2021 Triumph Bonneville T100 [Model Overview]
Triumph’s Unadulterated Bonneville: The 2021 Triumph Bonneville T100​
The Bonneville T100 is arguably the most famous British motorcycle on the market. It’s the closest thing to the original Bonneville available in the 2021 Triumph line-up, taking inspiration directly from the 1959 model. Today, the Bonneville lives on as a range of Triumph motorcycles, but the unadulterated T100 is the model that most closely resembles the original.
The 2021 T100 is built around Triumph’s powerful 900 cc liquid-cooled, 8-valve, parallel twin Bonneville engine. Sports performance isn’t the driving force behind this high-torque engine. Instead, it has been developed for practical cruising and well-rounded versatility. The engine produces 55 horsepower and 59 lb-ft of peak torque.
While the T100’s retro aesthetic is its biggest draw, it also features a shopping list of impressive features. The best of these include Ride-by-Wire, ABS, a torque-assist clutch, sophisticated and stylish instrumentation, and modern practicalities such as an immobilizer and USB charging port.
For 2021, the Bonneville T100 is available in three color options: Fusion White and Aegean Blue with hand-painted coach lines, New England White and Intense Orange with hand-painted coach line, and Jet Black. An additional model, the Triumph Bonneville T100 Black is available with a blacked-out aesthetic.
The 2021 Triumph Bonneville T100 starts from $10,450 USD / $11,350 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Triumph Bonneville T100 in one place.
  • Price: $10,450 USD / $11,350 CAD
    • Iconic 900cc high torque Bonneville engine
    • Original Bonneville DNA with beautiful features
    • Power and torque where you need it
  • Engine: 900 cc liquid-cooled, 8-valve, SOHC, 270° crank angle parallel-twin
  • Power: 55 HP
  • Torque: 59 lbs-ft
  • Dry Weight: 470lb (213kg) **Wet weight figures unavailable
  • Seat Height: 31.1in (790mm)
2021 Triumph Bonneville T100 Specifications​
Engine900 cc liquid-cooled, 8-valve, SOHC, 270° crank angle parallel-twin
Power55 HP
Bore x Stroke84.6 mm x 80 mm
Compression Ratio10.55:1
Fuel SystemMultipoint sequential electronic fuel injection
ExhaustPolished stainless steel 2 into 2 exhaust system with twin silencers
ClutchWet, multi-plate assist clutch
Transmission5-speed
Final DriveChain
Suspension FrontKYB 41 mm forks, 120 mm travel
Suspension RearKYB twin shocks with adjustable preload, 120 mm rear wheel travel
Brakes FrontSingle 310 mm floating disc, Nissin 2-piston floating caliper, ABS
Brakes RearSingle 255 mm disc, Nissin 2-piston floating caliper, ABS
Tires Front100/90-18
Tires Rear
150/70 R17
Fuel Tank Capacity3.8 US gal
ColorWhite and Intense Orange, Jet Black
Ignition
HeadlightLED
Overall Length
Width Handlebars28.1in (715mm)
Height Without Mirror43.3in (1100mm)
Wheelbase57.1in (1450mm)
Trail4.1in (104mm)
Seat Height31.1in (790mm)
Dry Weight470lb (213kg)
Warranty
2021 Triumph Bonneville T100 Features​
SMOOTH HANDLING​
Synonymous with British motorcycling, the Bonneville has become the embodiment for style and character. It is, genuinely, a great British icon and today’s new generation of T100s stand as the perfect blend of that original character, British heritage, design, and style, backed by modern capability, technology, performance and Triumph’s renowned precise and confidence inspiring handling.
900CC ‘HIGH-TORQUE’ BONNEVILLE ENGINE​
The Bonneville T100s both feature the same specially tuned 900cc high-torque Bonneville engine that delivers performance, enhanced fuel economy, and a deep, rich exhaust note.
The 8-valve single overhead camshaft parallel-twin with 270° firing interval provides smooth linear power, delivered directly from the slick new five-speed gearbox.
MORE POWER AND TORQUE WHERE YOU NEED IT​
The 900cc engine has been designed to deliver much more power and torque where you need it – between 2,750rpm and 4,750rpm, to suit the riding style of this modern classic, for a more thrilling and engaging ride.
In addition, the T100 delivers 22% more power in the mid-range against previous generations and a massive 18% more peak torque, with 80Nm at a low 3,230rpm.
SMOOTH, NEUTRAL RIDE​
The dedicated T100 chassis and suspension work together to provide a smooth ride, along with easy, neutral handling and sensitive incorporation of advanced rider-focused technology, with ABS, traction control and a torque-assist clutch to give that extra level of comfort and control. The T100 range is available in beautiful classic and stylish contemporary colours and there are over 150 accessories available to personalise your motorcycle.
UPRATED TYRES AND DISC BRAKES​
T100 motorbikes have an uprated single floating front brake disc. Both models come with Pirelli Phantom Sportscomp tyres, specially developed by Pirelli for the Triumph Bonneville range. Added stiffness, profile changes to the front, and deeper tread on the rear provide secure handling and excellent durability.
REFINED HANDLING AND COMFORT​
The T100s have a significantly enhanced level of comfort and handling. A more comfortable seat with thicker foam than previous generations comes as standard and the chassis and suspension, incorporating greater suspension travel, has been developed specifically for an engaging yet easy-going ride, improving long-distance use and pillion passenger capability.
ELEGANT STYLE AND SOUND​
The Bonneville T100s’ high-torque 900cc engine has been elegantly styled with a high level of detailing and finish. It includes signature styling cues from the original ’59 Bonneville engine silhouette, whilst incorporating contemporary components sensitively to preserve the iconic Bonneville look.
LIGHTER AND EVEN MORE ACCESSIBLE​
The Bonneville T100s are one of the most accessible motorbike options in the Bonneville range, weighing in less than the T120s.
With their low seat height, easy handling and a dealer-fitted A2 licence kit available, they are ideal for every type of ride and rider.
2021 Triumph Bonneville T100 Photos​
2021 Triumph Bonneville T100 Videos​
The post 2021 Triumph Bonneville T100 [Model Overview] appeared first on webBikeWorld.
