2021 MV Agusta Brutale 800 Rosso [Model Overview]
2021 MV Agusta Brutale 800 Rosso: Exotic On a Budget​
The 2021 MV Agusta Brutale 800 Rosso is the first step when easing your way into the Brutale section of MV Agusta’s 2021 lineup of bikes. It’s the base model of the 800 series, and if you’re feeling dicey you can graduate to the 140hp version for more power.
The Brutale line of Italian motorcycles is arguably the best-of-the-best when it comes to mid-displacement naked bikes. MV Agusta takes pride in their eye for design, and this motorcycle provides you with all the staple visual identifiers you would come to expect from an MV Agusta motorcycle, but at a fraction of the cost.
The Brutale 800 Rosso comes standard with a de-tuned version of MV Agusta’s 798cc inline-three shared with many other of their models in the mid-displacement lineup. This engine gives the Brutale 800 Rosso a healthy 110 horsepower that can get you up to a maximum speed of 237 km/h. If you’re in the market for a motorcycle similar to the Rosso but with a little more grunt, MV Agusta produces the “Brutale 800 RR” that manages to squeeze an extra 30 horsepower from the same inline-three engine.
This bike comes ready with tons of tech like ABS, traction control, wheelie control and all of the modern features you would expect to find in a modern high-performance Italian machine.
The 2021 MV Agusta Brutale 800 Rosso starts at $14,559 USD / $11,990 EUR.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 MV Agusta Brutale Rosso in one place.
  • Price: $14,559 USD / $11,990 EUR
    • Timeless MV Agusta styling
    • A de-tuned Brutale 900 RR engine
    • Eight levels of traction control and four riding modes
    • Four-piston Brembo calipers
    • ABS, TC, RLM ( Rear Wheel Lift-Up Mitigation)
Main Specs​
  • Engine: 798cc inline-three
  • Power: 110 BHP
  • Torque: 62 lb-ft
  • Dry Weight: 385.8 lb (144 kg)
  • Seat Height: 33.26 inches (843 mm) at lowest point
Competitors​
2021 MV Agusta Brutale 800 Rosso Specifications​
Engine798cc inline-three, Three cylinder, 4 stroke, 12 valve
Power110 horsepower
Bore x Stroke79 mm x 54.3 mm (3.1 in. x 2.1 in.)
Compression Ratio12.3:1
Timing system“D.O.H.C” with mechanical chain tensioner and DLC tappet
Cooling systemCooling with separated liquid and oil radiators
ClutchMulti-disc wet clutch with hydraulic actuation and back torque limiting device
TransmissionCassette style; six speed, constant mesh
Final Drive22/41
Suspension FrontMarzocchi “UPSIDE DOWN” telescopic hydraulic fork with rebound-compression damping and spring preload external and separate adjustment
Suspension RearProgressive Sachs, single shock absorber with rebound and compression damping and spring preload adjustment
Brakes Front
Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange
Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia.
Tires Front120/70 – ZR 17 M/C (58 W)
Tires Rear180/55 – ZR 17 M/C (73 W)
Fuel Tank Capacity16.5 l (4.36 U.S. gal.)
ABS SystemContinental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
Battery12 V – 8.5 Ah
Voltage12 V
Alternator350 W at 5000 r.p.m.
Headlight
Tail Light
Overall Length2045 mm (80.51 in.)
Overall Width875 mm (34.45 in.)
Trail103,5 mm (4.07 in.)
Wheelbase1400 mm (55,12 in.)
Ground Clearance135 mm (5.31 in.)
Seat Height830 mm (32.68 in.)
Dry Weight175 kg (385,80 lbs.)
Warranty
2021 MV Agusta Brutale 800 Rosso Features​
LATEST GENERATION ELECTRONICS​
The new IMU inertial platform, developed exclusively for MV Agusta, has redefined the standards of quality for electronic controls: traction control is more precise than ever, while FLC wheelie control heightens the thrill of riding without sacrificing any safety. The new EAS 3.0 electronic gearbox offers improved precision and speed.
Electronics​
Even excellence can be improved upon: with this in mind, the frame features new side plates which increase lateral and longitudinal rigidity. The new rear linkage boosts progressiveness and works in harmony with the re-calibrated fork. Efficiency, comfort and a sporting thrill are the results of constant evolution.
Safty​
The new Continental ABS MK100 with RLM means that even the sharpest and most sudden weight transfers can be managed safely.It includes a cornering function which enables safe breaking even on corners, as well as interfacing with the inertial platform designed specifically for the Brutale range.
2021 MV Agusta Brutale 800 Rosso Photos​
2021 MV Agusta Brutale 800 Rosso Videos​
MV Agusta Websites​
Other Links​
The post 2021 MV Agusta Brutale 800 Rosso [Model Overview] appeared first on webBikeWorld.
