2021 Indian Motorcycle 1200 / 1200 S [Model Overview]
The Flat-Track Inspired Indian FTR 1200 & 1200 S​
The Indian FTR 1200 and 1200 S continue to inject some much-needed “sport” into the Indian model line-up. Ever since the FTR 1200 first rolled into dealerships in 2019, it has been one of the most ferocious American-made motorcycles on the market. As the smaller, race-only FTR 750 continues to dominate on track, the street-focused FTR 1200 continues to impress on the roads.
Inspired by Indian’s track-racing history, the FTR 1200 platform builds on the brand’s legacy but refocuses it for practical, sporty, and fast street riding. Aside from its sporty frame and ergonomics, the FTR 1200 models also feature a muscular 1,200 cc V-twin engine that produces 123 horsepower and 87 lb-ft of torque.
Both models boast Brembo brakes, high-performance Dunlop tires, and LED lights. The standard FR 1200 is only available in Thunder Black for 2021.
The 1200 S model features an impressive array of upmarket parts and components such as fully-adjustable suspension and stability control, and extra color options including Titanium Metallic over Thunder Black Pearl, Indian Motorcycle Red over Steel Gray, and a stunning Race Replica livery.
The 2021 Indian FTR 1200 starts at $11,499 USD / $14,499 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new Indian FTR 1200 in one place.
Motorcycle Overview​
  • Price: $11,499 USD / $14,499 CAD
    • Race-inspired design
    • Confident handling
    • Dunlop high-performance tires
    • Cruise control as standard
  • Engine type: 1,200cc V-twin
  • Horsepower: 123 HP
  • Torque: 87 lb-ft
  • Wet Weight: 508 lbs / 230 kg
  • Seat Height: 33.1 in (840 mm)
  • BMW R nineT
  • Ducati Monster 1200S
  • Triumph Speed Triple
2021 Indian Motorcycle 1200 / 1200 S Specifications​
ENGINE
Engine1,203 cc, DOHC, 4-Valves per Cylinder, Graded Buckets
Engine Power123 Hp
Bore x Stroke4.016 in x 2.898 in (102 mm x 73.6 mm)
Compression Ratio12.5:1
Fuel SystemClosed Loop Fuel Injection / 60 mm Bore
Exhaust2-1-2
DRIVETRAIN
ClutchAssist & Slip, Multi-Plate
Transmission
Final DriveGear Drive Wet Clutch
CHASSIS
Suspension FrontInverted Telescopic Cartridge Fork
Suspension RearMonotube IFP, 5.9 in travel
Brakes FrontDual 320mm x t5 Rotor with 4-Piston Calipers
Brakes RearSingle 265mm x t5 Rotor with 2-Piston Calipers
Tires FrontDunlop® DT3-R Radial, 120/70R19 60V
Tires RearDunlop® DT3-R Radial, 150/70R18
Fuel Tank Capacity3.4 gal (12.9 L)
Color / GraphicsThunder Black
ELECTRICAL
Ignition
HeadlightLED Headlight
Tail LightTaillight
DIMENSIONS
Overall Length90 in (2,286 mm)
Overall Width33.5 in (850 mm)
Overall Height51.1 in (1297 mm)
Wheelbase60 in (1,524 mm)
Ground Clearance7.2 in (183 mm)
Seat Height33.1 in (840 mm)
Weight (Empty Tank / Full of Fuel)488 lbs / 508 lbs (221 kg / 230 kg)
WARRANTY
Warranty2 Years, Unlimited Miles
2021 Indian Motorcycle 1200 / 1200 S Features​
RACE-INSPIRED DESIGN
The rear swingarm design and tank silhouette are just a few of the elements borrowed from the FTR750 race bike.
POISED FOR THRILLS
A powerful 1203cc V-twin engine with 123 hp and 87 ft-lb of low-end torque delivers progressive, predictable power.
NIMBLE HANDLING
A sporty riding position and compact size combine for a commanding, precise ride.
CONFIDENT HANDLING
The gas tank is strategically located under the seat to lower the center of gravity for improved handling.
GRIP THE ROAD
Exclusive new Dunlop® high performance street tires with flat track inspired tread provide precise grip and great durability on any road.
STOPPING POWER
An inverted front suspension coupled with radially mounted dual 320 mm Brembo® brakes provide incredible stopping power.
LIGHT YOUR WAY
Enjoy the ride longer with full LED lighting, including a new, high-output LED headlight for improved visibility.
KEEP CHARGED
A fast-charge USB port lets you easily charge mobile devices. Perfect for letting the world know you won’t be home anytime soon.
CRUISE IN COMFORT
Cruise control comes standard because once you head out, you’re bound to be going for the long haul.
2021 Indian Motorcycle 1200 / 1200 S Photos​
2021 Indian Motorcycle 1200 / 1200 S Bobber Videos
The post 2021 Indian Motorcycle 1200 / 1200 S [Model Overview] appeared first on webBikeWorld.
