2021 Kawasaki Z650 [Model Overview]
The 2021 Kawasaki Z650: Riding Naked!​
The 2021 Kawasaki Z650 fills the middleweight role in the naked bike battle for Team Green. The naked segment is rapidly growing, and this Japanese-made 649cc parallel-twin offers a well-sorted combination of styling, handling, and power.
The Z650 benefits from shared components used across the 2021 Kawasaki lineup. The 67 HP engine is perfectly suited to this Z format. The rider triangle places the rider “in” rather than “on top of” the bike for a feeling of confident connected handling. This Kawasaki bike includes ABS braking, Assist & Slipper clutch, and Bluetooth smartphone connectivity via the Rideology App.
Overall the design team delivers a sharp looking bike with a bold front face and minimalist bodywork. I find the look to be clean, with a good amount of streetfighter aggressive.
Colors for 2021 include — Pearl Blizzard White/Metallic Spark Black, Metallic Spark Black/Metallic Flat Spark Black, and Metallic Spark Black
The 2021 Kawasaki Z650 starts at $7,249 USD / $8,499 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Kawasaki Z650 in one place.
2021 Kawasaki Z650
  • Price: $7,249 USD / $8,499 CAD
    • ABS Brakes
    • Smartphone Connectivity
    • Assist And Slipper Clutch
    • Twin LED headlights
Main Specs​
  • Engine: 649cc, liquid-cooled, 4-stroke, DOHC 8-valve parallel twin
  • Power: 50 kW (67 hp) @ 8,000 RPM
  • Torque: 47.0 lb-ft (63.7 NM) @ 6,700 RPM
  • Wet Weight: 187 kg (412 lb)
  • Seat Height: 790 mm (31.1 in)
Competitors​
  • Honda CB650R
  • Suzuki SV650A
  • Yamaha MT-07
2021 Kawasaki Z650
2021 Kawasaki Z650 Specifications​
Engine649cc, liquid-cooled, 4-stroke, DOHC 8-valve parallel twin
Power67 hp
Bore x Stroke83.0 x 60.0mm
Compression Ratio
10.8:1
Fuel SystemDFI® with Keihin 36mm throttle bodies
Lubrication
Clutch
Transmission6-speed, return shift
Final DriveSealed chain
Suspension FrontTelescopic fork/4.9 in
Suspension RearHorizontal back-link with adjustable preload, swingarm/5.1 in
Brakes FrontDual 300mm petal-style discs with two-piston calipers, ABS
Brakes Rear
Single 220mm petal-style disc, ABS
Tires Front110/70-17
Tires Rear150/70-17
Fuel Tank Capacity4.0 gal
Color
IgnitionTCBI with electronic advance
HeadlightLED
Overall Length81.3 in
Overall Width30.1 in.
Overall Height41.9 in
Wheelbase55.5 in
Ground Clearance5.1 in
Seat Height31.1 in
Curb Weight412.3 lb
Warranty12 Month Limited Warranty
Kawasaki Protection Plus12 / 24 / 36 / 48 months
2021 Kawasaki Z650
2021 Kawasaki Z650 Features​
Assist & Slipper Clutch​
Dual Throttle Valves​
Economical Riding Indicator​
Smartphone Connectivity​
Clever technology enables riders to connect to their motorcycle wirelessly. Using the smartphone application “RIDEOLOGY THE APP,” a number of instrument functions can be accessed, contributing to an enhanced motorcycling experience. Vehicle information (such as the odometer, fuel gauge, maintenance schedule, etc) can be viewed on the smartphone. Riding logs (varies by model, but may include GPS route, gear position, rpm, and other information) can be viewed on the smartphone. When connected, telephone (call, mail) notices are displayed on the instrument panel. Riders can also make changes to their motorcycle’s instrument display settings (preferred units, clock and date setting, etc) via the smartphone. And on certain models, it is even possible to check and adjust vehicle settings (such as Rider Mode, electronic rider support features, and payload settings) using the smartphone.
ABS (Anti-lock Brake System)​
Horizontal Back-link Rear Suspension​
Compared to the Kawasaki traditional Uni-Trak® rear suspension, which mounts the shock unit vertically, with Horizontal Back-link Rear Suspension, the shock unit is almost horizontal. The original Kawasaki suspension arrangement locates the shock unit very close to the bike’s center of gravity, greatly contributing to mass centralization. And because there is no linkage or shock unit protruding beneath the swingarm, this frees up space for a larger exhaust pre-chamber (an exhaust expansion chamber situated just upstream of the silencer). With a larger pre-chamber, silencer volume can be reduced, and heavy exhaust components can be concentrated closer to the center of the bike, further contributing to mass centralization. The result is greatly improved handling.
A secondary benefit is that the shock unit is placed far away from exhaust heat. Because it is more difficult for heat from the exhaust system to adversely affect suspension oil and gas pressure, suspension performance is more consistent.
2021 Kawasaki Z650 Photos​
2021 Kawasaki Z650
2021 Kawasaki Z650
2021 Kawasaki Z650
2021 Kawasaki Z650
2021 Kawasaki Z650 Videos​
Kawasaki Official Websites​
The post 2021 Kawasaki Z650 [Model Overview] appeared first on webBikeWorld.
