2021 Kawasaki Z125 Pro [Model Overview]
The 2021 Kawasaki Z125 Pro: Calling Your Inner Hooligan​
Well hello inner child, you want to come out and get hooligan crazy? Sounds like a blast, and here is the perfect hooligan accessory, the made in Japan Kawasaki Z125 Pro. Let’s be honest, our inner child is for sure a pro-level hooligan.
I will admit, I use the term hooligan loosely, but one look at the Z125 Pro and you begin smiling knowing full well this machine will be a blast to ride. The small wheels can fool one into thinking this is a kid’s bike, but the seat height is 805 mm (31.7 in), normal sportbike size. Kawasaki Motorcycles has made this little bike just right for everyone from junior to Grandma to put a leg over. The ergonomics are suitable for all but the very tall. Over 6’2” and you will find your knees bumping the handlebars on tight turns.
Yes, this is the smallest motorcycle in the 2021 Kawasaki lineup, but Kawasaki treats it very seriously. The 125cc Single makes 8.3 HP, and that’s just fine with the fun factor it packs. Above the 12” cast wheels and grippy sport rubber, there is a proper high tensile steel frame and a well-sorted suspension with rear preload adjustment.
The combined analog tach and digital display even has a gear indicator, very handy. It has been built to excel at urban commuting. Cheap to buy, insure, and fuel, it takes no effort to justify its place in your garage. It will turn the daily run to the office into an exhilarating little rip, and you will likely not even find yourself exceeding the speed limit.
Colors for 2021: Metallic Spark Black, Pearl Nightshade Teal.
The 2021 Kawasaki Z125 Pro starts at $3,299 USD / $3,599 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Kawasaki Z125 Pro in one place.
  • Price: $3,299 USD / $3,599 CAD
    • Fuel Injected
    • Electric Starter
    • Offset laydown single-shock with 4-way preload adjust
    • Sharp Styling
Main Specs​
  • Engine: 125cc, air-cooled, 4-stroke, SOHC 2-valve single
  • Power: 6.2 kW (8.3 hp) @ 7800 RPM RPM
  • Torque: 7.1 lb-ft (9.63 NM) @ 6,000 RPM
  • Wet Weight: 102 kg (225 lb)
  • Seat Height: 805 mm (31.7 in)
Competitors​
  • Honda GROM
  • Benelli TNT 135
2021 Kawasaki Z125 Pro Specifications​
Engine125cc, air-cooled, 4-stroke, SOHC 2-valve single
Power8.3 hp
Bore x Stroke56.0 x 50.6mm
Compression Ratio
9.8:1
Fuel SystemDFI, with 24mm throttle bodies
Lubrication
Clutch
Transmission4-speed, return shift
Final DriveSealed chain
Suspension FrontTelescopic fork/3.9 in
Suspension RearSwingarm, single shock/4.1 in
Brakes FrontSingle 200mm petal-style disc
Brakes Rear
Single 184mm petal-style disc
Tires Front100/90-12
Tires Rear120/70-12
Fuel Tank Capacity2.0 gal
Color
Pearl Nightshade Teal, Metallic Flat Spark Black
IgnitionTCBI with electronic advance
HeadlightLED
Overall Length66.9 in
Overall Width29.5 in
Overall Height39.6 in
Wheelbase46.3 in
Ground Clearance6.1 in
Seat Height31.7 in
Curb Weight224.8 lb
Warranty12 Month Limited Warranty
Kawasaki Protection Plus12 / 24 / 36 / 48 months
2021 Kawasaki Z125 Pro Features​
Smart Regulator​
The electric power used for lights and fuel pumps is produced by a bike’s generator. The regulator takes this power and maintains the voltage at a constant level. The Smart Regulator Kawasaki developed for small-displacement models features a built-in microprocessor, enabling control of the charging function and the headlamp.
This control enables charging to be done even at idling speed, when the voltage generated is at its lowest, (provided conditions are standard and no accessories are being used), which exceeds the ability of current regulators. Additionally, once the battery is fully charged, or when the throttle is opened quickly, the smart regulator turns the charging function off, instantly reducing the electrical resistance of the generator. This enables the energy used to drive the generator to be saved – usually a big loss, especially for a small-displacement engine. By minimizing power loss, the Smart Regulator contributes to increased fuel efficiency.
2021 Kawasaki Z125 Pro Photos​
2021 Kawasaki Z125 Pro Videos​
Kawasaki Official Websites​
The post 2021 Kawasaki Z125 Pro [Model Overview] appeared first on webBikeWorld.
