2021 MV Agusta Turismo Veloce 800 Lusso SCS [Model Overview]
The 2021 MV Agusta Turismo Veloce 800 Lusso SCS: The Highest Tech Sport Tourer From Italy​
The 2021 MV Agusta Turismo Veloce 800 Lusso SCS is a sub-model of the Tursimo Veloce 800 Lusso. As with the entire Turismo Veloce 800 line, it is powered by the same 798cc inline-three, with 110 HP and just about 60 lb-ft of torque.
The big difference between the regular Turismo Veloce 800 Lusso and the Lusso SCS is the addition of the Italian manufacturer’s latest technology innovation. The SCS in the name stands for Smart Clutch System, which works beside MV Agusta’s EAS 2.1 quickshift system to allow for the most enjoyable riding experience with the least amount of jerkiness or missed clutch points.
How the SCS works is that it automatically detects when the bike is coming to a full stop and disengages the clutch as you come to a full stop. You don’t need to clutch in and find neutral, as it will automatically do that for you with the quickshifter. And when you start to move again, the system will automatically feather the clutch as you add power, ensuring you have a smooth pull-away and don’t stall.
The 2021 MV Agusta Turismo Veloce 800 Lusso SCS starts at approximately $25,440 USD / $32,290 CAD, as it is listed in Euros (€20,990).
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 MV Agusta Turismo Veloce 800 Lusso SCS in one place.
  • Price: $25,440 USD / $32,290 CAD
    • 8 level traction control system
    • Brembo and Bosch dual-zone ABS with rear-wheel lift mitigation
    • MV Agusta Smart Clutch System
Main Specs​
  • Engine Type: 798cc liquid and oil cooled, four stroke, DOHC, 12 valve triple
  • Horsepower: 110 HP
  • Torque: 60 lb-ft
  • Wet Weight: Approx 450 lbs (Approx 204 kg)
  • Seat Height: 33.46 inches (850 mm)
Competitors​
2021 MV Agusta Turismo Veloce 800 Lusso SCS Specifications​
Engine798cc liquid and oil cooled, four stroke, DOHC, 12 valve triple
Power110 horsepower
Bore x Stroke79 mm x 54.3 mm (3.1 in. x 2.1 in.)
Compression Ratio13.3:1
Timing system“D.O.H.C” with mechanical chain tensioner
ColorFire Red, Dark Metallic Matt Grey, Pearl White, Dark Metallic Matt Grey
ClutchS.C.S. 2.0 (Smart Clutch System) Radius CX automatic clutch with hydraulic clutch actuation, wet multi-disc
TransmissionCassette style; six speed, constant mesh
Final Drive Ratio16/41
Suspension FrontSachs “UPSIDE DOWN” semi-active telescopic hydraulic fork MVCSC (MV Agusta Chassis Stability Control)
Suspension RearProgressive Sachs, semi-active single shock absorber with hydraulic spring preload adjustment MVCSC (MV Agusta Chassis Stability Control)
Brakes Front
Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange
Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia.
Tires Front120/70 – ZR 17 M/C (58 W)
Tires Rear190/55 – ZR 17 M/C (75 W)
Fuel Tank Capacity21.5 l (5.68 U.S. gal.)
ABS SystemBosch 9 Plus with RLM (Rear wheel Lift-up Mitigation)
Battery12 V – 8.6 Ah
Voltage12 V
Alternator350 W at 5000 r.p.m.
Headlight
Tail Light
Overall Length2125 mm (83.66 in.)
Overall Width910 mm (35.83 in.)
Trail108 mm (4.25 in.)
Wheelbase1445 mm (56.89 in.)
Ground Clearance140 mm (5.51 in.)
Seat Height850 mm (33.46 in.)
Dry Weight199 kg (438.72 lbs)
Warranty
2021 MV Agusta Turismo Veloce 800 Lusso SCS Features​
THE PERFECT RIDE​
Latest evolution of Ride by Wire; four engine maps of which one is customizable; an even more effective and less invasive 8-level traction control: in addition to the many improvements of the electronic management of the bike, the Turismo Veloce Lusso SCS features the perfect integration of the automatic clutch with the other electronic devices. The result is a flawless performance, whatever the riding conditions.
PROPRIETARY TECHNOLOGY​
The SCS (Smart Clutch System) technology is exclusive to MV Agusta, and this is the first time it is used on a production motorbike. Its development took over 3 years and required the production of specific technical components, in addition to hundreds of thousands of kilometers of testing. The transparent clutch cover is a tribute to this unique technology.
PEACE OF MIND​
Just like the EAS 2.0 “up and down” assisted shifting, the SCS technology was introduced for the first time on a production motorcycle by MV Agusta. It contributes to safety, working with the automatic clutch, avoiding the engine to switch off. The parking brake, operated with the right foot, further contributes to safety even when the surface in not perfectly level.
2021 MV Agusta Turismo Veloce 800 Lusso SCS Photos​
2021 MV Agusta Turismo Veloce 800 Lusso SCS Videos​
MV Agusta Websites​
Other Links​
The post 2021 MV Agusta Turismo Veloce 800 Lusso SCS [Model Overview] appeared first on webBikeWorld.
