2021 Indian Chieftain Dark Horse [Model Overview]
Dark Tourist: The Blacked-out 2021 Indian Chieftain Dark Horse​
The Indian Chieftain Dark Horse is arguably the most fearsome Chieftain model in the 2021 Indian line-up. Like its touring cruiser stablemates, the Chieftain Dark Horse features a large front fairing, a slammed stance, practical luggage, and a massive American-made V-twin engine. But unlike the others, the Dark Horse features a unique blacked-out aesthetic.
The blacked-out engine is Indian Motorcycle’s famous Thunderstroke 116 unit. This big and boisterous V-twin has a displacement of 1,890cc. It produces a hearty 92 horsepower and 126 lb-ft of peak torque. The powerful engine is complemented with a suite of top-shelf riding aids, including selectable ride modes, ABS, rear cylinder deactivation, cruise control, and tire pressure monitoring.
Other practicalities include keyless ignition, remote locking saddlebags, and Indian’s advanced RideCommand infotainment system, along with a 100 watt audio system!
Don’t let the Dark Horse name fool you though, because the Chieftain Dark Horse is available in more than a black color scheme.
For 2021, the Chieftain Dark Horse is available in a wide range of colors. The ABS model is available in Thunder Black Smoke, Ruby Smoke, and Titanium Smoke trims. The ICON models are available in Stealth Gray, Burnt Orange Metallic Smoke, and Crimson Metallic options.
The 2021 Indian Chieftain Dark Horse starts at $27,999 USD / $34,499 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Indian Chieftain Dark Horse in one place.
Motorcycle Overview​
  • Price: $27,999 USD / $34,499 CAD
    • Powerful Thunderstroke 116 V-twin engine
    • Blacked out hardware
    • Indian Motorcycle RideCommand infotainment
    • 18+ gallons of storage space
  • Engine type: 1,890 cc liquid-cooled Thunderstroke 116 V-twin
  • Horsepower: 92 HP
  • Torque: 126 lb-ft
  • Wet Weight: 823 lb (373 kg)
  • Seat Height: 25.6 in (650 mm)
2021 Indian Chieftain Dark Horse Specifications​
ENGINE
Engine1,890 cc, Thunderstroke® 116
Engine Power92 HP
Bore x Stroke4.063″ x 4.449″ (103.2mm x 113mm)
Compression Ratio11:1
Fuel SystemClosed loop fuel injection / 54 mm bore
ExhaustSplit Dual Exhaust w/ Cross-over
DRIVETRAIN
ClutchWet, Multi-Plate, Assist
Transmission6 Speed
Final DriveGear Drive Wet Clutch
CHASSIS
Suspension FrontTelescopic Fork
Suspension RearSingle Shock w/ Air adjust
Brakes FrontDual / 300 mm Floating Rotor / 4 Piston Caliper
Brakes RearSingle / 300 mm Floating Rotor / 2 Piston Caliper
Tires FrontMetzeler Cruisetec 130/60B19 66H
Tires RearMetzeler Cruisetec 180/60R16 80H
Fuel Tank Capacity5.5 gal (20.8 L)
Color / GraphicsThunder Black Smoke, Ruby Smoke, Titanium Smoke – Icon Colors: Stealth Gray, Burnt Orange Metallic Smoke, Crimson Metallic
ELECTRICAL
Ignition
HeadlightPathfinder LED Headlamp
Tail LightLED Taillight
DIMENSIONS
Overall Length98.7 in (2,506 mm)
Overall Width39.4 in (1,000 mm)
Overall Height54.5 in (1385 mm)
Wheelbase65.7 in (1668 mm)
Ground Clearance5.1 in (130 mm)
Seat Height25.6 in (650 mm)
Weight (Empty Tank / Full of Fuel)791 lb (359 kg) / 823 lb (373 kg)
WARRANTY
Warranty2 Years, Unlimited Miles
2021 Indian Chieftain Dark Horse Features​
THUNDERSTROKE 116 V-TWIN ENGINE
The blacked-out Thunderstroke 116 engine produces 126 ft-lb of torque for exceptional power at low RPM and responsive ride at any speed. 6-speed gearbox, throttle by wire and three distinct ride modes tailor the all the power perfectly to your needs.
STYLED WITH AN EDGE
Blacked-out finishes, a sleek fairing, slammed saddlebags, and Rogue seat deliver a streamlined, commanding presence.
INDIAN MOTORCYCLE RIDE COMMAND
RIDE COMMAND is the largest, most customizable system on two wheels, with Apple CarPlay® integration, turn-by-turn navigation with intuitive destination search capabilities, Bluetooth connectivity, vehicle information, plus connected traffic and weather overlays to keep you on the road longer.
MODERN. MEAN.
LED lighting from nose to tail and a lowered stance complete the custom-inspired look.
CORNER CARVING CONFIDENCE
Outstanding steering geometry and a lightweight cast aluminum frame come together to provide responsive handling and agile cornering at all speeds.
18+ GALLONS OF CARGO SPACE
Keep your cargo protected from the elements with 18+ gallons of weatherproof storage in power-locking slammed saddlebags.
PREMIUM AUDIO
Hear every note with high-output speakers in the fairing that deliver 100-Watts of crystal-clear audio. And the dynamic equalizer automatically adjusts for road, wind, and engine noise.
FEATURES FOR THE WIN
The Chieftain Limited comes standard with LED Lighting, keyless ignition, cruise control, power-locking saddlebags, ABS and tire pressure monitoring.
PUSH-BUTTON POWER WINDSHIELD
With the push of a handlebar-mounted button, this flare windshield will raise or lower to your preferred position.
2021 Indian Chieftain Dark Horse Photos​
2021 Indian Chieftain Dark Horse Videos
The post 2021 Indian Chieftain Dark Horse [Model Overview] appeared first on webBikeWorld.
