The 2021 Kawasaki Versys 1000 SE is an Adventure Tourer With the Heart of a Sportbike
The 2021 Kawasaki Versys 1000 ABS SE LT+ is the highest spec adventure bike from the venerable Japanese manufacturer. The engine of the bike, a 1,043cc inline-four, is shared with the friendly and easy to ride Ninja 1000 ABS. In both bikes, it produces 118 HP and 75 lb-ft of torque. The biggest difference between the two is engine mapping, where the sportbike is aiming for high revving power, while the adventure tourer wants low-and-mid-range grunt.
Being Kawasaki’s flagship model, it seems that they threw in everything, including a kitchen sink. Cornering stability control, traction control, variable riding and power modes, electronic cruise control, electronically adjustable suspension, and the aforementioned kitchen sink are all standard. Also standard are Kawasaki’s Hard Luggage System with KQR snap-in mount points.
The one new addition to the 2021 model is the inclusion of Kawasaki Skyhook. This is a selectable ride mode, or will automatically activate in certain other ride modes, that if a very rough or bumpy surface is detected, the bike will automatically adjust the suspension to smooth out as much of the rough ride as possible.
The 2021 Kawasaki Versys 1000 ABS LT SE+ starts at $18,199 USD / $20,099 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Kawasaki Versys 1000 SE LT+ in one place.
- Price: $18,199 USD / $20,099 CAD
- Very few options as most items come standard on this flagship model
- Sportbike-derived inline-four gives excellent power and torque
- Kawasaki Skyhook ride system
- Engine Type: 1,043cc 4-stroke, DOHC, 16-valve, liquid-cooled inline-four
- Horsepower: 118 HP
- Torque: 75 lb-ft
- Wet Weight: 567 lbs (257 kg)
- Seat Height: 33.1 inches (840 mm)
- KTM 1290 Super Adventure R
- Yamaha Super Tenere ES
- Suzuki V-Strom 1050XT
2021 Kawasaki Versys 1000 SE LT+ Specifications
Engine | 1,043cc 4-stroke, DOHC, 16-valve, liquid-cooled inline-four |
Power | 118 hp |
Bore x Stroke | 77.0 x 56.0mm |
Compression Ratio | 10.3:1 |
Fuel System | DFI® with 38mm Keihin ETV throttle bodies (4) |
Lubrication | |
Clutch | |
Transmission | 6-speed, return shift, Kawasaki Quick Shifter (KQS) |
Final Drive | Sealed chain |
Suspension Front | 43mm inverted fork with KECS-controlled rebound and compression damping, manual spring preload adjustability and top-out springs/5.9 in |
Suspension Rear | Horizontal back-link New Uni-Trak®, BFRC gas charged shock with piggyback reservoir, KECS-controlled compression and rebound damping electronically-adjustable spring preload/5.9 in |
Brakes Front | Dual 310mm petal-style discs with four-piston calipers, ABS |
Brakes Rear | Single 250mm petal disc with single-piston caliper, ABS |
Tires Front | 120/70 ZR-17 |
Tires Rear | 180/55 ZR-17 |
Fuel Tank Capacity | 5.5 gal |
Color | Pearl Storm Gray/Metallic Diablo Black/Metallic Flat Spark Black |
Ignition | TCBI with electronic advance |
Headlight | LED |
Tail Light | LED |
Overall Length | 89.4 in |
Overall Width | 37.4 in |
Overall Height | 58.7 in/60.2 in (windshield down/up) |
Wheelbase | 59.8 in |
Ground Clearance | 5.9 in |
Seat Height | 33.1 in |
Curb Weight | 566.7 lb (+ Saddlebags, Hand Guards, & Hardware approx. 20 lb.) |
Warranty | 12 Month Limited Warranty |
Kawasaki Protection Plus | 12 / 24 / 36 / 48 months |
2021 Kawasaki Versys 1000 SE LT+ Features
Assist & Slipper Clutch
Economical Riding Indicator
Dual Throttle Valves
Late-model sport bikes often use large-bore throttle bodies to generate high levels of power. However, with large diameter throttles, when a rider suddenly opens the throttle, the unrestricted torque response can be strong. Dual throttle valve technology was designed to tame engine response while contributing to performance.On models with dual throttle valves, there are two throttle valves per cylinder: in addition to the main valves, which are physically linked to the throttle grip and controlled by the rider, a second set of valves, opened and closed by the ECU, precisely regulates intake airflow to ensure a natural, linear response. With the air passing through the throttle bodies becoming smoother, combustion efficiency is improved and power is increased.
Electronic Cruise Control
Electronic Cruise Control allows a desired speed (engine rpm) to be maintained with the simple press of a button. Once activated, the rider does not have to constantly apply the throttle. This reduces stress on the right hand when traveling long distances, enabling relaxed cruising and contributing to a high level of riding comfort.Electronic Throttle Valves
Kawasaki’s fully electronic throttle actuation system enables the ECU to control the volume of both the fuel (via fuel injectors) and the air (via throttle valves) delivered to the engine. Ideal fuel injection and throttle valve position results in smooth, natural engine response and the ideal engine output. The system also makes a significant contribution to reduced emissions.Electronic throttle valves also enable more precise control of electronic engine management systems like S-KTRC and KTRC, and allow the implementation of electronic systems like KLCM, Kawasaki Engine Brake Control, and Electronic Cruise Control.
