2021 Kawasaki Z H2 [Model Overview]
The 2021 Kawasaki Z H2: Supercharged Hypernaked​
The world of Hypernaked motorcycles has typically belonged to just a select small group of manufacturers. The Japanese-made, Kawasaki Z H2 is a sniper shot at that group. Honestly, it’s dead on the mark.
Since blowing the collective minds of the two-wheeled universe with Kawasaki’s introduction of their 998cc, liquid-cooled, supercharged, 4-stroke DOHC 16-valve in-line four engine, it has slowly been deployed across the 2021 Kawasaki lineup. Configured in Hypernaked form, it churns out 200 hp at 10,500 rpm and 101 lb.-ft. of torque at 8,500 rpm. Yes…yes this is bonkers level power, and that makes it just right.
The Z H2 runs its own unique geometry of trellis frame, then wrapped in a unique asymmetrical sugomi design. Naturally, Kawasaki has fitted the Z H2 with every electronic rider aid they can deliver from its latest version IMU (Inertial Measurement Unit), all easily accessed through the TFT display.
Colors for 2021 — Metallic Diablo Black / Metallic Flat Spark Black
The 2021 Kawasaki Z H2 starts at $17,500 USD / $19,699 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Kawasaki Z H2 in one place.
2021 Kawasaki Z H2
  • Price: $17,500 USD / $19,699 CAD
    • High-Performance Showa Suspension Components
    • Brembo® Monobloc Brake Calipers
    • Electronic Cruise Control
    • Integrated Riding Modes
    • Smartphone Connectivity via RIDEOLOGY THE APP
Main Specs​
  • Engine: 4-stroke, In-Line Four, DOHC, 16-valve, liquid-cooled
  • Power: 104.5kW (200hp)@10,500 RPM
  • Torque: 101 lb-ft (111 NM) @ 8,500 RPM
  • Wet Weight: 239 kg (527 lb)
  • Seat Height: 830 mm (32.7 in)
Competitors​
2021 Kawasaki Z H2
2021 Kawasaki Z H2 Specifications​
Engine998cc, 4-stroke, 4-cylinder, DOHC, 4-valve, liquid-cooled, supercharged
Power200 hp
Bore x Stroke76.0 x 55.0mm
Compression Ratio
11.2:1
Fuel SystemDFI, 40mm Throttle Bodies
Lubrication
Clutch
Transmission6-speed dog-ring, return shift
Final DriveSealed chain
Suspension FrontShowa SFF-BP Fork with Adjustable Compression and Rebound Damping, Spring Preload Adjustability
Suspension RearUni-Trak®, Showa Gas-Charged Shock with Adjustable Compression and Rebound Damping, Preload Adjustability
Brakes FrontDual 320mm Disc w/Radial-mount Brembo M4.32 Calipers, KIBS
Brakes Rear
Single 250mm disc with single-piston caliper, KIBS
Tires Front120/70-17
Tires Rear190/55-17
Fuel Tank Capacity5.0 gal
Color
Metallic Diablo Black/Metallic Flat Spark Black
IgnitionTCBI w/ Digital Advance
HeadlightLED
Overall Length82.1 in
Overall Width31.9 in
Overall Height44.5 in
Wheelbase57.3 in
Ground Clearance5.5 in
Seat Height32.7 in
Curb Weight527.0 lb
Warranty12 Month Limited Warranty
Kawasaki Protection Plus12 / 24 / 36 / 48 months
2021 Kawasaki Z H2
2021 Kawasaki Z H2 Features​
Assist & Slipper Clutch​
Electronic Cruise Control​
Electronic Cruise Control allows a desired speed (engine rpm) to be maintained with the simple press of a button. Once activated, the rider does not have to constantly apply the throttle. This reduces stress on the right hand when traveling long distances, enabling relaxed cruising and contributing to a high level of riding comfort.
Electronic Throttle Valves​
Kawasaki’s fully electronic throttle actuation system enables the ECU to control the volume of both the fuel (via fuel injectors) and the air (via throttle valves) delivered to the engine. Ideal fuel injection and throttle valve position results in smooth, natural engine response and the ideal engine output. The system also makes a significant contribution to reduced emissions.
Electronic throttle valves also enable more precise control of electronic engine management systems like S-KTRC and KTRC, and allow the implementation of electronic systems like KLCM, Kawasaki Engine Brake Control, and Electronic Cruise Control.
KLCM (Kawasaki Launch Control Mode)​
Designed to assist riders by optimizing acceleration from a stop, KLCM electronically manages engine output to minimize wheel spin when moving off. With the clutch lever pulled in and the system activated, engine speed is limited to a determined speed while the rider holds the throttle open. Once the rider releases the clutch lever to engage the clutch, engine speed is allowed to increase, but power is regulated to minimize wheel spin and help keep the front wheel on the ground. The system disengages automatically once a predetermined speed has been reached, or when the rider shifts into third gear. Depending on the model, riders can choose from multiple modes, each offering a progressively greater level of intrusion.
KCMF (Kawasaki Cornering Management Function)​
Using the latest evolution of Kawasaki’s advanced modeling software and feedback from a compact IMU (Inertial Measurement Unit) that gives an even clearer real-time picture of chassis orientation, KCMF monitors engine and chassis parameters throughout the corner – from entry, through the apex, to corner exit – modulating brake force and engine power to facilitate smooth transition from acceleration to braking and back again, and to assist riders in tracing their intended line through the corner. The systems that KCMF oversees vary by model, but may include:
• S-KTRC/KTRC (including traction management and wheel lift management)
• KLCM (including traction management and wheel lift management)
– Designed to optimize acceleration from a stop
• KIBS (including pitching management and corner braking management)
• Kawasaki Engine Brake Control
POWER MODES​
Models equipped with multiple Power Modes offer riders an easily selectable choice of engine power delivery to suit riding conditions or preference. In addition to Full Power mode, one (Low) or two (Middle, Low) alternate mode(s) in which maximum power is limited and throttle response is milder are provided.
Smartphone Connectivity​
Clever technology enables riders to connect to their motorcycle wirelessly. Using the smartphone application “RIDEOLOGY THE APP,” a number of instrument functions can be accessed, contributing to an enhanced motorcycling experience. Vehicle information (such as the odometer, fuel gauge, maintenance schedule, etc) can be viewed on the smartphone. Riding logs (varies by model, but may include GPS route, gear position, rpm, and other information) can be viewed on the smartphone. When connected, telephone (call, mail) notices are displayed on the instrument panel. Riders can also make changes to their motorcycle’s instrument display settings (preferred units, clock and date setting, etc) via the smartphone. And on certain models, it is even possible to check and adjust vehicle settings (such as Rider Mode, electronic rider support features, and payload settings) using the smartphone.
ABS (Anti-lock Brake System)​
2021 Kawasaki Z H2 Photos​
2021 Kawasaki Z H2
2021 Kawasaki Z H2
2021 Kawasaki Z H2
2021 Kawasaki Z H2
2021 Kawasaki Z H2 Videos​
Kawasaki Official Websites​
The post 2021 Kawasaki Z H2 [Model Overview] appeared first on webBikeWorld.
