2021 Honda CRF450RL [Model Overview]
The 2021 CRF450RL: A Street Legal Motocrosser​
The 2021 CRF450RL is the reimagined CRF450L from years past but it’s still loaded with off-road enhancements. It’s based on the CRF450R motocross platform but tuned for ripping on the trails and street alike.
Honda Motorcycles tuned the CRF450RL’s engine to enhance and improve low RPM torque performance with a new crankshaft. It received a new ECU to refine the fuel delivery system to the 449cc liquid-cooled engine capable of 41.7hp.
The CRF450RL comes with a wider frame to make room for the 6-speed transmission which proves versatile no matter what the trails call for. It’s another bike in the 2021 Honda lineup that comes with Showa forks and a Pro-Link rear shock that provide a comfy ride in even the roughest terrain. This Japanese motorcycle comes with 12 inches of travel in the front and 11.8 inches of rear travel – exactly what you need whether you’re climbing, crawling, or hitting the berms.
The 2021 Honda CRF450RL starts at $9,999 USD / $12,199 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Honda CRF450RL in one place.
2021 Honda CRF450RL
  • Price: $9,999 USD / $12,199 CAD
    • Disc brakes front and rear
    • Handguards
    • Inverted Forks
Main Specs​
  • Engine: 449cc liquid-cooled, single-cylinder, four-stroke
  • Power: 41.7 horsepower
  • Wet Weight: 289 lbs (131 kg)
  • Seat Height: 940 mm (37 in.) at the lowest point
Competitors​
2021 Honda CRF450RL Specifications​
Engine449cc liquid-cooled single-cylinder four-stroke
Power41.7 horsepower
Bore x Stroke96mm x 62.1mm
Compression Ratio12.0:1
Fuel SystemProgrammed Fuel Injection (PGM-FI), 46mm downdraft throttle body
Valve TrainUnicam® OHC, four-valve
Clutch
TransmissionWide-ratio six-speed
Final Drive#520 Chain; 13T/51T
Suspension Front49mm leading-axle inverted telescopic Showa coil-spring fork with rebound and compression damping adjustability; 12.0 inches of travel
Suspension RearPro-Link Showa single shock with adjustable spring preload, rebound and compression damping adjustability; 11.8 inches of travel
Brakes FrontSingle 260mm disc with twin-piston caliper
Brakes RearSingle 240mm disc
Tires FrontIRC GP21 80/100-21
Tires RearIRC GP22 120/80-18
Fuel Tank Capacity2.0 gallons
ColorRed
IgnitionDC-CDI
Headlight
Tail Light
Overall Length
Overall Width
Trail4.8 inches
Wheelbase58.9 inches
Ground Clearance12.6 inches
Seat Height37.2 inches
Curb Weight291 pounds (Includes all standard equipment, required fluids and full tank of fuel—ready to ride.)
2021 Honda CRF450RL Features​
VERSATILITY​
FULLY STREET LEGAL & OFF-ROAD CAPABLE
The CRF450RL is equipped with a catalytic converter and is fully street legal in all 50 states—and off-road capable just about anywhere on the planet. That means you can ride it wherever it’s legal to operate a motor vehicle—in state and national parks, on the road, on public lands. Plus, you don’t need to haul your bike to the trailhead in a truck or on a trailer. Best of all, it makes finding gas (or lunch) a breeze.
CONVENIENCE​
ELECTRIC START
An electric start system ensures trouble-free starting in all conditions. The electric starter also drives the clutch side of the crankshaft to provide superior lubrication to starter gears while producing a narrow engine with a short, strong crank.
[accordion title=’PERFORMANCE
449cc UNICAM® ENGINE
The CRF450RL’s Unicam® cylinder-head combines the best of single- and double-overhead-cam designs, and shares its DNA with our championship-winning CRF450R. The configuration saves weight compared to a dual-overhead-camshaft motor, and the camshaft sits lower in the head for a more compact engine and a lower center of gravity. You also get a narrow included valve angle that flattens the combustion chamber for better ignition flame propagation and a high compression ratio.
FUEL INJECTION
The CRF450RL features our proven fuel-injection system. It’s part of the reason the CRF450RL offers such excellent torque and spot-on metering and response, especially in the critical low-rpm range. It also automatically compensates for elevation and weather changes.
TITANIUM INTAKE AND EXHAUST VALVES
Lightweight titanium intake and exhaust valves permit use of smaller valve springs, reducing overall engine height.
ENGINEERING​
WIDE-RATIO SIX-SPEED TRANSMISSION
Like our CRF450X, the CRF450RL rocks a wide-ratio six-speed gearbox. That gives you a low gear perfect for tight, slow situations, and a top gear that’s tall enough for highway riding to the next gas stop or trailhead.
