2021 Kawasaki Z900RS [Model Overview]
The 2021 Kawasaki Z900RS (and Cafe): Old School, New Cool​
Kawasaki has done a brilliant homage to the iconic Z1, with the styling of the Z900RS. We have seen many attempts to bring the old school cool into modern machines, often badly by the cager crowd (think Chevy SSR or Ford retro Thunderbird), but this Japanese-made modern classic really hits the mark.
Borrowing a few parts from its stablemate Z900 in the 2021 Kawasaki lineup, the Z900RS is its own animal. The 948cc mill has been retuned for better power in the lower RPM range. In Z900RS guise it cranks out 111 HP at 8500 RPM and 72 lb-ft of torque at 6500 RPM. Not meant to be a high revving sportbike, this Kawasaki wants a little more relaxed ride where you can vibe with the melodic exhaust note, but be confident in the power delivery at any point.
Hiding between the classic bullet gauges is a multi-function LCD screen, just another example of how well Kawasaki has blended old with new. A teardrop tank and well-padded slab seat merge with modern tech like the adjustable 41mm inverted front fork, ABS brakes, and Assist & Slipper clutch.
One last choice for the Z900RS owner, to Cafe or not Cafe? This is the question, well at least for the Americans. Oddly Canada is not bringing in the Cafe model. Such a shame, the added front cowl is a gorgeous throwback piece of art and function.
A final interesting tidbit on the Z900RS, for 2021 Canadians get the bike in Ebony, and those in the USA will have Candytone Green. The USA spec Cafe model comes in Pearl Storm Gray.
The 2021 Kawasaki Z900RS starts at $11,299 USD / $13,499 CAD.
The 2021 Kawasaki Z900RS Cafe starts at $11,899 USD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Kawasaki Z900RS in one place.
  • Price: $11,299 USD / $13,499 CAD / Cafe – $11,899 USD
    • Classic Modern styling
    • ABS Braking
    • Assist And Slipper Clutch
    • Tuned Exhaust Note
Main Specs​
  • Engine: 948cc, liquid-cooled, 4-stroke DOHC 16-valve in-line four
  • Power: 80.3 kW (111 hp) @ 8500 RPM
  • Torque: 72.7 lb-ft (98.6 NM) @ 6,500 RPM
  • Wet Weight: 214 kg (472 lb)
  • Seat Height: 800 mm (31.5 in)
Competitors​
2021 Kawasaki Z900RS Specifications​
Engine948cc, liquid-cooled, 4-stroke DOHC 16-valve in-line four
Power111 hp
Bore x Stroke73.4 x 56.0mm
Compression Ratio
11.8:1
Fuel SystemDFI® with 36mm Keihin throttle bodies
Lubrication
Clutch
Transmission6-speed, return shift
Final DriveSealed chain
Suspension FrontInverted telescopic fork with (13-way) adjustable compression and rebound (11-way) damping, spring preload (15-turn)/4.7
Suspension RearHorizontal back-link swingarm with stepless adjustable rebound damping and spring preload/5.5 in
Brakes FrontDual 300mm disc ABS
Brakes Rear
Single 250mm disc ABS
Tires Front120/70 ZR17
Tires Rear180/55 ZR17
Fuel Tank Capacity4.5 gal
Color
Candytone Green
IgnitionTCBI with electronic advance
HeadlightLED
Overall Length83.1 in
Overall Width34.1 in
Overall Height46.5 in
Wheelbase57.9 in
Ground Clearance5.1 in
Seat Height32.9 in
Curb Weight474.1 lb
Warranty12 Month Limited Warranty
Kawasaki Protection Plus12 / 24 / 36 / 48 months
2021 Kawasaki Z900RS Features​
Assist & Slipper Clutch​
Dual Throttle Valves​
Economical Riding Indicator​
POWER MODES​
Models equipped with multiple Power Modes offer riders an easily selectable choice of engine power delivery to suit riding conditions or preference. In addition to Full Power mode, one (Low) or two (Middle, Low) alternate mode(s) in which maximum power is limited and throttle response is milder are provided.
Smartphone Connectivity​
Clever technology enables riders to connect to their motorcycle wirelessly. Using the smartphone application “RIDEOLOGY THE APP,” a number of instrument functions can be accessed, contributing to an enhanced motorcycling experience. Vehicle information (such as the odometer, fuel gauge, maintenance schedule, etc) can be viewed on the smartphone. Riding logs (varies by model, but may include GPS route, gear position, rpm, and other information) can be viewed on the smartphone. When connected, telephone (call, mail) notices are displayed on the instrument panel. Riders can also make changes to their motorcycle’s instrument display settings (preferred units, clock and date setting, etc) via the smartphone. And on certain models, it is even possible to check and adjust vehicle settings (such as Rider Mode, electronic rider support features, and payload settings) using the smartphone.
ABS (Anti-lock Brake System)​
Horizontal Back-link Rear Suspension​
Compared to the Kawasaki traditional Uni-Trak® rear suspension, which mounts the shock unit vertically, with Horizontal Back-link Rear Suspension, the shock unit is almost horizontal. The original Kawasaki suspension arrangement locates the shock unit very close to the bike’s center of gravity, greatly contributing to mass centralization. And because there is no linkage or shock unit protruding beneath the swingarm, this frees up space for a larger exhaust pre-chamber (an exhaust expansion chamber situated just upstream of the silencer). With a larger pre-chamber, silencer volume can be reduced, and heavy exhaust components can be concentrated closer to the center of the bike, further contributing to mass centralization. The result is greatly improved handling.
A secondary benefit is that the shock unit is placed far away from exhaust heat. Because it is more difficult for heat from the exhaust system to adversely affect suspension oil and gas pressure, suspension performance is more consistent.
2021 Kawasaki Z900RS Photos​
2021 Kawasaki Z900RS Videos​
Kawasaki Official Websites​
The post 2021 Kawasaki Z900RS [Model Overview] appeared first on webBikeWorld.
