’s OK. Can’t tell if the block on the near side is putting any force on the exhaust, but if it is, I’d fire the mechanic.Here is how the mechanic elevated the front end on mine yesterday while changing the front tire
Skid plates are aftermarket items so whether your skid plate would withstand a jack attack would depend on your particular skid plate's construction.Hi guys & dolls, is it allowed to jack my 2012 NC700X under the very flat aluminum skid plate ? Bike is lowered and a central stand is not an option,
grtz Hoogy (Belgium)
I also had my NC700 lowered. But I also had an OEM center stand that I installed before I lowered my bike. So in order to still be able to use the center stand for various work on the motorcycle, I made a simple platform to raise the rear wheel....Bike is lowered and a central stand is not an option...
I bought the bike this way and the lower parts are not that necessary fot me so I will try to score a center stand and make the bike higher again. For the moment I will try, with a wooden plate between, to rise very carefully with a jack for grease the chain and check the wheel bearings. Thx for your info.Skid plates are aftermarket items so whether your skid plate would withstand a jack attack would depend on your particular skid plate's construction.
Depending on how low your NC is lowered, and what skid plate you have, an NC700S center stand might work. It is shorter than an NC700X stand.
It came like this on the bike also well used in Morroco by the preveous owner, thickness = about 3 or 4 mm but with a wooden board between this skid plate and the jack I think I can raise it. On the photo's you see also the frame of the skid plate.That looks like a homemade skid plate. It may not be very robust, the aluminum looks thin to me.
How do you jack this dang thing up? Is center stand only option? Why didn't it come with one?
I have a cheap Harbor Freight lift that goes under the swingarms. For the front, I mounted a heavy duty hook to my garage ceiling, and ratchet strap it into the air. Worked for me to remove both wheelsHow do you jack this dang thing up? Is center stand only option? Why didn't it come with one?
