Question 2021 LED headlight adjustment
Wheels
USA, NC , Raleigh
First service asked for headlight adjustment (too low). Service guys said it was OK.
Its NOT OK.
Anyone have service manual or know about adjusting these new LED headlight enclosures?
There appears to be only one bolt that may be the adjuster.
Wheels
USA, NC , Raleigh
Appears to be two adjusters left side up high and the right side down low (looking from the seat).
Finagled a socket , extension and ratchet and cranked on the left side. Looking at the beam
on the garage wall I could not tell any difference. Didn't do anything with the right side, the
fork tube gets in the way.
Wheels
USA, NC , Raleigh
2021 LED Headlight assembly, the lights are bright enough if adjusted correctly.
OK, about 90% accurate .... lol
View from seat:
HI Beam: Right hand side bolt, used 10 mm closed end wrench.
Handlebar to the right, come up from bottom with wrench.
Used small (lol) left hand to steady wrench.
LO Beam: Left hand side bolt, used 10mm socket with short extension
Handlebar to the left, straight at the bolt
Clockwise ... lowered Counter-Clockwise ... raised
Count your 1/8 or 1/4 turns ....
Wheels
USA, NC , Raleigh
2021 Service Manual page 3-21.
From seat perspective:
Left side is horizontal , uses phillips head screwdriver, maybe from below.
Right side is vertical, uses phillips head screwdriver, from below.
I previously got the light vertical raised, will have to check the horizontal after messing with it.
