2021 Triumph Speed Triple RS [Model Overview]
Triumph’s Top-Shelf Triple: The 2021 Triumph Speed Triple RS​
The Triumph Speed Triple RS is the top of the range naked roadster from Triumph Motorcycles. Thanks to a number of impressive tweaks from Triumph, the Speed Triple RS claims to be the most powerful, responsive, and best sounding triple ever! If you want to unleash your inner hooligan, this is the best model in the 2021 Triumph line-up for the job.
The 2021 Triumph Speed Triple RS draws power from a British-made 1,050cc Liquid-cooled, 12 valve, DOHC, inline 3-cylinder engine that produces a potent 148 horsepower and 86 lb-ft of peak torque. It’s a powerful ride, but the real secret to the Speed Triple RS’s success isn’t the engine, but the comprehensive electronics package that complements it.
Boasting five riding modes (Road, Rain, Sport, Track, and Rider-configurable), optimized cornering ABS, traction control, cruise control, and Triumph’s own all-new shift assist quick-shifter, the Speed Triple RS is a powerful and advanced motorcycle, with plenty of bells and whistles. What’s more, it also has fully adjustable Ohlins suspension, high-spec Brembo brakes, a keyless ignition, LED DRLs, and a full-color TFT display too. And that’s only a snapshot of what is on offer.
For 2021, the Speed Triple RS is available in two color options: Matt Black or Crystal White.
The 2021 Triumph Speed Triple RS starts from $16,500 USD / $18,300 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Triumph Speed Triple RS in one place.
  • Price: $16,500 USD / $18,300 CAD
    • New TFT color instruments
    • Five riding modes
    • New optimized cornering ABS and traction control
Main Specs​
  • Engine: 1,050 cc liquid-cooled, 12 valve, DOHC, inline 3-cylinder
  • Power: 148 HP
  • Torque: 86 lbs-ft
  • Dry Weight: 416 lbs (189 Kg)
  • Seat Height: 32.48 in (825 mm)
Competitors​
2021 Triumph Speed Triple RS Specifications​
Engine 1,050 cc liquid-cooled, 12 valve, DOHC, inline 3-cylinder
Power148 HP
Bore x Stroke79 mm x 71.4 mm
Compression Ratio12.92:1
Fuel SystemMultipoint sequential electronic fuel injection with SAI
ExhaustStainless Steel 3 into 1 into 2 high level stainless steel mufflers
ClutchWet, multi-plate slip-assist clutch
Transmission6-Speed
Final DriveX-ring chain
Suspension FrontShowa 43 mm upside down forks with adjustable preload, rebound and compression damping, 4.72 in (120 mm) travel
Suspension RearShowa monoshock with adjustable preload, rebound and compression damping, 5.12 in (130 mm) rear wheel travel
Brakes FrontTwin 12.6 in (320 mm) floating discs, Brembo 4-piston Monobloc radial calipers Switchable ABS
Brakes RearSingle 10.04 in (255 mm) disc, 2-piston sliding caliper Switchable ABS
Tires Front120/70 ZR17
Tires Rear
190/55 ZR17
Fuel Tank Capacity4.1 US gallons (15.5 L)
ColorMatt Black, Crystal White
Ignition
HeadlightLED
Overall Length
Width Handlebars30.51 in (775 mm)
Height Without Mirror42.13 in (1,070 mm)
Wheelbase56.89 in (1,445 mm)
Trail3.59 in (91.3 mm)
Seat Height32.48 in (825 mm)
Dry Weight423 lbs (192 Kg)
Warranty
2021 Triumph Speed Triple RS Features​
NEW TFT COLOR INSTRUMENTS​
Full-color 5-inch TFT instrument display that presents both essential and additional rider information from the on-board computer, with three screen styles to choose from, all with high and low contrast settings, adjustable for optimum visibility.
NEW ILLUMINATED SWITCH CUBES​
Ergonomically optimized stylish new backlit switch cubes for fast intuitive access to bike functions, including 5-way joystick to navigate TFT instrument screen, riding modes button and new cruise control switch.
FOUR RIDING MODES​
Easily accessed through the left hand switch cube, choose from four riding modes, Rain, Road, Sport and Rider-configurable. Each altering the throttle map, ABS and traction control settings to suit the conditions or desired riding style.
NEW CRUISE CONTROL​
Fitted as standard for the first time on the Speed Triple, cruise control can reduce rider fatigue on long distance journeys and is quickly enabled and disabled via the left hand switch cube for additional convenience.
DRL HEADLIGHTS​
Daytime Running Lights are an impressive way of increasing your visibility with a distinctive light profile. These are incorporated into the headlamps, which are set characteristically low to reflect the Speed Triple’s nose-down focused attitude.
MAJOR ENGINE UPDATE AND IMPROVED GEARBOX​
The latest Speed Triple is lighter, with an updated 1050cc engine, more responsive throttle, and improved gearbox to deliver even more power and the most agile, sharp and focused ride you’ve ever had on this explosive bike.
GRADED SLIP-ASSIST CLUTCH​
Improving the clutch ‘feel’ by reducing lever effort, bringing a lighter touch than you’d expect; perfect for long journeys or stop-start urban commutes.
Triumph Shift Assist​
All-new Triumph designed system that enables smooth up/down gear changes without the use of the clutch, reducing rider fatigue.
NEW RESTYLED SILENCERS​
Contemporary new black, race-style, freer flowing twin upswept silencers, with a larger bore and a more slender stainless steel end cap and aluminum heat shield.
NEW WHEELS WITH HIGH SPECIFICATION BRAKES AND TIRES​
There’s a more contemporary high-gloss finish to the Speed Triple cast alloy wheels, while high-spec Pirelli Diablo Supercorsa tyres and twin disc front brakes with Brembo Monobloc calipers provide an even greater feel and control.
2021 Triumph Speed Triple RS Photos​
2021 Triumph Speed Triple RS Videos​
The post 2021 Triumph Speed Triple RS [Model Overview] appeared first on webBikeWorld.
