2021 Honda CB300R [Model Overview]
Honda’s Neo-Sports Cafe 2021 CB300R ABS is Back Again!​
The 2021 Honda CB300R is the perfect starting point for anyone looking to explore motorcycling. This Japanese motorcycle is a combination of weight, power, and excellent handling. The style of the CB300R looks awesome too, it’s referred to as a “Neo-Sports Cafe” look by Honda.
This year’s CB300R comes with ABS as an added safety feature, making it another great beginner choice for Honda’s 2021 lineup. Its 286cc single-cylinder provides the right amount of power for those who commute in the city or those who are just starting out on a motorcycle.
Though the CB300R may look stripped to bare bones, it comes packing a rather smart display. Comes with an LCD display that shows engine rpm, fuel level, and gear shift indicator. The CB300R also comes with LED lights front and rear. Honda says they’ve fitted their thinnest taillight yet on this bike.
The 2021 Honda CB300R starts at $4,949 USD / $5,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Honda CB300R in one place.
2021 Honda CB300R
  • Price: $4,949 USD / $5,999 CAD
    • Standard ABS
    • 286cc Engine
    • Blacked out hardware
Main Specs​
  • Engine: 286cc Single-cylinder
  • Power: 30 BHP
  • Wet Weight: 317 lbs (144 kg)
  • Seat Height: 31.5 inches (800 mm) at lowest point
Competitors​
  • 2021 KTM 390 Duke
  • 2021 Husqvarna Vitpilen 401
2021 Honda CB300R
2021 Honda CB300R Specifications​
Engine286cc liquid-cooled 20º single-cylinder four-stroke
Power30 BHP
Bore x Stroke76mm x 63mm
Compression Ratio10.7:1
Fuel SystemFuel injection w/ 38mm throttle body
Valve TrainDOHC; four valves per cylinder
Clutch
TransmissionSix-Speed
Final Drive
Suspension Front41mm telescopic fork; 5.1 inches of travel
Suspension RearPro-Link® single shock; 4.2 inches of travel
Brakes FrontSingle 296mm disc; ABS
Brakes RearSingle 220mm disc; ABS
Tires Front110/70-17
Tires Rear150/60-17
Fuel Tank Capacity2.7 gallons
ColorMatte Pearl Blue
IgnitionFull transistorized ignition
HeadlightLED
Overall Length
Overall Width
Trail93mm (3.7 inches)
Wheelbase53.3 inches
Ground Clearance
Seat Height31.5 inches
Curb Weight317 pounds
2021 Honda CB300R
2021 Honda CB300R Features​
PERFORMANCE​
COMPACT ENGINE
The CB300R’s compact 286cc DOHC four-valve, liquid-cooled, single-cylinder engine is a jewel with a free-revving, responsive nature. The engine also works extraordinarily well in real-world road-riding conditions, providing plenty of power both around town and out on the highway.
FINE-TUNED INTAKE AND EXHAUST
The CB300R’s engine uses an intake and exhaust designed to reduce air resistance, contributing to more linear throttle response.
HIGH-REVVING PERFORMANCE
Bore and stroke are set at 76 x 63mm, with a compression ratio of 10.7:1. PGM-FI fuel injection—with 38mm throttle bore and a refined, straight-shot intake path—delivers crisp throttle response across the rev range.
UNDERSLUNG EXHAUST
The CB300R underslung exhaust features a dual-chamber design with the outlet on the right side. The high-flow design contributes to an ultra-linear throttle response.
HANDLING​
LIGHT, STRONG STEEL CHASSIS
The concept behind a Neo-Sports Café machine strives for a perfect combination of handling, power, and athletic comfort. Great handling starts with a superior chassis, which is why the CB300R uses special frame construction designed to be both light and strong.
INVERTED FRONT FORK
The CB300R’s 41mm inverted fork offers a smooth ride with compliant damping. The supple spring rate is just right for a bike this size.
LIGHTWEIGHT ALUMINUM WHEELS
Unsprung weight—the tires, wheels, and brakes—are super-important in a sportbike. The CB300R’s lightweight aluminum wheels are a critical part of the bike’s responsive handling. Plus, they look great too.
LIGHTWEIGHT CONSTRUCTION
Since it’s over 30 pounds lighter than our previous CB300F model, the 2021 CB300R’s user-friendly 317-pound curb weight means this bike handles well, and is easier to balance at stoplights or in parking lots.
PERFECT BALANCE
The CB300R features a balanced 49.6/50.4 front/rear weight bias. That means you’re set up for unmatched sport riding, combining rear-wheel traction, front-end grip, and balanced braking forces.
TUNED STEEL SWINGARM
In addition to the CB300R’s chassis, the steel swingarm is designed to provide high longitudinal rigidity and control torsion without being harsh or heavy. This means you get confidence-inspiring feel and feedback, especially while cornering.
STYLE​
NEO-SPORTS CAFÉ STYLE
Taking its styling cues from our CB1000R, the CB300R offers a fresh, contemporary take on the modern streetbike. Plus, the light weight and upright seating make it a blast to ride.
ENGINEERING​
STANDARD ABS
Our Anti-Lock Braking System (standard on the 2021 CB300R) can be a big help in making controlled stops in less-than-ideal conditions, like on wet pavement or other compromised surfaces. It’s a great choice whether you’re using your new bike as a commuter or just riding it for fun, since it helps you stop with added confidence.
BLACKED-OUT HARDWARE
Check out the blacked-out hardware; subtle touches like these complement the CB300R’s traditional-meets-modern Neo-Sports Café styling.
EFFICIENT DESIGN
The CB300R’s engine is designed with a minimum number of moving parts. Details like low-friction piston rings, high-density core radiator and iridium spark plug help increase fuel efficiency. Thanks in part to the weight-saving measures and the intake layout, initial acceleration has been improved by 4%.
LCD INSTRUMENTS
The CB300R’s lightweight, full-function LCD display adds a premium feel. It’s 60-percent thinner than previous designs, and gives you readouts for engine rpm, speed, and fuel level.
LED LIGHTING PACKAGE
Another perfect example of classic styling with a modern touch, the CB300R features an all-LED lighting package, yet still sports a timeless round headlight lens. The LED taillight is the thinnest ever mounted on a Honda motorcycle!
POWERFUL BRAKES
The CB300R’s radial-mount four-piston Nissin front brake caliper clamps down onto a 296mm floating disc to provide optimum stopping power.
2021 Honda CB300R Photos​
2021 Honda CB300R
2021 Honda CB300R
2021 Honda CB300R
2021 Honda CB300R
2021 Honda CB300R Videos​
Honda Websites​
Other Links​
The post 2021 Honda CB300R [Model Overview] appeared first on webBikeWorld.
