2021 Aprilia RS 660 [Model Overview]
The 2021 Aprilia RS 660: High technology and Stunning Looks at a Middleweight Price​
Aprilia Motorcycles says “If you want to go unnoticed, this is not the bike for you,” and as far as the 600cc sport bike segment goes, they could well be right. With its exposed aluminum frame, chunky asymmetrical swing arm and modern body work, the RS 660 stands out in Aprilia’s 2021 lineup as a middleweight champ.
The Italian-made RS 660 is packed with technology and rider aids, including the latest Aprilia Performance Ride Control (APRC) package, a six-axis IMU playing a part in traction control, wheelie control, and cornering ABS. Add to that three riding modes, engine brake control, a quick shifter, and even cruise control to make long rides a bit easier on the right wrist.
The liquid-cooled 659cc parallel twin engine puts out a claimed 100 horsepower, peaking at over 10,000 RPM; torque is a claimed 50 foot-pounds at 8,500 RPM. Twin 48mm throttle bodies feed gas and air to the cylinders, and four-piston Brembo brakes bring high-end stopping power to the whole package. The 41mm USD fork is fully adjustable, while the rear shock is adjustable for rebound and spring preload. All of this comes in a package with a wet weight of 403 pounds.
As with other Aprilia motorcycles, riders can use Aprilia’s smartphone app to manage the bike’s optional multimedia platform. Aprilia MIA as it’s known enables the rider to use voice controls to make phone calls or listen to music using handlebar controls and even use phone-based navigation, which displays on the bike’s dash. The app will also store trip and telemetry data.
Perhaps the best aspect of the RS 660 is it’s not expected to have just a limited release outside the US meant strictly to satisfy homologation requirements for FIM. It should be available just about everywhere.
The 2021 Aprilia RS 660 starts at $11,299 USD / $14,200 CAD (estimated).
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Aprilia RS 660 in one place.
2021 Aprilia RS 660
  • Price:$11,299 USD / $14,200 CAD (estimated)
    • Cornering ABS
    • Air and oil cooled 659cc parallel-twin
    • Elongated swing arm lugs
    • Double fairing eliminates exposed winglets
Main Specs​
  • Engine: 659cc parallel-twin
  • Power: 100 BHP
  • Torque: 50 ft-lbs
  • Wet Weight: 403 lbs (183 kg)
  • Seat Height: 32.3 inches (820 mm)
Competitors​
2021 Aprilia RS 660
2021 Aprilia RS 660 Specifications​
Engine659cc parallel-twin
Engine Power100 HP
Bore x Stroke
Compression Ratio
Fuel SystemAirbox with front air vent. Two 48 mm throttle bodies, Ride-by-wire management
Starter
Lubrication
Clutch
TransmissionSix gears with Aprilia Quick Shift (AQS) up and down system
Final Drive
Suspension FrontKayaba Ø 41 mm upside down fork with top out spring, Aluminium pins to fasten radial callipers. Rebound,
compression and spring pre-load adjustment. 120 mm wheel travel.
Suspension RearAsymmetrical aluminium swingarm. Single shock and top out spring with rebound and spring pre-load
adjustment. 130 mm wheel travel
Brakes Front320 mm diameter double disc. Brembo radial callipers with 4 horizontally opposed 32 mm pistons. Radial
pump and metal braided brake hose
Brakes Rear220 mm diameter disc; Brembo calliper with two 34 mm separate pistons. Pump with integrated tank and
metal braided hose
Front Wheel3.5”x17” aluminium alloy wheel. Tubeless radial tyre: 120/70 ZR 17”
Rear Wheel5.5”x17” aluminium alloy wheel. Tubeless radial tyre: 180/55 ZR 17 (alternatively 180/60 ZR17)
Fuel Tank Capacity15 litres (including 4-litre reserve)
Color
Ignition
HeadlightLED
Tail Light
Overall Length
Overall Width
Saddle Height
Wheelbase
Ground Clearance
Seat Height32.3 inches (820 mm)
Wet Weight183 Kg
Warranty
2021 Aprilia RS 660 Features​
APRC SYSTEM​
Originally developed for use in racing then fine-tuned for the road, the APRC system is an advanced electronic control solution. It is a total package designed to ensure safety on roads and improved performance on the track.
The RS 660 boasts the latest APRC (Aprilia Performance Ride Control) package of electronic controls. This advanced inertial six-axis navigation system uses internal gyroscopes and acceleration sensors to understand the engine’s status as it relates to the road in real time and provide instant adjustments to help improve performance and safety.
An evolution of a system that was designed for highest-level racing, the RS 660’s APRC package includes:
ATC: Aprilia Traction Control, adjustable traction control based on precise, high-performance operating logic.
AWC: Aprilia Wheelie Control
ACC: Aprilia Cruise Control which maintains your set speed without touching the throttle.
AQS: Aprilia Quick Shift, an electronic gear system that enables extremely fast gear shifts without closing the throttle or using the clutch. It also includes a downshift function for changing down without touching the clutch. Also available as an optional extra is a software that enables you to implement a reverse shift pattern without having to substitute any parts.
AEB: Aprilia Engine Brake, for controlling engine braking when closing the throttle down.
AEM: Aprilia Engine Map, with a range of different maps that vary engine power output and character.
ABS: with cornering functionality and 3 adjustable levels
EXCLUSIVE TRY-OUTS​
APRILIA RS 660 SHOWS EARLY PROMISE
When they got off the bike, the two journalists asked the same question: “When could I come back for another ride?”.
And you, how much do you want to get on an Aprilia RS 660?
6 REASONS YOU CAN’T HELP BUT WANT IT​
Let RS 660 look you in the eye and tell you why you can’t do without it.
There are motorcycles that want to be followed, revered and pampered, others that look you straight in the eye and tell you exactly why you just can’t do without them. As far as reasons go, you can be sure that RS knows at least 660. For now, just settle for 6.
2021 Aprilia RS 660 Photos​
2021 Aprilia RS 660
2021 Aprilia RS 660
2021 Aprilia RS 660
2021 Aprilia RS 660 Videos​
Aprilia Official Websites​
The post 2021 Aprilia RS 660 [Model Overview] appeared first on webBikeWorld.
