2021 Kawasaki Z900RS Cafe [Model Overview]
The 2021 Kawasaki Z900RS Cafe: Retro cafe vibes, modern cafe technology​
Kawasaki’s 2021 Z900RS Cafe is a throwback to the lightweight, four-cylinder road rockets that raced between cafe stops in the 1960s and 1970s. A lowered seat height, raked back clip ons, and the aerodynamic headlight cowling to tuck down behind all speak the language of days gone by, but the 948cc inline-four is anything but, putting down a respectable 110 HP and 73 lb-ft of torque. The Z900 is the perfect retro-style bike in Kawasaki’s 2021 lineup.
As usual, Kawasaki Motorcycles does not skimp out on the racer-like underpinnings of the Z900RS Cafe. 36mm throttle bodies gulp in air to mix with the fuel from the injectors, producing a purring growl at idle. Twist open the throttle, and you’ll hear the distinct, throaty roar that the old Kawasaki bikes are known for.
Japan’s big four has truly embraced heritage bikes, with at least one being made by each manufacturer. We, the riding public, are lucky that Kawasaki makes one that can be ridden either as a comfortable sport tourer, or a tucked down cafe racer, and be good at both in equal measure.
The 2021 Kawasaki Z900RS Cafe starts at $11,899 USD and is at the time of this article, not available in Canada.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Kawasaki Z900RS Cafe in one place.
  • Price: $11,899 USD
    • Retro styling, modern technology
    • Dual-zone ABS
    • Tuned exhaust to sound like the bikes of yesteryear
Main Specs​
  • Engine Type: 948cc 4-stroke, DOHC, 16-valve, liquid-cooled inline-four
  • Horsepower: 110 HP
  • Torque: 73 lb-ft
  • Wet Weight: 476 lbs (216 kg)
  • Seat Height: 32.3 inches (820 mm)
Competitors​
2021 Kawasaki Z900RS Cafe Specifications​
Engine948cc 4-stroke, DOHC, 16-valve, liquid-cooled inline-four
Power110 HP
Bore x Stroke73.4 x 56.0mm
Compression Ratio
10.8:1
Fuel SystemDFI® with Keihin 36mm throttle bodies
Lubrication
Clutch
Transmission6-speed, return shift
Final DriveSealed chain
Suspension FrontInverted telescopic fork with (13-way) adjustable compression and rebound (11-way) damping, spring preload (15-turn)/4.7
Suspension RearHorizontal back-link swingarm with stepless adjustable rebound damping and spring preload/5.5 in
Brakes FrontDual disc ABS
Brakes Rear
Single disc ABS
Tires Front120/70 ZR17
Tires Rear180/55 ZR17
Fuel Tank Capacity4.5 gal
Color
Pearl Storm Gray
IgnitionTCBI with electronic advance
HeadlightLED
Overall Length82.7 in
Overall Width33.3 in
Overall Height46.9 in
Wheelbase57.9 in
Ground Clearance5.1 in
Seat Height32.3 in
Curb Weight 476.3 lb
Warranty12 Months
Kawasaki Protection Plus12, 24, 36 or 48 months
2021 Kawasaki Z900RS Cafe Features​
Assist & Slipper Clutch​
Dual Throttle Valves​
Economical Riding Indicator​
(Kawasaki Traction Control)​
Sound Tuning​
Kawasaki has long had a reputation for building great-sounding bikes – a characteristic inherent in the Kawasaki engine architecture – but it is only recently that effort has been put into crafting a specific auditory experience through careful sound tuning of either the intake or exhaust system.
Designed specifically to allow riders to enjoy their motorcycles aurally as well as physically, the carefully crafted auditory notes can be the key components of the street riding exhilaration offered by models that have benefitted from sound tuning. Sound tuning can include conducting sound research, designing intake and exhaust system components based on an acoustic test carried out in a sound room, and careful consideration of every detail of a system’s components to ensure a balance of performance and the desired sound.
ABS (Anti-lock Brake System)​
ERGO-FIT®​
Proper fit is key for rider comfort and control. However, the ideal fit varies from rider to rider, depending on their physical dimensions and riding style.
ERGO-FIT® is an interface system designed to allow riders to find their ideal riding position. Various points of the chassis interface (the handlebar, footpegs and seat, etc.) can be adjusted through a combination of interchangeable parts and parts with adjustable positions. This enables a wide range of riders to find a riding position that offers both comfort and control. Feeling at one with their machine, they will be able to experience how Kawasaki machines are fun and rewarding to ride.
*Adjustable parts and their range of adjustability vary by model.
Horizontal Back-link Rear Suspension​
Compared to the Kawasaki traditional Uni-Trak® rear suspension, which mounts the shock unit vertically, with Horizontal Back-link Rear Suspension, the shock unit is almost horizontal. The original Kawasaki suspension arrangement locates the shock unit very close to the bike’s center of gravity, greatly contributing to mass centralization. And because there is no linkage or shock unit protruding beneath the swingarm, this frees up space for a larger exhaust pre-chamber (an exhaust expansion chamber situated just upstream of the silencer). With a larger pre-chamber, silencer volume can be reduced, and heavy exhaust components can be concentrated closer to the center of the bike, further contributing to mass centralization. The result is greatly improved handling.
A secondary benefit is that the shock unit is placed far away from exhaust heat. Because it is more difficult for heat from the exhaust system to adversely affect suspension oil and gas pressure, suspension performance is more consistent.
2021 Kawasaki Z900RS Cafe Photos​
2021 Kawasaki Z900RS Cafe Videos​
Not Available
Kawasaki Official Websites​
The post 2021 Kawasaki Z900RS Cafe [Model Overview] appeared first on webBikeWorld.
