2021 Kawasaki Z H2 SE [Model Overview]
The 2021 Kawasaki Z H2 SE: Supercharged Hypernaked With Extra Sauce​
Boy, what a predicament the engineers found themselves in when looking at the 2021 Kawasaki lineup, they just had to add a little extra sauce somewhere. That “somewhere” was the all-new for 2021 Z H2 SE. Wait a minute, wasn’t the Z H2 already amazing enough? Of course it was, that’s why it needed just a bit extra.
How do you add any extra to the Japanese-made Hypernaked, you ask? Simple, you upgrade the braking system to the Brembo Stylema system, then include the Kawasaki Electronic Control Suspension (KECS) with Showa Skyhook technology. That’s on top of the already incredible standard equipment found on the Z H2.
No changes were made to the 998cc, liquid-cooled, supercharged, 4-stroke DOHC 16-valve in-line four engine from the Kawasaki Z H2, it churns out 200 hp at 10,500 rpm and 101 lb.-ft. of torque at 8,500 rpm.
There is definite legitimacy to Kawasaki’s claim that the Z H2 SE is the King of the Hypernakeds.
Colors for 2021 — Metallic Diablo Black / Golden Blazed Green
The 2021 Kawasaki Z H2 SE starts at $19,700 USD / $23,099 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Kawasaki Z H2 SE in one place.
  • Price: $19,700 USD / $23,099 CAD
    • NEW Kawasaki Electronic Control Suspensions (KECS) with Showa Skyhook EERA Technology
    • NEW Brembo® Stylema Front Calipers
    • Stainless Steel Braided Brake Lines
    • Integrated Riding Modes
    • Smartphone Connectivity via RIDEOLOGY THE APP
Main Specs​
  • Engine: 4-stroke, In-Line Four, DOHC, 16-valve, liquid-cooled
  • Power: 104.5kW (200hp)@10,500 RPM
  • Torque: 101 lb-ft (111 NM) @ 8,500 RPM
  • Wet Weight: 240 kg (529 lb)
  • Seat Height: 830 mm (32.7 in)
Competitors​
2021 Kawasaki Z H2 SE Specifications​
Engine998cc, 4-stroke, 4-cylinder, DOHC, 4-valve, liquid-cooled, supercharged
Power200 hp
Bore x Stroke76.0 x 55.0mm
Compression Ratio
11.2:1
Fuel SystemDFI, 40mm Throttle Bodies
Lubrication
Clutch
Transmission6-speed dog-ring, return shift
Final DriveSealed chain
Suspension FrontShowa SFF-BP Fork with Adjustable Compression and Rebound Damping, Spring Preload Adjustability
Suspension RearUni-Trak®, Showa Gas-Charged Shock with Adjustable Compression and Rebound Damping, Preload Adjustability
Brakes FrontDual 320mm Disc w/Radial-mount Brembo M4.32 Calipers, KIBS
Brakes Rear
Single 260mm disc with single-piston caliper, KIBS
Tires Front120/70-17
Tires Rear190/55-17
Fuel Tank Capacity5.0 gal
Color
Golden Blazed Green/Metallic Diablo Black
IgnitionTCBI w/ Digital Advance
HeadlightLED
Overall Length82.1 in
Overall Width31.9 in
Overall Height44.5 in
Wheelbase57.3 in
Ground Clearance5.5 in
Seat Height32.7 in
Curb Weight531.4 lb
Warranty12 Month Limited Warranty
Kawasaki Protection Plus12 / 24 / 36 / 48 months
2021 Kawasaki Z H2 SE Features​
Assist & Slipper Clutch​
Economical Riding Indicator​
Electronic Cruise Control​
Electronic Cruise Control allows a desired speed (engine rpm) to be maintained with the simple press of a button. Once activated, the rider does not have to constantly apply the throttle. This reduces stress on the right hand when traveling long distances, enabling relaxed cruising and contributing to a high level of riding comfort.
Electronic Throttle Valves​
Kawasaki’s fully electronic throttle actuation system enables the ECU to control the volume of both the fuel (via fuel injectors) and the air (via throttle valves) delivered to the engine. Ideal fuel injection and throttle valve position results in smooth, natural engine response and the ideal engine output. The system also makes a significant contribution to reduced emissions.
Electronic throttle valves also enable more precise control of electronic engine management systems like S-KTRC and KTRC, and allow the implementation of electronic systems like KLCM, Kawasaki Engine Brake Control, and Electronic Cruise Control.
KLCM (Kawasaki Launch Control Mode)​
Designed to assist riders by optimizing acceleration from a stop, KLCM electronically manages engine output to minimize wheel spin when moving off. With the clutch lever pulled in and the system activated, engine speed is limited to a determined speed while the rider holds the throttle open. Once the rider releases the clutch lever to engage the clutch, engine speed is allowed to increase, but power is regulated to minimize wheel spin and help keep the front wheel on the ground. The system disengages automatically once a predetermined speed has been reached, or when the rider shifts into third gear. Depending on the model, riders can choose from multiple modes, each offering a progressively greater level of intrusion.
