2021 Ducati Hypermotard 950 SP [Model Overview]
The Exclusive Ducati Hypermotard 950 SP Returns For 2021​
The second Hypermotard model in the 2021 Ducati line-up is the Hypermotard 950 SP: a slick Italian-made Supermoto with premium components, designed for fast and agile urban riding. Despite being a Supermoto, it’s still chock full of the same elegance and attitude associated with other Ducati motorcycles, but in a more versatile package. Like the standard Hypermotard 950, the SP model receives no updates for 2021.
That means that it still draws power from the same 937cc 11-degree Testastretta twin-cylinder engine as last year, producing 114 horsepower and 71 lb-ft of peak torque, and with the same riding aids too. Notable features include selectable riding modes, Ducati Traction Control EVO, Wheelie Control EVO, and Bosch Cornering ABS EVO.
What makes the Hypermotard 950 SP more impressive than the standard base model is the addition of a number of key premium ingredients. The most significant of these include a bi-directional Ducati Quick Shift system, Fully adjustable Öhlins front suspension, Marchesini forged wheels, and a selection of carbon fiber parts, such as the timing belt covers and front mudguard. The Hypermotard 950 SP also receives a different color option too.
For 2021, the Hypermotard 950 SP is available exclusively in Ducati’s SP livery. This is a bold Ducati Red and White scheme, with a black rear subframe.
The 2021 Ducati Hypermotard 950 SP starts at $17,195 USD / $19,495 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Ducati Hypermotard 950 SP in one place.
  • Price: $17,195 USD / $19,495 CAD
    • Fully adjustable Öhlins front suspension
    • Bosch cornering ABS EVO
    • Selectable riding modes
Main Specs​
  • Engine: 937 cc liquid-cooled, Testastretta V2 engine
  • Power: 114 HP
  • Torque: 71 lbs-ft
  • Dry Weight: 392 lbs (178 kg)
  • Seat Height: 34.2 in (870 mm)
Competitors​
  • Aprilia Dorsoduro 900
  • KTM 690 SMC R
  • KTM 790 Duke R
2021 Ducati Hypermotard 950 SP Specifications​
Engine937 cc liquid-cooled, Testastretta V2 engine
Power114 HP
Bore x Stroke94 x 67,5 mm (3,70 x 2,66 in)
Compression Ratio13,3:1
Fuel InjectionElectronic fuel injection system, Ø 53 mm throttle bodies with full Ride by Wire system.
Torque96 Nm (71 lb-ft) @ 7.250 rpm
ClutchSlipper and self-servo wet multiplate clutch, hydraulic control.
Transmission6 Speed
Final DriveChain; Front sprocket 15; Rear sprocket 43
Suspension FrontOhlins fully adjustable, upside-down Ø 48 mm
Suspension RearProgressive linkage with fully adjustable Öhlins monoshock. Aluminum single-sided swingarm-
Brakes Front2 x 320 mm semi-floating aluminum flange discs, radially mounted Monobloc Brembo callipers, 4-piston 2-pad, radial pump with adjustable lever, with Bosch cornering ABS EVO.
Brakes Rear
Tires FrontPirelli Diablo Supercorsa SP v3, 120/70 ZR17
Tires Rear
Pirelli Diablo Supercorsa SP, 180/55 ZR17
Fuel Tank Capacity14.5 l (3,8 US gallons)
ColorGraffiti
Ignition
HeadlightLED
Overall Length
Overall Width
Rake25°
Wheelbase1498 mm (59,0 in)
Trail104 mm (4.1 in)
Seat Height 890 mm (35.0 in)
Kerb Weight
Warranty24 months unlimited mileage
2021 Ducati Hypermotard 950 SP Features​
Design​
Motard style
The Hypermotard perfectly combines such distinctive features of the original Hypermotard 1100 as minimalism, aggressiveness, lightweight look and “fun-bike” image with the innovation and technology of Ducati’s latest generation models. . The “Graffiti” color scheme of the new 950 RVE emphasises the lightness and aggression of the bike with a high-impact graphics layout, inspired by urban graffiti.
Graffity Color Scheme​
“Graffiti” livery
For the first time across such an extensive, complex surface, Ducati has utilised ultra-thin waterslide decals during the painting phase. As this application process is particularly lengthy and complicated, it calls for highly specialised skills. The end result is comparable to that of airbrushed bodywork, of extremely high-quality, imperceptible to the touch and long-lasting.
Ergonomics​
Fun to the Nth degree
For the utmost riding fun and control the Hypermotard 950 is equipped with an open handlebar, narrow side profile, a seat with an extended profile and a moderate bulge in the passenger area for improved comfort. For the 950 RVE and 950 SP versions the seat is flat, in line with the pro-motard style, to facilitate shifting forward and backward on the seat while riding. The 950 RVE seat has a special covering with a dedicated “tone on tone” Ducati logo.
Performance​
Ducati Testastretta 11°
The Hypermotard 950 family is equipped with a revised version of the 937 cc twin-cylinder Ducati Testastretta 11°. The twin-cylinder engine has been radically revised and lightened (-1.5 kg). It outputs 4 more horsepower than its predecessor (114 hp at 9,000 rpm) and a flat torque curve peaking at 9.8 kgm at 7,250 rpm. All the Hypermotard versions are available with the 35Kw engine specifications suitable for learners. Thanks to Ducati’s constant attention to quality, the 937 cc Testastretta 11° engine allows optimal maintenance management: valve adjustment is scheduled every 30,000 km.
2021 Ducati Hypermotard 950 SP Photos​
2021 Ducati Hypermotard 950 SP Videos​
The post 2021 Ducati Hypermotard 950 SP [Model Overview] appeared first on webBikeWorld.
