2021 Indian Scout Sixty [Model Overview]
The 2021 Indian Scout Sixty​
The 2021 Indian Motorcycle line-up once again features the ever-popular Scout Sixty model. It’s a model that shares almost all of the same DNA as the larger Scout model but paired down into a more beginner-friendly, entry-level machine. But don’t be fooled into thinking that this is an Indian Scout-lite. Because it’s just as much of an American-made icon as its larger sibling.
While it’s advertised as an introductory motorcycle to get riders acquainted with the legendary Indian brand, it packs a serious punch. It features a 999cc liquid-cooled 60-degree V-twin engine that produces 78 horsepower and 65 lb-ft of torque—which is more than plenty.
Equipped with a single-seat, a selection of eye-catching color options, blacked-out hardware, and optional ABS, the 2021 Indian Scout Sixty is a worthy choice for new riders and experienced hands alike.
For 2021, the Scout Sixty is available in Thunder Black or Ruby Metallic.
The 2021 Indian Scout Sixty starts at $8,999 USD / $10,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new Indian Scout Sixty in one place.
Motorcycle Overview​
  • Price: $8,999 USD / $10,999 CAD
    • Lightweight cast aluminum frame
    • Blacked out 78 hp V-twin engine
    • Optional ABS
    • Stylish classic silhouette
  • Engine type: 1,000cc liquid-cooled V-twin
  • Horsepower: 78 HP
  • Torque: 65 lb-ft
  • Wet Weight: 544 lbs (247 kg)
  • Seat Height: 25.6 in (649 mm)
2021 Indian Scout Sixty Specifications​
ENGINE
Engine1,000cc liquid-cooled V-twin
Engine Power78 Hp
Bore x Stroke3.661 in x 2.898 in (93 mm x 73.6 mm)
Compression Ratio11:1
Fuel SystemClosed loop fuel injection / 54 mm bore
ExhaustSplit Dual Exhaust w/ Cross-over
DRIVETRAIN
ClutchWet, Multi-Plate
Transmission5 Speed
Final DriveGear Drive Wet Clutch
CHASSIS
Suspension FrontTelescopic Fork
Suspension RearDual Shocks
Brakes FrontSingle / 298 mm Rotor / 2 Piston Caliper
Brakes RearSingle / 298 mm Rotor / 1 Piston Caliper
Tires FrontKenda K673F 130/90-16 72H
Tires RearKenda K673 150/80-16 71H
Fuel Tank Capacity3.3 gal (12.5 L)
ColorThunder Black, Thunder Black ABS, Ruby Metallic ABS
ELECTRICAL
Ignition
HeadlightHeadlight
Tail LightTaillight
DIMENSIONS
Overall Length91.4 in (2,321 mm)
Overall Width36.1 in (916 mm)
Overall Height42 in (1,068 mm)
Wheelbase62 in (157.6 cm)
Ground Clearance5.7 in (14.5 cm)
Seat Height25.6 in (649 mm)
Weight (Empty Tank / Full of Fuel)524 lbs / 544 lbs (238 kg / 247 kg)
WARRANTY
Warranty2 Years, Unlimited Miles
2021 Indian Scout Sixty Features​
JOYRIDE OF THE CENTURY
The lightweight, cast aluminum frame, and low seat make for an expertly balanced bike that’s easy to handle at all speeds.
MODERN, LIQUID-COOLED V-TWIN ENGINE
Powered by a blacked-out, liquid-cooled, 60 cu in, 78 hp V-twin engine for a thrilling ride.
ELEVATE YOUR RIDE
Put the finishing touches on your ride with authentic Indian Motorcycle accessories.
AN ICON. REMASTERED.
The engine, headlights, fenders, and wheels were inspired by the original Scout of the 1920s.
BLACK, AND MORE BLACK
The modern 78 hp V-twin comes in one color and one color only: black.
COMFORT THAT GOES FURTHER
As comfortable as it is stylish.
ABS OPTIONAL
Superior stopping power with ABS optional.
FAST FORWARD
Equipped with a 5-speed transmission for quick acceleration and smooth cruising.
ENGINEERING IS EVERYTHING
Electronic fuel injection and liquid cooling are just some of the advanced engineering features giving the Scout Sixty unmistakable power every time you fire up the engine.
2021 Indian Scout Sixty Photos​
2021 Indian Scout Sixty Videos
The post 2021 Indian Scout Sixty [Model Overview] appeared first on webBikeWorld.
