2022 BMW F850GS Adventure [Specs, Features, Photos]
The 2022 BMW F850GS And GS Adventure: Premium Middleweight Adventure​
Often called “The Best Of Both Worlds”, BMW Motorrad certainly has many things right with the F 850 GS and GS Adventure. Powered by 853cc in-line 2-cylinder engines, and sharing the same 6-speed gearbox and brakes. Both bikes use the easy-to-read TFT display with connectivity. When it comes to the suspension, it appears that both bikes are using the same suspension and should have the same wheel travel numbers, 9.1″ / 8.5″ (230 mm / 215 mm) front and rear. I will note that there is some confusion on the BMW websites. Canada and some European sites list them as the same, but the USA and UK for example show different suspension travel figures between the two models.
There are key differences between these 2 premium Adventure bikes. The most obvious at first glance is the fairing. The Adventure has a larger fairing providing more protection. The Adventure receives a larger fuel tank holding an additional 8 L for a total of 23 L versus the GS with 15L. The Adventure model is blessed with the comfort seat which is a bit more posh for longer rides, this also means a slightly higher seat height. Finally you will notice the engine guard on the Adventure is much more substantial. All of these items add up to an additional 34 lbs (15 kg) of weight. This may not seem like much but it does leave the standard GS feeling much more nimble at slow speeds.
Like many models in the 2022 BMW lineup, the options list is full of goodies. I highly recommend looking at the Premium package, it includes key items such as the Dynamic ESA and Ride Modes Pro.
3 Color choices for the 2022 BMW F850GS : Racing Red, Style Rallye, Triple Black
3 Color choices for the 2022 BMW F850GS Adventure: Light White, Rallye, Triple Black
The 2022 BMW F850GS starts at $12,595 USD / $14,595 CAD.
The 2022 BMW F850GS Adventure starts at $12,595 USD / $14,595 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 BMW F850GS and GS Adventure in one place.
  • Price: GS: $12,595 USD / $14,595 CAD GSA: $12,595 USD / $14,595 CAD
  • Key Features GS:
    • ABS
    • Adjustable handbrake lever and clutch lever
    • ASC (Automatic Stability Control)
    • Engine guard
    • LED headlight
    • LED tail light
    • On-board computer Pro
    • Selectable Ride Modes (Rain / Road)
    • 12 V power socket
  • Key Features GS Adventure:
    • 6,5″ TFT colour display with connectivity
    • BMW Motorrad ABS
    • Riding modes Rain / Road
    • LED headlights and LED indicators
    • Adjustable touring windshield
    • 12 V power outlet and USB socket
    • Engine guard
    • Hand protectors
    • Stainless steel luggage rack
Main Specs​
  • Engine: 853cc Parallel Twin
  • Power: 99 hp at 8,500 rpm
  • Torque: 68 lb-ft at 6,750 rpm
  • Wet Weight: GS: 504 lbs (229 kg) GSA: 538 lbs (244 kg)
  • Seat Height: GS: 33.9″ GSA: 34.4”
Competitors​
  • Ducati Multistrada V2
  • KTM 890 Adventure
  • Triumph Tiger 900 Rally
2022 BMW F850GS Adventure Specifications​
Engine853cc, Liquid cooled, 4-stroke parallel twin engine, four valves per cylinder, double overhead camshafts, dry sump lubrication
Engine Power90 hp (66 kW) at 8,000 rpm
Bore x Stroke84 mm x 77 mm
Compression Ratio12.7 : 1
Fuel deliveryElectronic fuel injection
Max Torque63 lb-ft (86 Nm) at 6,250 rpm
ClutchMultiple-disc wet clutch (anti hopping), mechanically operated
TransmissionConstant mesh 6-speed gearbox integrated in crankcase
DriveChain Drive
Suspension FrontUpside-down telescopic fork, Ø 43 mm
Suspension RearCast aluminum dual swing arm, central spring strut, spring pre-load hydraulically adjustable, rebound damping adjustable
Brakes FrontDual floating disc brakes, dual-piston floating calipers, diameter 12.0″ (305 mm)
Brakes RearSingle disc brake, diameter 10.4″ (265 mm), single-piston floating caliper
Tires Front90/90 – 21 54V
Tires Rear150/70 – 17 69V
Fuel Tank Capacity4.0 gal (15 l)
ColorGS Trophy, Racing Red, Triple Black
AlternatorThree-phase 416 W generator
Battery12 V / 10 Ah
Headlight
Tail LightLED Tail Light
Overall Length90.8″ (2,305 mm)
Overall Width36.3″ (922 mm)
Overall Height53.4″ (1,356 mm)
Wheelbase62.7″ (1593 mm)
Castor4.9″ (126 mm)
Seat HeightRallye Seat: 35.0″, Comfort Seat: 34.4″, Standard Seat: 33.9″, Low Seat: 32.9″, Low Suspension Kit: 32.1″
Unladen weight, road ready, fully fueled
504 lbs (229 kg)
Warranty
2022 BMW F850GS Adventure Features​
Dynamic ESA​
Dynamic ESA automatically dampens the chassis and lets you determine how intense the contact between the tires and the terrain should be.
ABS Pro and DTC as standard​
ABS Pro gets even more out of curves and Dynamic Traction Control (DTC) prevents the rear wheel from spinning during changing grip conditions.
Iconic LED indicators in series​
The new standard LED indicators show even more clearly where the road is taking you.
Optional Ride Modes Pro​
With Ride Modes Pro you gain engine drag torque control (MSR) and Dynamic Brake Control (DBC), to support your riding style. In “Dynamic” mode the new engine mapping means that you can enjoy even more riding fun.
Adjustable windscreen and USB port as standard​
The adjustable windscreen protects you from wind and weather, while your smartphone remains charged thanks to the USB port.
Connectivity with TFT display and multi-controller​
Connect your smartphone to the bike via bluetooth and keep an overview of the vehicle information, navigation, calls and media with the 6.5 inch TFT display. You can control all functions intuitively via the multi-controller.
Expanded seat variety​
The new “extra low” seat help improve the handling and control of the machine, even for shorter riders.
2022 BMW F850GS Adventure Photos​
2022 BMW F850GS Adventure 2022 BMW F850GS Adventure 2022 BMW F850GS Adventure
2022 BMW F850GS Adventure Videos​
BMW F850GS vs F850GS Adventure
BMW F850GS Review Update – 30000 Miles – From a Real Owner
BMW Official Websites​
The post 2022 BMW F850GS Adventure [Specs, Features, Photos] appeared first on webBikeWorld.