KTRC (Kawasaki Traction Control)
KTRC, Kawasaki’s advanced traction control system provides both enhanced sport riding performance and the peace of mind to negotiate slippery surfaces with confidence. Multiple rider-selectable modes (the number of modes varies by model) offer progressively greater levels of intrusion to suit the riding situation and rider preference.Less intrusive modes maintain optimum traction during cornering. Designed with sport riding in mind, they facilitate acceleration out of corners by maximizing forward drive from the rear wheel. And because Kawasaki’s sophisticated software bases its dynamic analysis on the chassis’ orientation relative to the track surface (rather than relative to a horizontal plane), it is able to take into account corner camber, gradient, etc., and adapt accordingly.
POWER MODES
Models equipped with multiple Power Modes offer riders an easily selectable choice of engine power delivery to suit riding conditions or preference. In addition to Full Power mode, one (Low) or two (Middle, Low) alternate mode(s) in which maximum power is limited and throttle response is milder are provided.Smartphone Connectivity
Clever technology enables riders to connect to their motorcycle wirelessly. Using the smartphone application “RIDEOLOGY THE APP,” a number of instrument functions can be accessed, contributing to an enhanced motorcycling experience. Vehicle information (such as the odometer, fuel gauge, maintenance schedule, etc) can be viewed on the smartphone. Riding logs (varies by model, but may include GPS route, gear position, rpm, and other information) can be viewed on the smartphone. When connected, telephone (call, mail) notices are displayed on the instrument panel. Riders can also make changes to their motorcycle’s instrument display settings (preferred units, clock and date setting, etc) via the smartphone. And on certain models, it is even possible to check and adjust vehicle settings (such as Rider Mode, electronic rider support features, and payload settings) using the smartphone.ABS (Anti-lock Brake System)
Kawasaki ABS systems use front and rear wheel sensors to constantly monitor wheel speed. Should information from either of the sensors indicate that wheel lock has occurred, the ABS ECU directs the pump in the ABS unit to modulate brake fluid pressure (releasing and reapplying pressure so that traction can be regained) until normal operation resumes. ABS offers rider reassurance that contributes to greater riding enjoyment.KIBS (Kawasaki Intelligent anti-lock Brake System)
Kawasaki developed KIBS to take into account the particular handling characteristics of supersport motorcycles, ensuring highly efficient braking with minimal intrusion during sport riding. It is the first mass-production brake system to link the ABS ECU (Electronic Control Unit) and engine ECU.In addition to front and rear wheel speed, KIBS monitors front brake caliper hydraulic pressure, throttle position, engine speed, clutch actuation and gear position. This diverse information is analyzed to determine the ideal front brake hydraulic pressure. Through precise control, hydraulic pressure is modulated in much smaller increments than with standard ABS systems. The system limits rear wheel lift under heavy braking and takes downshifting into account while braking, allowing the rider to manage the rear brake. And because of the finer control, kickback to the brake lever is minimal, resulting in a very natural feeling.
KECS (Kawasaki Electronic Control Suspension)
KECS adapts to road and riding conditions in real time, providing the ideal amount of damping called for by electronically adjusting damping to suit vehicle speed and suspension stroke speed. Deceleration is also taken into account, which allows the system to help manage pitching that may occur during braking.Control via solenoid valve with direct actuation enables an extremely quick reaction time, making KECS ideal for sport riding applications, where natural feeling is crucial to feeling at one with the bike. Built-in stroke sensors on both the fork and rear shock provide real-time stroke speed and compression information. Input from the sensor coils to the KECS ECU is complemented by information provided by the IMU (acceleration/deceleration) and the FI ECU (vehicle speed). The KECS ECU then directs current to the solenoids to adjust damping as required by the situation.
Selectable modes allow riders to choose softer or firmer base settings.
Horizontal Back-link Rear Suspension
Compared to the Kawasaki traditional Uni-Trak® rear suspension, which mounts the shock unit vertically, with Horizontal Back-link Rear Suspension, the shock unit is almost horizontal. The original Kawasaki suspension arrangement locates the shock unit very close to the bike’s center of gravity, greatly contributing to mass centralization. And because there is no linkage or shock unit protruding beneath the swingarm, this frees up space for a larger exhaust pre-chamber (an exhaust expansion chamber situated just upstream of the silencer). With a larger pre-chamber, silencer volume can be reduced, and heavy exhaust components can be concentrated closer to the center of the bike, further contributing to mass centralization. The result is greatly improved handling.A secondary benefit is that the shock unit is placed far away from exhaust heat. Because it is more difficult for heat from the exhaust system to adversely affect suspension oil and gas pressure, suspension performance is more consistent.
2021 Kawasaki Versys 1000 SE LT+ Photos
2021 Kawasaki Versys 1000 SE LT+ Videos
N/A
Kawasaki Official Websites
The post 2021 Kawasaki Versys 1000 SE LT+ [Model Overview] appeared first on webBikeWorld.