DUAL RADIATORS
The CRF450RL’s dual radiators feature a refined core area for superior heat dissipation compared with conventional dual-radiator designs. A coolant recovery tank is located in front of the engine between the frame downtubes for improved center of mass, and the tank is protected by a plastic skid plate.
ELECTRIC FAN
The CRF450RL is a “ride anywhere” type of bike, and because conditions vary so widely, we’ve equipped it with a light electric fan for the radiator. Rock crawling or riding on a hot Arizona single-track, it helps keep your engine running cool.
FINAL-DRIVE SPROCKET DAMPER
Designed to keep your bike quieter while not adding any weight, these unique drive sprockets are just another example of the CRF450RL’s innovative engineering.
INERTIA-TUNED CRANK
The CRF450RL’s crank has 13 percent more inertia than the CRF450R. Why? To smooth out power delivery and make the engine more user-friendly in tight, technical situations.
LED HEADLIGHT
The CRF450RL features an all-LED lighting package, including the headlight. That’s a big deal, because it takes a lot of weight off the front end. And the lighting pattern is also specially designed for both on- and off-road situations.
LED TAILLIGHT
The LED taillight is integrated into the rear fender. It’s light, compact and rigid.
LITHIUM-ION BATTERY
Light, compact, and offering excellent performance—just like the CRF450RL itself! Conventional batteries are heavy, but not this premium piece. It’s all part of why your CRF450RL performs as well as it does.
SKID PLATE
The CRF450RL’s factory skid plate is light, yet also offers the engine and lower-frame protection serious riders demand on a machine like this.
TITANIUM FUEL TANK
Holding 2.0 gallons, the CRF450RL’s premium titanium tank is light and tough.
HANDLING​
18-INCH REAR WHEEL
The CRF450RL’s 18-inch rear wheel gives you an excellent choice of on/off-road tires.
IRC GP TIRES
The CRF450RL’s tires give you good off-road traction and on-road life. Tires are always a critical part of any on/off-road bike, and we’ve hooked you up with some great ones here.
LOW CENTER OF GRAVITY
The compact Unicam® engine and Honda’s famous concentration on center-of-mass engineering help keep the CRF450RL’s center of gravity low. That means the bike feels lighter, and it helps handling too.
TWIN-SPAR CHASSIS
This is the same design as our latest CRF450X uses, and that’s a really big deal. It means the CRF450RL is a true off-road bike, and not some compromise. The twin-spar aluminum frame is both light and stiff, and provides the basis for the CRF450RL’s excellent handling. The chassis geometry is specially selected for responsiveness, and also is wider than the standard MX frame to accommodate the six-speed transmission.
WORKS-STYLE FRONT BRAKE
Compact twin-piston front brake caliper, anodized-aluminum brake pistons and lightweight 260mm front disc offer great stopping power while minimizing unsprung weight for improved turning and handling.
WORKS-STYLE REAR BRAKE
HRC works-type rear brake system uses a 240mm brake rotor combined with an integrated rear master-cylinder and fluid reservoir, a set-up that eliminates the separate reservoir and hose.
COMFORT​
NEW FACTORY HANDGUARDS
You asked; we delivered. The 2021 CRF450RL comes with handguards installed right from the factory. They’re fully integrated, too, not like some aftermarket add-ons. They attach right to the control-lever pivots, are color-matched to your new bike, and are even vented.
BLACK DID RIMS
They may not help you go faster, but the sweet black DID DirtStar rims sure look good.
FUEL MILEAGE METER
An important feature for planning gas stops and calculating your bike’s range under varying conditions, the Fuel Mileage Meter shows current fuel mileage and average fuel mileage as well as fuel consumption. Displays in either miles or kilometers, and applies to both the A and B tripmeters. The Fuel Mileage Meter is in the same digital instrument display as the speedometer, odometer, tripmeters and digital clock.
GEAR-DRIVEN COUNTERBALANCER
The Gear-Driven Counterbalancer reduces vibration and drives the water pump. Eight clutch plates provide the surface area necessary to handle the engine’s massive torque, while carefully matched clutch springs provide a light feel at the lever.
SIDESTAND
Hey, a sidestand may seem like no big thing, but take a look at the one the CRF450RL uses. Tucked up high and out of the way, this forged alloy piece is just another example of how the CRF450RL gets it right.
SUPERIOR ERGONOMICS
Placing the rider’s legs at the narrowest part of the frame helps improve comfort and handling.
WORKS MX STYLING
Having a hard time spotting the differences between our factory MX bikes and the CRF450RL? You’re excused. The “RL” looks like our MX bikes because it’s derived from them—the smooth bodywork makes it easy to move around, and the updated for 2021 in-mold graphics not only look cool but are durable, too.
2021 Honda CRF450RL Photos​
2021 Honda CRF450RL
2021 Honda CRF450RL
2021 Honda CRF450RL Videos​
Honda Websites​
Other Links​
The post 2021 Honda CRF450RL [Model Overview] appeared first on webBikeWorld.