KCMF (Kawasaki Cornering Management Function)​
Using the latest evolution of Kawasaki’s advanced modeling software and feedback from a compact IMU (Inertial Measurement Unit) that gives an even clearer real-time picture of chassis orientation, KCMF monitors engine and chassis parameters throughout the corner – from entry, through the apex, to corner exit – modulating brake force and engine power to facilitate smooth transition from acceleration to braking and back again, and to assist riders in tracing their intended line through the corner. The systems that KCMF oversees vary by model, but may include:
• S-KTRC/KTRC (including traction management and wheel lift management)
• KLCM (including traction management and wheel lift management)
– Designed to optimize acceleration from a stop
• KIBS (including pitching management and corner braking management)
• Kawasaki Engine Brake Control
POWER MODES​
Models equipped with multiple Power Modes offer riders an easily selectable choice of engine power delivery to suit riding conditions or preference. In addition to Full Power mode, one (Low) or two (Middle, Low) alternate mode(s) in which maximum power is limited and throttle response is milder are provided.
Smartphone Connectivity​
Clever technology enables riders to connect to their motorcycle wirelessly. Using the smartphone application “RIDEOLOGY THE APP,” a number of instrument functions can be accessed, contributing to an enhanced motorcycling experience. Vehicle information (such as the odometer, fuel gauge, maintenance schedule, etc) can be viewed on the smartphone. Riding logs (varies by model, but may include GPS route, gear position, rpm, and other information) can be viewed on the smartphone. When connected, telephone (call, mail) notices are displayed on the instrument panel. Riders can also make changes to their motorcycle’s instrument display settings (preferred units, clock and date setting, etc) via the smartphone. And on certain models, it is even possible to check and adjust vehicle settings (such as Rider Mode, electronic rider support features, and payload settings) using the smartphone.
ABS (Anti-lock Brake System)​
KIBS (Kawasaki Intelligent anti-lock Brake System)​
Kawasaki developed KIBS to take into account the particular handling characteristics of supersport motorcycles, ensuring highly efficient braking with minimal intrusion during sport riding. It is the first mass-production brake system to link the ABS ECU (Electronic Control Unit) and engine ECU.
In addition to front and rear wheel speed, KIBS monitors front brake caliper hydraulic pressure, throttle position, engine speed, clutch actuation and gear position. This diverse information is analyzed to determine the ideal front brake hydraulic pressure. Through precise control, hydraulic pressure is modulated in much smaller increments than with standard ABS systems. The system limits rear wheel lift under heavy braking and takes downshifting into account while braking, allowing the rider to manage the rear brake. And because of the finer control, kickback to the brake lever is minimal, resulting in a very natural feeling.
KECS (Kawasaki Electronic Control Suspension)​
KECS adapts to road and riding conditions in real time, providing the ideal amount of damping called for by electronically adjusting damping to suit vehicle speed and suspension stroke speed. Deceleration is also taken into account, which allows the system to help manage pitching that may occur during braking.
Control via solenoid valve with direct actuation enables an extremely quick reaction time, making KECS ideal for sport riding applications, where natural feeling is crucial to feeling at one with the bike. Built-in stroke sensors on both the fork and rear shock provide real-time stroke speed and compression information. Input from the sensor coils to the KECS ECU is complemented by information provided by the IMU (acceleration/deceleration) and the FI ECU (vehicle speed). The KECS ECU then directs current to the solenoids to adjust damping as required by the situation.
Selectable modes allow riders to choose softer or firmer base settings.
IMU-Enhanced Chassis Orientation Awareness​
The strength of Kawasaki’s cutting-edge electronics has always been the highly sophisticated programming that, using minimal hardware, gives the ECU an accurate real-time picture of what the chassis is doing. Kawasaki’s proprietary dynamic modeling program makes skillful use of the magic formula tire model as it examines changes in multiple parameters, enabling it to take into account changing road and tire conditions.
The addition of an IMU (Inertial Measurement Unit) enables inertia along 6 DOF (degrees of freedom) to be monitored. Acceleration along longitudinal, transverse and vertical axes, plus roll rate and pitch rate are measured. The yaw rate is calculated by the ECU using Kawasaki original software. This additional feedback contributes to an even clearer real-time picture of chassis orientation, enabling even more precise management for control at the limit.
With the addition of the IMU and the latest evolution of Kawasaki’s advanced modeling software, Kawasaki’s electronic engine and chassis management technology takes the step to the next level – changing from setting-type and reaction-type systems to feedback-type systems – to deliver even greater levels of riding excitement.
2021 Kawasaki Z H2 SE Photos​
2021 Kawasaki Z H2 SE Videos​
Kawasaki Official Websites​
The post 2021 Kawasaki Z H2 SE [Model Overview] appeared first on webBikeWorld.
