2021 Honda Trail 125 ABS: A Legend Returns
The Honda CT110 and CT90 were one of the most loved Honda Motorcycles ever. They were responsible for countless excursions in the 1960s and 70s for many families and people who loved being outdoors. Well, we’re happy to announce that the CT will be returning to the 2021 Honda lineup in the form of the Honda Trail 125 ABS.
The Trail 125 is built off of the Super Cub platform and given modifications to make it capable of light-duty offroad use. The 2021 Trail 125 has an increased rake, wheelbase, fork tube size, and wheel travel to improve off-road capability. It also has a retuned 124.9cc engine that’s also found in the Grom and Super Cub.
This Japanese motorcycle comes with disc brakes front and rear as opposed to the Super Cub’s rear drum brake configuration. It also comes sporting a center-stand for easy bike maintenance and cleaning.
The 2021 Honda Trail 125 ABS starts at $3,899 USD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Honda Trail 125 ABS in one place.
- Price: $3,899 USD
- Anti-lock brakes
- Rear rack
- Center stand
- Engine: 124.9cc air-cooled, single-cylinder, four-stroke
- Power: 9 horsepower
- Wet Weight: 259 lbs (117 kg)
- Seat Height: 800 mm (31.5 in.) at lowest point
- Yamaha TW200
- Honda Super Cub
- Honda Grom
- Honda Monkey
2021 Honda Trail 125 ABS Specifications
Engine | 124.9cc air-cooled single-cylinder four-stroke |
Power | 9 horsepower |
Bore x Stroke | 52.4mm x 57.9mm |
Compression Ratio | 9.3:1 |
Fuel System | PGM-FI with automatic enrichment |
Valve Train | SOHC; two valves per cylinder |
Clutch | Automatic centrifuga |
Transmission | Four-speed semi-automatic |
Final Drive | #420 Chain; 14T/39T |
Suspension Front | 27mm telescopic fork; 3.9 inches travel |
Suspension Rear | Twin shock; 3.4 inches travel |
Brakes Front | Single 220mm hydraulic disc; ABS |
Brakes Rear | Single 190mm hydraulic disc |
Tires Front | 80/90-17 |
Tires Rear | 80/90-17 |
Fuel Tank Capacity | 1.4 gallons (including 0.3-gallon-reserve) |
Color | Glowing Red |
Ignition | Fully transistorized |
Headlight | LED |
Tail Light | LED |
Overall Length | |
Overall Width | |
Trail | 3.1 inches |
Wheelbase | 49.4 inches |
Ground Clearance | |
Seat Height | 31.5 inches |
Curb Weight | 259 pounds |
Warranty | Unlimited-mileage, limited warranty |
2021 Honda Trail 125 ABS Features
N/A
2021 Honda Trail 125 ABS Photos
2021 Honda Trail 125 ABS Videos
Honda Websites
Other Links
The post 2021 Honda Trail 125 ABS [Model Overview] appeared first on webBikeWorld.
