2021 Royal Enfield INT650 [Model Overview]
The 2021 Royal Enfield INT650: Flagship of This Year’s Lineup​
The 2021 Royal Enfield Interceptor 650, or INT650 in North America, is the flagship of the India-based company for the 2021 lineup. With classic lines that echo the original British manufacturer’s 1960’s Interceptor, it carries a certain air of the inter-city sprints that were popular in the UK in decades past, where riding groups would set off from different points and meet up in the next city for a good time.
While the bike itself may look classic, this is not to say that it is not as fresh and modern as a motorcycle of this day and age should be. A refinement of the 2020 INT650’s mill, the 2021 648cc parallel-twin carries itself well, with 47 BHP and 38.3 lbs-ft of crank torque from as low as 2,500 RPM, peaking at 5,250 RPM. The engine carries a single-piece forged and counterbalanced crankshaft at 270 degrees to provide both smoothness on throttle and the classic parallel-twin burble that brings a smile to any riders’ face.
The engine is also under-stressed at 9.5:1 compression, to give it a much more comfortable riding feel. No wild vibrations through the frame, and easy, smooth throttle response. Twin throttle-body intakes paired with a Bosch fuel injection system newly developed for 2021 just adds to the smoothness. The 6 speed transmission with standard slipper clutch returns for 2021, however with new ratios set to give the INT650 the best variety of gear options depending on the situation.
18 inch wheels front and back, paired with a 41mm front forks (110 mm travel) and twin coil-over rear shocks (88 mm travel), provide a comfortable, predictable ride. Preload is adjustable in 5 stages to suit riders of all sizes and shapes. Stopping power is provided by twin-piston ByBre brakes front and back, with a 320 mm front disc and 240 mm rear disc. Bosch dual-channel ABS is standard.
The 2021 Royal Enfield INT650 starts at $5,799 USD / $7,599 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Royal Enfield INT650 in one place.
  • Price: $5,799 USD / $7,599 CAD
    • Standard ABS
    • Newly adjusted for 2021 6-speed transmission
    • Air and oil cooled 648cc parallel-twin
  • Engine: 648cc parallel-twin
  • Power: 47 BHP
  • Torque: 38.3 lbs-ft at the crank
  • Wet Weight: 445 lbs (202 kg)
  • Seat Height: 31.5 inches (800 mm)
2021 Royal Enfield INT650 Specifications​
ENGINE
Engine648 cc, parallel-twin
Engine Power47 Hp
Bore x Stroke
Compression Ratio9.5:1
Fuel SystemFuel Injection
Torque38.3 lbs-ft
DRIVETRAIN
ClutchWet, multi-plate
Transmission6-speed
Final Drive
CHASSIS
Suspension Front41 mm front fork, 110 mm travel
Suspension RearTwin coil-over shocks, 88 mm travel
Brakes Front320 mm disc, ABS
Brakes Rear240 mm disc, ABS
Tires Front100/90-18
Tires Rear130/70-18
Fuel Tank Capacity13.7 lts
ColorGlitter And Dust, Silver Specter, Baker Express, Mark Three, Ravishing Red, and Orange Crush
ELECTRICAL
IgnitionTCI
Headlight
Tail Light
DIMENSIONS
Overall Length2122 mm
Overall Width789 mm
Overall Height1165 mm
Wheelbase
Ground Clearance174 mm
Seat Height804 mm
Curb Weight202 Kg
WARRANTY
Warranty*3 year unlimited mile warranty & road side assistance with the purchase of any Twins model.
2021 Royal Enfield INT650 Features​
Easy Come, Easy Go
The frame, developed in conjunction with the legendary Harris Performance, thoroughly tested for durability, offers superior balance and handling. Together with the finely tuned suspension with ‘piggy-back’ gas-charged twin shocks for optimum blend of comfort & feel, the chassis ensures the INT 650 is dynamic & responsive, nimble in the city, planted on the highways & agile on the twisties.
At The Heart Of It All
An air/oil-cooled parallel twin configuration chosen for its authentic uncluttered lines, the 648 cc engine is built for real world riding, with sufficient power to make light work of city traffic or cruise effortlessly on the open road. A twin throttle-body paired to a highly precise Bosch fuel injection system and EMS tune results in excellent throttle response throughout the rev range.
Smooth Operator
Classic aesthetics of 18” alloy-rimmed wheels are shod with Pirelli Phantom SportComp tires the structure and the compound of which were especially developed for Royal Enfield to complement the chassis and suspension in all riding conditions. The combination of twin-piston Brembo derived callipers on floating front disc and Bosch dual-channel ABS provide assured braking with progressive feedback.
Easy Like Sunday Morning
With its wide braced handlebars, the INT650 has a comfortable upright commanding riding position. The ergonomic triangle, formed by the handlebar, low seat and foot peg position, is set up for comfort with a gentle sports bias helping the rider make the most of the agile chassis and feel intuitively connected with the machine.
Old-School New
Whilst the beautifully sculpted lines of the gleaming, hand-polished aluminum engine covers hark back to a golden era of motorcycling, what really makes heads turn is the deep evocative exhaust note – metering either a steady heady beat, a wonderful over-run burble or a power-on rumble that will move your soul.
Devil Is In The Details
For the first time Royal Enfield uses a six-speed gearbox, specially developed for the 650 Twin, thoroughly tested on proving grounds, race tracks and public roads, with carefully selected gear ratios chosen to deliver the best blend for all riding conditions. The result is evident in the optimum shift feel, reliability of engagement, quiet notch-free selection and perfect ratio spacing. The gearbox is augmented by a slipper clutch which has an assist feature for light lever feel.
2021 Royal Enfield INT650 Photos​
2021 Royal Enfield INT650 Videos
Royal Enfield Himalayan Official Websites
The post 2021 Royal Enfield INT650 [Model Overview] appeared first on webBikeWorld.
