2021 BMW F 750 GS [Model Overview]
Unlimited and Uncompromising Versatility: The 2021 BMW F 750 GS​
The 2021 BMW F 750 GS strikes the perfect balance between rugged adventure capabilities and practical everyday rideability. It may not have the same commanding presence as its larger GS-designated stablemates, but this unassuming machine packs a powerful punch, making it one of the most impressive models in the 2021 BMW line-up.
This mid-sized adventure motorcycle uses a compact European-made 853cc twin-cylinder inline engine. The output is rated at 77 horsepower and 61 lb-ft of torque, propelling the F 750 GS to speeds of up to 118 mph. Power is delivered to the wheel via a six-speed gearbox and a chain drive.
Aside from the dominant riding position and commanding road presence, the F 750 GS also boasts some advanced technology as standard equipment. The highlights of these include BMW Motorrad ABS Pro, Dynamic Traction Control, selectable riding modes (Road, Rain), adjustable levers, LED lights, and a TFT display.
Shorter riders will be pleased to know that there are multiple seat options, including an “extra low” setting.
For 2021, the F 750 GS is available in three color options: Light White, San Marino Blue Metallic, and a special edition black and yellow design that celebrates 40 years of the GS brand designation.
The 2021 BMW F 750 GS starts at $10,995 USD / $11,310 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 BMW F 750 GS in one place.
2021 BMW F 750 GS
  • Price: $10,995 USD / $11,310 CAD
    • Extended Pro riding modes
    • Dynamic ESA Pro
    • TFT display with BMW Motorrad Connectivity
  • Engine: 853 cc water-cooled in-line two-cylinder engine
  • Power: 77 HP
  • Torque: 61 lbs-ft
  • Wet Weight: 493 lbs. (227 kg)
  • Seat Height: 32.1 in (815 mm)
2021 BMW F 750 GS
2021 BMW F 750 GS Specifications​
ENGINE
Engine853 cc, Water-cooled 4-stroke in-line two-cylinder engine
Engine Power77 Hp
Bore x Stroke84 mm x 77 mm
Compression Ratio12.7 : 1
Mixture controlElectronic fuel injection
Max Torque61 lb-ft at 6,000 rpm
DRIVETRAIN
ClutchMulti-disc wet clutch (anti hopping), mechanically operated
TransmissionConstant mesh 6-speed gearbox integrated in crankcase
DriveChain Drive
CHASSIS
Suspension FrontTelescopic fork, Ø 41 mm
Suspension RearCast aluminum dual swing arm, central spring strut, spring pre-load hydraulically adjustable, rebound damping adjustable
Brakes FrontDual disc brake, floating brake discs, 12.0″ (305 mm), double-piston floating caliper
Brakes RearSingle disc brake, 10.4″ (265 mm), single-piston floating caliper
Tires Front110/80 R19
Tires Rear150/70 R17
Fuel Tank Capacity4.0 gal. (15 l)
ColorLight white
ELECTRICAL
AlternatorPermanent magnet generator 416 W (nominal power)
Battery12 V / 10 Ah, maintenance free
HeadlightFull-LED headlight
Tail Light
DIMENSIONS
Overall Length88.8” (2,255 mm)
Overall Width36.3” (922 mm)
Overall Height48.2” (1,225 mm)
Wheelbase61.4” (1,559 mm)
Castor4.1” (104.5 mm)
Seat HeightComfort Seat: 32.7″, Standard Seat: 32.1″, Low Seat: 31.1″, Suspension Lowering Kit: 30.3
Unladen weight, road ready, fully fueled493 lbs. (227 kg)
WARRANTY
Warranty
2021 BMW F 750 GS
2021 BMW F 750 GS Features​
Become one with your machine
To ensure that you sit perfectly on your F 750 GS, you can select the right height from a variety of seat variations: from the low-sitting version with 30.3“ to the rally seat with 33.2″. Through the removal of disruptive edges when standing and the adjusted width when sitting for extended periods, the new “extra low” seat helps you become one with your machine.
Feel the engine
The F 750 GS fuels your thirst for adventure: The two-cylinder in-line engine delivers immense power to the rear wheel with 77 hp – combined with low consumption (57 mpg according to WMTC).
2021 BMW F 750 GS Photos​
2021 BMW F 750 GS
2021 BMW F 750 GS
2021 BMW F 750 GS
2021 BMW F 750 GS
2021 BMW F 750 GS Videos
BMW Official Websites
The post 2021 BMW F 750 GS [Model Overview] appeared first on webBikeWorld.
