2021 MV Agusta Turismo Veloce 800 RC SCS [Model Overview]
2021 MV Agusta Turismo Veloce 800 RC SCS: The Pinnacle Of Mid-Displacement Touring​
If you’re looking to get onto a mid-displacement MV Agusta motorcycle but the Dragster and Brutale model lineups don’t provide enough comfort for long distance riding, the Turismo Veloce should be right up your alley. It is a touring-oriented motorcycle built off of MV Agusta’s 800 platform.
The 2021 Turismo Veloce 800 RC SCS is the highest trim level found in the Turismo Veloce lineup. This Italian-made touring motorcycle has every feature that MV Agusta has to offer when it comes to extras and electronics.
For starters, the SCS denotes the inclusion of MV Agusta’s “Smart Clutch 2.0” system. This is a highly developed quick shifting system that MV Agusta has created to support the highest trim levels across all models. The inclusion of the Smart Clutch system allows for instant shifting without the use of the clutch lever to blow through gears without missing a beat.
The “RC” denotes that this trim package comes with all of MV Agusta’s parts designed for racing. This brings the model an updated chassis, forged aluminum wheels, and extra electronics to help you ride to the limits.
The engine is the same 798cc inline-three that you can find across all of MV Agusta’s mid-displacement bikes in their 2021 lineup.
The 2021 MV Agusta Turismo Veloce 800 RC SCS starts at $22,990 EUR / $27,675 USD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 MV Agusta Turismo Veloce 800 RC SCS in one place.
  • Price: $22,990 EUR / $27,675 USD
    • Bosch ABS
    • MV Agusta’s 789cc inline-three engine
    • Semi-active suspension
    • Cruise control
    • Updated electronics
    • 8-level traction control
Main Specs​
  • Engine: 798cc inline-three
  • Power: 110 BHP
  • Torque: 59 lbs-ft at the crank
  • Dry Weight: 438.72 lbs (199 kg)
  • Seat Height: 33.46 inches (850 mm) at lowest point
Competitors​
  • Yamaha Tracer 900 GT
  • Ducati Multistrada 950
  • BMW F900 XR
2021 MV Agusta Turismo Veloce 800 RC SCS Specifications​
Engine798cc inline-three, Three cylinder, 4 stroke, 12 valve
Power110 horsepower
Bore x Stroke79 mm x 54.3 mm (3.1 in. x 2.1 in.)
Compression Ratio12.3:1
Timing system“D.O.H.C” with mechanical chain tensioner
ColorMetallic Avio Grey, Ago Red
ClutchS.C.S. 2.0 (Smart Clutch System) Radius CX automatic clutch with hydraulic clutch actuation, wet multi-disc
TransmissionCassette style; six speed, constant mesh
Final Drive Ratio16/41
Suspension FrontSachs “UPSIDE DOWN” semi-active telescopic hydraulic fork MVCSC (MV Agusta Chassis Stability Control)
Suspension RearProgressive Sachs, semi-active single shock absorber with hydraulic spring preload adjustment MVCSC (MV Agusta Chassis Stability Control)
Brakes Front
Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange
Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia.
Tires Front120/70 – ZR 17 M/C (58 W)
Tires Rear190/55 – ZR 17 M/C (75 W)
Fuel Tank Capacity21.5 l (5.68 U.S. gal.)
ABS SystemBosch 9 Plus with RLM (Rear wheel Lift-up Mitigation)
Battery12 V – 8.6 Ah
Voltage12 V
Alternator350 W at 5000 r.p.m.
Headlight
Tail Light
Overall Length2125 mm (83.66 in.)
Overall Width910 mm (35.83 in.)
Trail108 mm (4.25 in.)
Wheelbase1445 mm (56.89 in.)
Ground Clearance140 mm (5.51 in.)
Seat Height850 mm (33.46 in.)
Dry Weight199 kg (438.72 lbs)
Warranty
2021 MV Agusta Turismo Veloce 800 RC SCS Features​
PROGRESSIVE ELECTRONICS​
We did not settle for just the integrated MVICS electronics with full multi-map Ride by Wire, 8-level traction control and Up & Down EAS 2.0 electronic gearbox and inertial platform: the Lusso version also features our Skyhook algorithm that supplies all the key parameters for the semi-active suspension adjustments.
COUNTER-ROTATING CRANKSHAFT​
The heart of the Turismo Veloce is the pulsing 800 cc three-cylinder engine derived from the F3. It has a counter-rotating crankshaft, a unique feature in a touring bike that ensures unparalleled riding pleasure. We could not resist including a slipper clutch, worthy of a true racing thoroughbred.
THE PLEASURE OF RIDING​
When all you have to think about is riding, fun and pleasure are at their top, especially since safety is ensured by the two-channel Bosch 9 PLUS ABS system. With Rear Wheel Lift-ip Mitigation, the system controls the pressure applied on the front brake to avoid involuntary rear wheel lift-up.
2021 MV Agusta Turismo Veloce 800 RC SCS Photos​
2021 MV Agusta Turismo Veloce 800 RC SCS Videos​
MV Agusta Websites​
Other Links​
The post 2021 MV Agusta Turismo Veloce 800 RC SCS [Model Overview] appeared first on webBikeWorld.
