2022 BMW R 1250 R [Specs, Features, Photos]
The 2022 BMW R 1250 R: The Naked Boxer.​
The BMW R 1250 R is a naked European bike that shares the iconic boxer-style engine BMW is famous for.
The 1254cc engine puts down 105 lb-ft of torque through the Cast aluminum single-sided swing arm. Dual 320mm Brembo front brakes with BMW Motorrad Integral ABS are on tap to reign things back in again. A nice-looking 6.5” TFT screen pairs easily to your phone with BMW Motorrad Connectivity, giving access to riding modes, navigation, and media.
The BMW R 1250 R joins other 2022 models with the Option 719 package. From exclusive paintwork and a host of milled parts to forged wheels, this is all about factory individualization.
3 Color choices for the 2022 BMW R 1250 R: Black Storm Metallic, Style Sport, and Style Exclusive
The 2022 BMW R 1250 R starts at $14,995 USD / $17,625 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 BMW R 1250 R in one place.
2022 BMW R 1250 R
  • Price: $14,995 USD / $17,625 CAD
    • ABS Brakes
    • ASC (Automatic stability control)
    • 2 riding modes (Rain, Road)
    • TFT-Display with connectivity
    • HSC (Hill start control)
    • On Board Computer
    • Heated Grips
    • Power Socket
Main Specs​
  • Engine: 1,254 cc Air/liquid-cooled 4-stroke flat twin engine
  • Power: 136 hp (100 kW) at 7,750 rpm
  • Torque: 105 lb-ft (143 Nm) at 6,250 rpm
  • Wet Weight: 527 lbs (239 kg)
  • Seat Height: 32.3” (820mm)
Competitors​
  • Yamaha MT-10
  • Kawasaki Z900
  • KTM 890 Duke R
2022 BMW R 1250 R
2022 BMW R 1250 R Specifications​
Engine1254cc, Air/liquid-cooled 4-stroke flat twin engine, double overhead camshaft, one balance shaft and variable engine timing system BMW ShiftCam.
Engine Power136 hp at 7,750 rpm
Bore x Stroke4” x 3’
Compression Ratio12.5 : 1
Fuel deliveryElectronic fuel injection with ride-by-wire throttle system
Max Torque105 lb-ft at 6,250 rpm
ClutchOil lubricated clutch, hydraulically operated
TransmissionConstant-mesh 6-speed gearbox with helical cut gears
DriveShaft drive
Suspension FrontUpside-down telescopic fork, Ø 1.77”
Suspension RearCast aluminum single-sided swing arm with BMW Paralever; WAD strut (travel-related damping), spring pre-load hydraulically adjustable (continuously variable) via handwheel, rebound damping adjustable
Brakes FrontDual floating disc brakes, 4-piston radial calipers, diameter 320 mm
Brakes RearSingle disc brake, diameter 276 mm, dual-piston floating caliper
Tires Front120/70 ZR 17
Tires Rear180/55 ZR 17
Fuel Tank Capacity4.8 gal (18 L)
ColorBlack Storm Metallic, Sport, Exclusive
AlternatorThree-phase 508 W generator
Battery12 V / 12 Ah
Headlight
Tail LightLED Tail Light
Overall Length85.2″ (2,165 mm)
Overall Width34.6″ (880 mm)
Overall Height51.2″ (1,300 mm)
Wheelbase59.6″ (1,515 mm)
Castor4.9″ (125.6 mm)
Seat HeightStandard Seat: 32.3″
Unladen weight, road ready, fully fueled
527 lbs (239 kg)
Warranty
2022 BMW R 1250 R
2022 BMW R 1250 R Features​
Boxer Engine.​
With a maximum torque of 136hp, the reworked engine delivers more power than ever before. Experience the pure thrill of riding and the typical punch of the Boxer engine at all times.
ShiftCam model inscription.​
Shows what’s inside: the new boxer engine with variable camshaft control ensures increased performance, smooth running and efficiency.
Stainless steel.​
Set beautiful and high-quality accents with the radiator cover and the tank cover made of stainless steel. The engine spoiler made of stainless steel is available as an optional accessory.
High-resolution TFT color display.​
Connect your smartphone to your bike via Bluetooth. The 6.5-inch TFT display shows you information about your motorcycle and in conjunction with your smartphone app, additional features such as navigation, music and phone.
Style Exclusive.​
The Style Exclusive package features expressive Mineral Grey Metallic paintwork and premium materials and surfaces. Golden brake calipers and high-quality hardware components complete the stylish look.
Ride Modes Pro.​
Ride Modes Pro now also includes Hill Start Control Pro with automatic brake activation on inclines and Dynamic Brake Assistant (DBC).
2022 BMW R 1250 R Photos​
2022 BMW R 1250 R 2022 BMW R 1250 R 2022 BMW R 1250 R 2022 BMW R 1250 R
2022 BMW R 1250 R Videos​
BMW’s R 1250 R is undeservedly overlooked as a sporting naked.
BMW R1250R SE 2022 – My first review after a week of riding.
BMW Official Websites​
The post 2022 BMW R 1250 R [Specs, Features, Photos] appeared first on webBikeWorld.
