2021 Indian Challenger Dark Horse [Model Overview]
The 2021 Indian Challenger Dark Horse Brings a Futuristic Aesthetic​
The Challenger Dark Horse returns to the Indian line-up for 2021, adding a touch of darkness to the celebrated Challenger range. Featuring a lightweight cast-aluminum frame, a large front fairing, hard luggage, and a giant engine, this model has all the makings of a legendary muscle cruiser. It could even be one of the best models from Indian Motorcycles this year.
The 2021 Indian Challenger Dark Horse uses Indian’s American-made Powerplus 108 V-twin engine. It’s a 1768 cc liquid-cooled unit that’s capable of producing 122 horsepower and 128 lb-ft of peak torque. That power is delivered to the rear wheel via a six-speed transmission, and controlled using Smart Lean Technology in the form of dynamic traction control, drag torque control, and ABS as standard.
The only real difference to the stock Challenger model is the blacked-out color options—but black and dark isn’t the only color option for this year.
For 2021, the Challenger Dark Horse is available in Thunder Black Smoke, Bronze Smoke, or White Smoke trims. Each option comes with ABS as standard.
The 2021 Indian Challenger Dark Horse starts at $27,999 USD / $34,499 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Indian Challenger Dark Horse in one place.
Motorcycle Overview​
  • Price: $27,999 USD / $34,499 CAD
    • Blacked-out PowerPlus engine
    • Aggressive fairing with LED lighting
    • Lightweight cast aluminum frame
    • High-output audio system
  • Engine type: 1768 cc liquid-cooled PowerPlus V-twin
  • Horsepower: 122 HP
  • Torque: 128 lb-ft
  • Wet Weight: 831 lb (377 kg)
  • Seat Height: 26.5 in (672 mm)
2021 Indian Challenger Dark Horse Specifications​
ENGINE
Engine1.768 cc, PowerPlus
Engine Power122 HP
Bore x Stroke4.251 in x 3.799 in (108 mm x 96.5 mm)
Compression Ratio11.0:1
Fuel SystemClosed loop fuel Injection / 52mm dual bore
ExhaustSplit Dual exhaust w/ Resonator
DRIVETRAIN
ClutchWet, Multi-Plate, Assist
Transmission6 Speed
Final DriveGear Drive Wet Clutch
CHASSIS
Suspension FrontInverted Telescopic Fork
Suspension RearSingle Shock w/Hyd adjust
Brakes FrontDual / 320mm Semi-Floating Rotor / 4 Piston Radial Caliper
Brakes RearSingle / 298mm Floating Rotor / 2 Piston Caliper
Tires FrontMetzeler Cruisetec 130/60B19 66H
Tires RearMetzeler Cruisetec 180/60R16 80H
Fuel Tank Capacity6.0 gal (22.7 L)
Color / GraphicsThunder Black Smoke, Bronze Smoke, White Smoke
ELECTRICAL
Ignition
HeadlightLED Headlamp
Tail LightLED Taillight
DIMENSIONS
Overall Length98.5 in (2500.7 mm)
Overall Width39 in (990.2 mm)
Overall Height56.2 in (1428.5 mm)
Wheelbase65.7 in (1667.8 mm)
Ground Clearance5.4 in (137.3 mm)
Seat Height26.5 in (672 mm)
Weight (Empty Tank / Full of Fuel)796 lb (361 kg)/831 lb (377 kg)
WARRANTY
Warranty2 Years, Unlimited Miles
2021 Indian Challenger Dark Horse Features​
FREE REIN TO DOMINATE
Our blacked-out PowerPlus liquid-cooled engine is a fully-modern design and redefines American V-twin performance. Class-leading 128 ft-lb of torque and 122 hp dominate straight from the factory. Three ride modes provide unmatched acceleration and passing power with all the character you’d expect from a V-twin.
CARVE CORNERS. ALL OF THEM.
Inverted front suspension, lightweight cast-aluminum frame, and hydraulically adjustable Fox® rear shock deliver curve-hugging handling and unyielding stability.
SUPREME TRACTION. SUPERIOR STOPPING POWER.
Race-spec, radially-mounted Brembo® brakes provide superior stopping power, and performance touring Metzeler® Cruisetec® tires offer supreme traction.
LEAD THE WAY
Chassis mounted fairing for incredibly precise, stable handling also provides class-leading wind protection which means maximum comfort mile after mile.
STYLE THAT STANDS ALONE
Aggressive fairing design with full LED lighting and menacingly styled running lights provide a signature face that leads the way in both style and function.
COMMAND ATTENTION
Open fender with subtle flip and a modern take on the iconic lit headdress means no mistaking that Indian Challenger has arrived.
LEAN INTO EVERY RIDE
, keeps you confidently grounded and in command of the road with 6-axis Bosch IMU, Dynamic traction control, ABS with cornering control, and Drag Torque Control.
MORE BEATS FOR THE STREETS
Go bigger with 6.5 in speakers that deliver 100-Watts of crystal-clear audio.
MORE SCREEN. MORE CONTROL.
RIDE COMMAND is the largest, most customizable system on two wheels, with Apple CarPlay® integration, turn-by-turn navigation with intuitive destination search capabilities, Bluetooth connectivity, vehicle information, plus connected traffic and weather overlays to keep you on the road longer.
2021 Indian Challenger Dark Horse Photos​
2021 Indian Challenger Dark Horse Videos
The post 2021 Indian Challenger Dark Horse [Model Overview] appeared first on webBikeWorld.
