2021 MV Agusta Dragster 800 RR SCS [Model Overview]
2021 MV Agusta Dragster 800 RR SCS: The Streetfighter (SCS)​
The MV Agusta Brutale line of motorcycles are considered naked motorcycles, but the Dragster takes a different approach with more of a streetfighter form factor and styling. The motorcycle is highly exotic looking and brings some stylistic elements into the mix that aren’t found in the Brutale. This bike still retains the same 798cc 140 horsepower engine that spans the entirety of the 800 RR lineup in 2021, although this model in specific comes with a quick-shifter. Everything else remains the same.
The Dragster is aggressive and far sharper than its close Brutale relatives. The motorcycles are still pretty similar and share much of the same DNA when it comes down to brass taxes, though. The rims on this bike have been swapped out for some beautiful wire-spoke wheels, but much of the tech remains the same across the entire Italian manufacturer’s lineup.
The “SCS” part of the name hints at the inclusion of MV Agusta’s Smart Clutch System 2.0; a quick-shifting system that allows for easy up and downshifting without the use of the clutch lever. As a result of this feature, no time will be lost when blasting through the gears on this bike with a spirited pull.
Along with the inclusion of the quickshifter, there are many other electronic aids to make riding a breeze. There are a total of eight fully adjustable traction control modes, Bosch ABS, ride-by-wire technology introduced this model year, and four rider modes.
The 2021 MV Agusta Dragster 800 RR SCS starts at $23,440 USD / $19,490 EUR.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 MV Agusta Dragster 800 RR SCS in one place.
  • Price: $23,440 USD / $19,490 EUR
    • MV Agusta’s Smart Clutch System 2.0
    • Spoked rims
    • Streetfighter DNA
    • The same inline-three shared with the Brutale 800 family
    • Eight levels of traction control and four riding modes
    • Four-piston Brembo calipers
    • ABS, TC, RLM ( Rear Wheel Lift-Up Mitigation)
  • Engine: 798cc inline-three
  • Power: 140 BHP
  • Torque: 64.2 lb-ft
  • Dry Weight: 370.4 lb (168 kg)
  • Seat Height: 33.27 inches (845 mm) at lowest point
2021 MV Agusta Dragster 800 RR SCS Specifications​
Engine798cc inline-three, Three cylinder, 4 stroke, 12 valve
Power140 horsepower
Bore x Stroke79 mm x 54.3 mm (3.1 in. x 2.1 in.)
Compression Ratio13.3:1
Timing system“D.O.H.C” with mechanical chain tensioner and DLC tappet
ColorMatt Magnum Avio Grey, Matt Metallic Dark Grey, Matt Magnum Silver, Matt Metallic Dark Grey
ClutchS.C.S. 2.0 (Smart Clutch System) Radius CX automatic clutch with hydraulic clutch actuation, wet multi-disc
TransmissionCassette style; six speed, constant mesh
Final Drive Ratio16/41
Suspension FrontMarzocchi “UPSIDE DOWN” telescopic hydraulic fork in DLC treated aluminium, with anodized fork legs and having rebound-compression damping and spring preload external and separate adjustment
Suspension RearProgressive Sachs, single shock absorber with rebound and compression damping and spring preload adjustment
Brakes Front
Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange
Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia.
Tires Front120/70 – ZR 17 M/C (58 W)
Tires Rear200/55 – ZR 17 M/C (78 W)
Fuel Tank Capacity16.5 l (4.36 U.S. gal.)
ABS SystemContinental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
Battery12 V – 8.6 Ah
Voltage12 V
Alternator350 W at 5000 r.p.m.
Headlight
Tail Light
Overall Length2035 mm (80.12 in.)
Overall Width935 mm (36.81 in.)
Trail135 mm (5.31 in.)
Wheelbase1400 mm (55.12 in.)
Ground Clearance135 mm (5.31 in.)
Seat Height845 mm (33.27 in.)
Dry Weight175 kg (385.8 lbs.)
Warranty
2021 MV Agusta Dragster 800 RR SCS Features​
Ultimate efficiency​
The SCS 2.0 system allows a perfect match between the clutch action and the delivery curve of the three-cylinder engine. The support of highly sophisticated electronics has allowed MV engineers to unlock the secret to beating traditional-clutch models in acceleration performance.
Fluid, more intuitive ride​
The SCS 2.0 system doesn’t really change the way the rider interacts with the motorcycle: the clutch control, shift and gears are still just where you’d expect to find them, but with the bonus option of simply deciding not to use the clutch. For extreme functionality, without sacrificing anything.
Power and control​
A braking system worthy of the name and performance of the Dragster. Powerful and scalable, with two 320 mm-diameter floating discs and four-piston radial callipers, plus the assistance of the advanced Continental ABS with cornering function.
2021 MV Agusta Dragster 800 RR SCS Photos​
2021 MV Agusta Dragster 800 RR SCS Videos​
MV Agusta Websites​
Other Links​
The post 2021 MV Agusta Dragster 800 RR SCS [Model Overview] appeared first on webBikeWorld.
