The 2021 Kawasaki Ninja 400 ABS: Team Greens Tanto Sword
The 2021 Kawasaki Ninja 400 ABS is the Tanto Sword in the Ninja family. Japanese-made, small, light, and razor-sharp the 399cc Ninja more than lives up to the family name.
Many consider the Ninja 400 to be an entry-level motorcycle, and that is a role it fills well in the 2021 Kawasaki lineup, but this a very satisfying bike for a wide range of skill levels. The overall design makes for a nimble and very efficient urban ripper, the power delivery is smooth and the riding position just right to hone your cornering skills. The ABS and slipper clutch are very welcome technology for all riders.
The same traits that make the Ninja 400 a fun daily ride also translate to the track. The great handling and lower power level become an excellent platform to learn to carry your speed, ride smoothly, corner perfectly, and at a very reasonable price tag.
Kawasaki offers the choice of KRT graphics for a small upcharge, otherwise, you have three color choices. Entry-level? For sure it is perfect for new riders, but don’t be shocked when you never want to sell it.
Colors for 2021 include: Metallic Spark Black, Pearl Nightshade Teal / Metallic Spark Black, Metallic Graphite Gray / Metallic Magnetic Dark Gray, Passion Red, KRT Graphics
The 2021 Kawasaki Ninja 400 ABS starts at $4,999 USD / $6,399 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Kawasaki Ninja 400 ABS in one place.
- Price: $4,999 USD / $6,399 CAN
- ABS Brakes
- Back-torque limiting Slipper clutch
- Assist And Slipper Clutch
- New Lightweight Trellis Frame
- Engine: 399cc, liquid-cooled, 4-stroke, DOHC 8-valve parallel twin
- Power: 33.56 kW (45 hp) @ 10,000 RPM
- Torque: 28.0 lb-ft (38 NM) @ 8,000 RPM
- Wet Weight: 166 kg (366 lb)
- Seat Height: 785 mm (30.9 in)
- KTM RC390
- Suzuki GSX250R
- Yamaha YZF-R3
2021 Kawasaki Ninja 400 ABS Specifications
Engine | 399cc, liquid-cooled, 4-stroke, DOHC 8-valve parallel twin |
Power | 45 hp |
Bore x Stroke | 70.0 x 51.8mm |
Compression Ratio | 11.5:1 |
Fuel System | DFI® with dual 32mm throttle bodies |
Lubrication | |
Clutch | |
Transmission | 6-speed |
Final Drive | Sealed chain |
Suspension Front | 41mm hydraulic telescopic fork/4.7 in |
Suspension Rear | Horizontal back-link with adjustable spring preload/5.1 in |
Brakes Front | Single 310mm petal-type disc with 2-piston calipers and ABS |
Brakes Rear | Single 220mm petal-type disc with single-piston caliper and ABS |
Tires Front | 110/70-17 |
Tires Rear | 150/70-17 |
Fuel Tank Capacity | 3.7 |
Color | Pearl Nightshade Teal/Metallic Spark Black |
Ignition | TCBI w/digital advance |
Headlight | LED |
Tail Light | LED |
Overall Length | 78.3 in |
Overall Width | 28 in |
Overall Height | 44.1 in |
Wheelbase | 53.9 in |
Ground Clearance | 5.5 in |
Seat Height | 30.9 in |
Curb Weight | 368.2 lb |
Warranty | 12 months |
Kawasaki Protection Plus | 12 / 24 / 36 / 48 months |
2021 Kawasaki Ninja 400 ABS Features
Assist & Slipper Clutch
Economical Riding Indicator
ABS (ANTI-LOCK BRAKE SYSTEM)
Kawasaki ABS systems use front and rear wheel sensors to constantly monitor wheel speed. Should information from either of the sensors indicate that wheel lock has occurred, the ABS ECU directs the pump in the ABS unit to modulate brake fluid pressure (releasing and reapplying pressure so that traction can be regained) until normal operation resumes. ABS offers rider reassurance that contributes to greater riding enjoyment.ERGO-FIT®
Proper fit is key for rider comfort and control. However, the ideal fit varies from rider to rider, depending on their physical dimensions and riding style.ERGO-FIT® is an interface system designed to allow riders to find their ideal riding position. Various points of the chassis interface (the handlebar, footpegs and seat, etc.) can be adjusted through a combination of interchangeable parts and parts with adjustable positions. This enables a wide range of riders to find a riding position that offers both comfort and control. Feeling at one with their machine, they will be able to experience how Kawasaki machines are fun and rewarding to ride.
*Adjustable parts and their range of adjustability vary by model.
2021 Kawasaki Ninja 400 ABS Photos
2021 Kawasaki Ninja 400 ABS Videos
Kawasaki Official Websites
The post 2021 Kawasaki Ninja 400 ABS [Model Overview] appeared first on webBikeWorld.
