Did the dreaded air filter change at 20k as well as battery change. Wasn’t bad at all. A lot easier than installing the sub harness. I only commute on the freeway and was surprised it was this dirty.
Today I changed the rear tire. Another rear tire shows cords!
I'm not a fan of these rear tires that have no tread along the center line. So I kept a close eye on my rear Conti Motion. On the last ride, I see the rubber starting to wrinkle in the middle. What annoys me about the Motion is that although I just hit the wear bar on the left, I'm not through it on the right, but there is no rubber left in the center. A little more warning would be nice.
So I mount up a half used Michelin PR4 from my tire stock. Prior to mounting, I check wheel balance. This is the only wheel out of the 5 I've checked that actually has the heaviest spot at the valve. See my thread on that subject: The red dot on the tire.
I mark it for future reference.
The Michelin PR4 has by far the softest sidewalls of any tire I've mounted. If you want to practice mounting tires, do it with the Pilot Road 4 or similar tire. When I watched the No-Mar guy at the bike show demo their tire mounting machine, it was a PR4 that he mounted and dismounted about 50 times a day. He must have chosen that for a reason.
Looks like you have a hole in that wheel bearing seal.
Installed some Grip Puppies (or Grab Ons, same thing). These are foam rubber over grips that slide on top of the OEM Honda grips. They make the grips larger and are cushioned for a more comfortable grip.
About 10 min install. Super easy using an air compressor to float air under the grip. It expands and slides right on.
JT
HEY!
I wish I knew how to do that. I'll think about it.
I rode around the neighborhood. We lived here 19 years and moved away for the last two and a half years doing a retirement experiment. It did not work out so we are "back home". Nice place to live.
Anyone passing by can stop and rest. I have a trailer in the back.
Land o lakes....north of Tampa.
Do these bags make my butt look fat?
Maybe I should just use one as a top box?
Anyway I bought some 42L Givi Monokey cases that clip right on to my existing racks.
Looks like I need a new front tire - just below the wear lines, and a new battery. Wont charge up. Guess I will be making a trip to the Cycle Gear just down the road.
My HJC MaxII arrived last evening so i had to go for a ride today...heh heh, to try it out ya know. Fits great, feels nice on. During the ride the first thing i noticed over my 15 year old one is there is a lot more wind noise then i expected. Although i still can't hear the IXIL pipe until i pop open the face shield, With the shield closed all i can hear is wind. After a couple of hours' ride, Very pleased with it. :{)
(now to install the ROX 2" handlebar risers, and the "Back Off" brake light module that also came in the mail). :{)
So I replaced the air filter and the battery over the weekend but never got around to test ride afterwards. This morning as I was pulling out for my commute noticed my check engine light flashing. I turn the engine off and start again and the same light. I start riding and bike feels normal. Then I think in my head... that damm plug on the air filter assembly!! Go back home, disassemble and yup forgot to plug it back in... at least now I know that I can take off my panels super fast. 15 min delay, not bad.
