2021 BMW R NineT [Model Overview]
BMW’s Urban Adventurer: The 2021 BMW R NineT Urban G/S​
The BMW R nineT Urban G/S is a European-made heritage roadster that takes its inspiration from the legendary R80GS. While it’s easily one of the most eye-catching models in the R nineT range, it’s arguably one of the most exciting models in the entire 2021 BMW line-up. Built on top of the already successful R nineT platform, BMW has added in a little G/S spice to get heads turning.
The heart of the Urban G/S is a 1,170cc air/oil-cooled, 4-stroke flat twin engine. To meet new emissions regulations, the R nineT has had some internal revisions but the results haven’t been drastic. The new specs show the R nineT producing one less HP at 109 horsepower, and the same 86 lb-ft of torque that it had before.
The Urban G/S might look like it’s all talk but it actually comes with plenty of top-notch equipment to ensure that its bite is as strong as its bark. Standard equipment includes ABS Pro, Dynamic Braking Control, selectable riding modes, and a rear shock with travel-dependent damping.
For 2021, the R nineT Urban G/S is available in three original BMW Motorrad color options: Light White Metallic, Opt. 719 Black Storm Metallic / Light White, or Opt. 719 Black Storm Metallic / Aurum.
The 2021 BMW R NineT Urban G/S is expected to start from $12,495 USD / $14,500 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 BMW R NineT Urban G/S in one place.
2021 BMW R NineT
  • Price: $12,495*** USD / $14,500 CAD ***Expected. US MSRP currently unannounced
    • Boxer twin engine
    • Large 19-inch front wheel
    • ABS
  • Engine: 1,170 cc air/oil-cooled 4-stroke flat twin engine
  • Power: 109 HP
  • Torque: 86 lbs-ft
  • Wet Weight: 487 lbs (221 kg)
  • Seat Height: 33.5″ (850 mm)
2021 BMW R NineT
2021 BMW R NineT Specifications​
Engine 1,170 cc air/oil-cooled 4-stroke flat twin engine
Engine Power109 Hp
Bore x Stroke101 mm x 73 mm
Compression Ratio12.0:1
Fuel deliveryElectronic intake pipe fuel injection, electronic engine management with overrun cut-off, twin-spark ignition
Max Torque116 Nm at 6,000 rpm
ClutchHydraulically operated single-disc dry clutch
TransmissionConstant mesh 6-speed gearbox with helical gear teeth
DriveShaft drive
Suspension FrontTelescopic forks, 43 mm fixed-tube diameter
Suspension RearCast aluminium single swing-arm with BMW Motorrad Paralever; central spring strut, spring preload via hook wrench can be adjusted infinitely, rebound stage damping adjustable
Brakes FrontTwin disc brake, diameter 320 mm, 4-piston fixed calipers
Brakes RearSingle disc brake, diameter 265 mm, double-piston floating caliper
Tires Front120/70 ZR 19
Tires Rear170/60 ZR 17
Fuel Tank Capacity
ColorOpt. 719 Black storm metallic/Aurum
Alternator720-W three-phase generator
Battery12 V / 12 Ah, maintenance-free
Headlight
Tail LightWhite indicators and LED rear light
Overall Length2,175 mm
Overall Width870 mm
Overall Height1,330 mm
Wheelbase1,527 mm
Castor110.6 mm
Seat Height850 mm (Low seat (OE): 820mm)
Unladen weight, road ready, fully fueled
221 kg
Warranty
2021 BMW R NineT
2021 BMW R NineT Features​
Distinctive front.​
Headlamp mask, round headlights with windscreen: a front reminiscent of vintage G/S bikes.
Front mudguard.​
Dirt doesn’t stand a chance: the raised mudguard keeps things rolling. Nothing gets clogged with mud and dirt.
A perfect colour scheme.​
White tank, blue accents and the red seat: classic BMW M.
Enduro foot pegs.​
For better hold and better vehicle control for offroad use and driving while standing.
Large 19-inch front wheel.​
The 19-inch front wheel with optional all-terrain tires brings up memories of rides on almost impassable terrain.
Red seat.​
The inspiration is clear: just like the R 80 G/S, the R nineT Urban G/S also has the distinctive long red seat.
White indicators.​
Elegant and modern: White indicators.
Bolted-on heat shield.​
A classic enduro touch: heat shield on the brushed stainless steel rear silencer.
2021 BMW R NineT Photos​
2021 BMW R NineT
2021 BMW R NineT
2021 BMW R NineT
2021 BMW R NineT
2021 BMW R NineT Videos​
BMW Official Websites​
The post 2021 BMW R NineT [Model Overview] appeared first on webBikeWorld.
