2021 Ducati Hypermotard 950 [Model Overview]
Ducati’s Supermoto Hypermotard 950 Returns For 2021​
The Hypermotard range features three Supermoto-inspired models in the 2021 Ducati line-up. These Italian-made supermotos include the 950, 950 SP, and brand new 950 RVE. We’re here to look at the base model Supermoto Ducati motorcycle: the 950. Though it’s the cheapest model in the range, don’t be fooled. It’s a formidable motorcycle with impressive performance specs and supreme handling.
Recently updated in 2020, the 2021 Ducati Hypermotard 950 receives nothing new for 2021. That means that it’s still powered by the same 937 cc 11-degree Testastretta twin-cylinder engine as last year, producing 114 horsepower and 71 lb-ft of peak torque. The previous update shaved a handsome 3.3 lbs off of the overall engine’s weight, making it quite a powerful and compact unit.
The powerful engine is kept under control with sophisticated electronics and riding aids, including three selectable riding modes, traction control, cornering ABS, and wheelie control. Other cool features include a Daytime Running Light, wide tapered aluminum handlebars, a USB power socket, and removable pillion footpegs.
For 2021, the Hypermotard 950 is available exclusively in Ducati Red, with a black rear subframe.
The 2021 Ducati Hypermotard 950 starts at $13,395 USD / $15,295 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Ducati Hypermotard 950 in one place.
  • Price: $13,395 USD / $15,295 CAD
    • Fully adjustable Marzocchi front suspension
    • Bosch cornering ABS EVO
    • Three riding modes
Main Specs​
  • Engine: 937 cc liquid-cooled, Testastretta V2 engine
  • Power: 114 HP
  • Torque: 71 lbs-ft
  • Dry Weight: 392 lbs (178 kg)
  • Seat Height: 34.2 in (870 mm)
Competitors​
  • Aprilia Dorsoduro 900
  • KTM 690 SMC R
  • KTM 790 Duke R
2021 Ducati Hypermotard 950 Specifications​
Engine937 cc liquid-cooled, Testastretta V2 engine
Power114 HP
Bore x Stroke94 x 67,5 mm (3,70 x 2,66 in)
Compression Ratio13,3:1
Fuel InjectionElectronic fuel injection system, Ø 53 mm throttle bodies with full Ride by Wire system.
Torque96 Nm (71 lb-ft) @ 7.250 rpm
ClutchSlipper and self-servo wet multiplate clutch, hydraulic control.
Transmission6 Speed
Final DriveChain; Front sprocket 15; Rear sprocket 43
Suspension FrontMarzocchi aluminum fully adjustable, upside-down Ø 45 mm.
Suspension RearProgressive linkage with adjustable spring preload and rebound damping Sachs monoshock. Aluminum single-sided swingarm.
Brakes Front2 x 320 mm semi-floating aluminum flange discs, radially mounted Monobloc Brembo callipers, 4-piston 2-pad, radial pump with adjustable lever, with Bosch cornering ABS EVO.
Brakes Rear
Tires FrontPirelli Diablo Rosso III, 120/70 ZR17
Tires Rear
Pirelli Diablo Rosso III, 180/55 ZR17
Fuel Tank Capacity14.5 l (3,8 US gallons)
ColorGraffiti
Ignition
HeadlightLED
Overall Length
Overall Width
Rake25°
Wheelbase1493 mm (58,8 in)
Trail104 mm (4.1 in)
Seat Height870 mm (34.2 in)
Kerb Weight
Warranty24 months unlimited mileage
2021 Ducati Hypermotard 950 Features​
Design​
Motard style
The Hypermotard perfectly combines such distinctive features of the original Hypermotard 1100 as minimalism, aggressiveness, lightweight look and “fun-bike” image with the innovation and technology of Ducati’s latest generation models. . The “Graffiti” color scheme of the new 950 RVE emphasises the lightness and aggression of the bike with a high-impact graphics layout, inspired by urban graffiti.
Graffity Color Scheme​
“Graffiti” livery
For the first time across such an extensive, complex surface, Ducati has utilised ultra-thin waterslide decals during the painting phase. As this application process is particularly lengthy and complicated, it calls for highly specialised skills. The end result is comparable to that of airbrushed bodywork, of extremely high-quality, imperceptible to the touch and long-lasting.
Ergonomics​
Fun to the Nth degree
For the utmost riding fun and control the Hypermotard 950 is equipped with an open handlebar, narrow side profile, a seat with an extended profile and a moderate bulge in the passenger area for improved comfort. For the 950 RVE and 950 SP versions the seat is flat, in line with the pro-motard style, to facilitate shifting forward and backward on the seat while riding. The 950 RVE seat has a special covering with a dedicated “tone on tone” Ducati logo.
Performance​
Ducati Testastretta 11°
The Hypermotard 950 family is equipped with a revised version of the 937 cc twin-cylinder Ducati Testastretta 11°. The twin-cylinder engine has been radically revised and lightened (-1.5 kg). It outputs 4 more horsepower than its predecessor (114 hp at 9,000 rpm) and a flat torque curve peaking at 9.8 kgm at 7,250 rpm. All the Hypermotard versions are available with the 35Kw engine specifications suitable for learners. Thanks to Ducati’s constant attention to quality, the 937 cc Testastretta 11° engine allows optimal maintenance management: valve adjustment is scheduled every 30,000 km.
2021 Ducati Hypermotard 950 Photos​
2021 Ducati Hypermotard 950 Videos​
The post 2021 Ducati Hypermotard 950 [Model Overview] appeared first on webBikeWorld.
