2019 tail light interchangeability
Bskicrash1
New Berlin, New York
I am looking to purchase an aftermarket taillight to replace the stock light. However, there is no aftermarket available for my 2019. The grom has a large aftermarket to choose from, however, I’m not sure If the physical mounting studs are in the same location as the NC. I’ve compared 2019 models on a parts diagram. I know Honda uses multiple parts across models. In this case, I believe the tail light is the same physical dimension with the same mounting point, however the grom I believe has a longer harness wire. If the wire is longer I can work with that. I’ve included parts diagrams for the NC and the Grom.
Can anyone here verify if the grom taillight is plug and play?
