2022 BMW F 900 XR [Specs, Features, Photos]
The 2022 BMW F 900 XR: The SUV Of Motorcycles​
The BMW F 900 XR sits in the Adventure category of the 2022 BMW lineup, but this is a middleweight sport touring machine with a GS-like riding position.
The design of the F 900 XR definitely carries a European-made feel, providing a sense that carving corner after corner for many kilometers would be very comfortable behind the fairing. With 99 hp from the 895cc parallel-twin, it is nice to have Rain/Road riding modes and stability control as standard features.
The option is long for this motorcycle. BMW groups many popular options into the Premium Package including, Dynamic ESA, Ride Modes Pro, Traction Control, Cruise Control, and many more. They also offer many options for Touring cases, both side, and top.
3 Color choices for the 2022 BMW F 900 XR: Light White, Style Sport, Style Triple Black
The 2022 BMW F 900 XR starts at $11,695 USD / $12,985 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 BMW F 900 XR in one place.
2022 BMW F 900 XR
  • Price: $11,695 USD / $12,985 CAD
    • Adjustable hand brake and clutch levers
    • ASC
    • LED headlight (low / high beam)
    • LED indicators
    • Riding modes Rain/Road
    • Windshield adjustment
    • 6.5” TFT display with BMW Motorrad Connectivity
    • 12V socket
    • Windshield Adjustment
Main Specs​
  • Engine: 895cc Parallel Twin
  • Power: 99 hp at 8,500 rpm
  • Torque: 68 lb-ft at 6,750 rpm
  • Wet Weight: 482 lbs (219 kg)
  • Seat Height: 32.5″ (830 mm)
Competitors​
  • Suzuki V-Strom 1050
  • Ducati Multistrada V2
  • Triumph Tiger 900 GT
2022 BMW F 900 XR
2022 BMW F 900 XR Specifications​
Engine895cc, Water-cooled 4-stroke in-line two-cylinder engine, four valves per cylinder, two overhead camshafts, dry sump lubrication
Engine Power99 hp at 8,500 rpm
Bore x Stroke86 mm x 77 mm
Compression Ratio13.1 : 1
Fuel deliveryElectronic injection
Max Torque68 lb-ft at 6,750 rpm
ClutchMultiple-disc wet clutch (anti hopping), mechanically operated
TransmissionConstant mesh 6-speed gearbox integrated in crankcase
DriveEndless O-ring chain with shock damping in rear wheel hub
Suspension FrontUpside-down telescopic fork, Ø 43 mm
Suspension RearCast aluminum dual swing arm, central spring strut, spring pre-load hydraulically adjustable, rebound damping adjustable
Brakes FrontDual disc brake, floating brake discs, Ø 320 mm, 4-piston radial brake calipers
Brakes RearSingle disc brake, Ø 265 mm, single-piston floating caliper
Tires Front120/70 ZR 17
Tires Rear180/55 ZR 17
Fuel Tank Capacity4.1 gal (15.5 L)
ColorSport, Triple Black
AlternatorPermanent magnetic alternator 416 W (nominal power)
Battery12 V / 12 Ah
Headlight
Tail LightLED Tail Light
Overall Length85.0” (2,160 mm)
Overall Width33.9” (860 mm)
Overall Height52.0” – 55.9” (1,320 mm – 1,420 mm)
Wheelbase60” (1,521 mm)
Castor4.1” (105.2 mm)
Seat Height32.5”
Unladen weight, road ready, fully fueled
482 lbs (219 kg)
Warranty
2022 BMW F 900 XR
2022 BMW F 900 XR Features​
Two-cylinder in-line engine.​
The two-cylinder deliver torque exactly where you need it.
Dynamic ESA.​
The Dynamic ESA allows you to switch between suspension settings while riding.
Adaptive cornering light.​
Can you enjoy curves more with your own lighting?
Seat heights: Wide range that just fits.​
From 30.5 – 34.2 inches: With the F 900 XR, everyone can find their preferred seat height.
Height-adjustable windshield.​
Practical: The wind and weather protector can be adjusted by hand.
Always well-informed with BMW Motorrad Connectivity and TFT display.​
The standard 6.5” TFT color display and BMW Connectivity – direct connection with your smartphone.
Convenient storage space.​
Long-distance performance in every detail: Bags in the vehicle color are just one of the many highlights in terms of storage space.
2022 BMW F 900 XR Photos​
2022 BMW F 900 XR 2022 BMW F 900 XR 2022 BMW F 900 XR 2022 BMW F 900 XR
2022 BMW F 900 XR Videos​
2022 BMW F900 XR – First Ride Review
New 2022 BMW F900XR
BMW Official Websites​
The post 2022 BMW F 900 XR [Specs, Features, Photos] appeared first on webBikeWorld.
