2021 Indian Challenger Limited [Model Overview]
Touring Redefined: The 2021 Indian Challenger Limited​
The 2021 Indian Challenger Limited is one of the most impressive models in the 2021 Indian line-up. It features a selection of advanced riding aids, impressive ride ergonomics, and all the bells and whistles that you’d expect from a top-of-the-line touring motorcycle.
At the heart of the Challenger Limited you’ll find the Indian PowerPlus liquid-cooled engine. It’s an engine that Indian Motorcycle claims to redefine the landscape of American V-twin performance. With the same 1,770cc arrangement found on the rest of the Challenger range, the Limited model boasts 122 horsepower and 128 lb-ft of torque, for smooth acceleration with power right across the rev range.
Featuring ABS, Dynamic Traction Control, Drag Torque Control, and Smart Lean Technology, as well as sophisticated adjustable suspension, Brembo brakes, and Metzler Cruistec tires, the 2021 Indian Challenger Limited packs a sportier punch than you might think.
Like most modern touring machines, the Challenger Limited has an advanced touchscreen infotainment system, heated and cooled features, and access to a full catalog of extras and accessories.
For 2021, the Challenger Limited is available in three color options: Thunder Black Pearl, Deepwater Metallic, and Ruby Metallic.
The 2021 Indian Challenger Limited starts at $27,999 USD / $34,499 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new Indian Challenger Limited in one place.
Motorcycle Overview​
  • Price: $27,999 USD / $34,499 CAD
  • Smart Lean technology
  • Dynamic traction control
  • Radially mounted Brembo brakes
  • RideCommand infotainment
  • Engine type: 1,770cc V-twin
  • Horsepower: 122 HP
  • Torque: 128 lb-ft
  • Wet Weight: 840 lbs / 381 kg
  • Seat Height: 26.5 in (672 mm)
2021 Indian Challenger Limited Specifications​
ENGINE
Engine1,770cc V-twin
Engine Power122 Hp
Bore x Stroke4.251 in x 3.799 in (108 mm x 96.5 mm)
Compression Ratio11.0:1
Fuel SystemClosed loop fuel Injection / 52mm dual bore
ExhaustSplit Dual exhaust w/ Resonator
DRIVETRAIN
ClutchWet, Multi-Plate, Assist
Transmission6 Speed
Final DriveGear Drive Wet Clutch
CHASSIS
Suspension FrontInverted Telescopic Fork
Suspension RearFox Single Shock w/Hyd adjust
Brakes FrontDual / 320mm Semi-Floating Rotor / 4 Piston Radial Caliper
Brakes RearSingle / 298mm Floating Rotor / 2 Piston Caliper
Tires FrontMetzeler Cruisetec 130/60B19 66H
Tires RearMetzeler Cruisetec 180/60R16 80H
Fuel Tank Capacity6.0 gal (22.7 L)
ColorThunder Black Pearl, Deepwater Metallic, Ruby Metallic
ELECTRICAL
Ignition
HeadlightLED
Tail LightTaillight
DIMENSIONS
Overall Length98.5 in (2500.7 mm)
Overall Width39 in (990.2 mm)
Overall Height56.2 in (1428.5 mm)
Wheelbase65.7 in (1667.8 mm)
Ground Clearance5.4 in (137.3 mm)
Seat Height26.5 in (672 mm)
Weight (Empty Tank / Full of Fuel)
805 lbs (365 kg)/840 lbs (381 kg)
WARRANTY
Warranty2 Years, Unlimited Miles
2021 Indian Challenger Limited Features​
FREE REIN TO DOMINATE
Our PowerPlus liquid-cooled engine is a fully-modern design and redefines American V-twin performance. Class-leading 128 ft-lb of torque and 122 hp dominate straight from the factory. Three ride modes provide unmatched acceleration and passing power with all the character you’d expect from a V-twin.
CARVE CORNERS. ALL OF THEM.
Inverted front suspension, lightweight cast-aluminum frame, and hydraulically adjustable Fox® rear shock deliver curve-hugging handling and unyielding stability.
SUPREME TRACTION. SUPERIOR STOPPING POWER.
Race-spec, radially-mounted Brembo® brakes provide superior stopping power, and performance touring Metzeler® Cruisetec® tires offer supreme traction.
LEAD THE WAY
Chassis mounted fairing for incredibly precise, stable handling also provides class-leading wind protection. Color-matched fender close outs and highway bars add comfort mile after mile.
STYLE THAT STANDS ALONE
Aggressive fairing design with full LED lighting and menacingly styled running lights provide a signature face that leads the way in both style and function.
COMMAND ATTENTION
Open fender with subtle flip and a jewel-like modern take on the iconic lit headdress means no mistaking that Challenger has arrived.
LEAN INTO EVERY RIDE
, keeps you confidently grounded and in command of the road with 6-axis Bosch IMU, Dynamic traction control, ABS with cornering control, and Drag Torque Control.
MORE BEATS FOR THE STREETS
Go bigger with 6.5 in speakers that deliver 100-Watts of crystal-clear audio.
MORE SCREEN. MORE CONTROL.
RIDE COMMAND® is the largest, most customizable system on two wheels, with Apple CarPlay® integration, turn-by-turn navigation with intuitive destination search capabilities, Bluetooth connectivity, vehicle information, plus connected traffic and weather overlays to keep you on the road longer.
2021 Indian Challenger Limited Photos​
2021 Indian Challenger Limited Videos
The post 2021 Indian Challenger Limited [Model Overview] appeared first on webBikeWorld.
