2022 BMW R nineT / Pure / Scrambler / Urban GS [Specs, Features, Photos]
The 2022 BMW R nineT: The Nostalgic Bagger​
The R nineT line of bikes from BMW Motorrad are retro cool, classic standard bikes that stand out thanks to the powerful air/oil-cooled twin-cylinder boxer engine, drawing 109 hp from its 1,170 cc displacement. Power reaches the rear wheel via a shaft drive and a six-speed gearbox.
This European standard comes in 4 variations for the 2022 lineup, Standard nineT, Pure, Scrambler, and Urban G/S, each having unique styling features, but all share LED lighting, Automatic Stability Control (ASC), and selectable ride modes. All versions offer unique 719 paint choices, options like Ride Modes Pro, Cruise Control, and heated grips.
The R nine T is a nimble ride and exudes quality at every touch. Brembo brakes with ABS, Akrapovic exhaust, and the slick single-sided swingarm, each component shows off BMW’s high build quality. The only real choice is to decide which model speaks to your soul.
The 2022 BMW R nineT starts at $15,945 USD / $17,695 CAD.
The 2022 BMW R nineT Pure starts at $10,995 USD / $13,795 CAD.
The 2022 BMW R nineT Scrambler starts at $12,995 USD / $14,995 CAD.
The 2022 BMW R nineT Urban G/S starts at $12,995 USD / $14,995 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 BMW R nine T in one place.
  • Price: $15,945 USD / $17,695 CAD
    • LED headlight and turn signals
    • Dual speed indicator and rational-speed sensor instrument with on-board computer content
    • Automatic Stability Control (ASC)
    • Ride Modes: Rain & Road
    • Drivetrain and final drive black
    • Upside down front fork fully adjustable (spring preload, compression stage rebound)
Main Specs​
  • Engine: 1,170 cc air/oil-cooled 4-stroke flat twin engine
  • Power: 109 HP at 7,250 rpm
  • Torque: 86 lbs-ft at 6,000 rpm
  • Wet Weight: 487 lbs (221 kg)
  • Seat Height: 31.7 in (805 mm)
Competitors​
2022 BMW R nineT / Pure / Scrambler / Urban GS Specifications​
Engine1170cc, Air/oil-cooled two-cylinder, four-stroke boxer engine with two camshafts and four radially-arranged valves per cylinder as well as central counterbalance shaft
Engine Power109 hp at 7,250 rpm
Bore x Stroke4.0” x 2.9”
Compression Ratio12.0 : 1
Fuel deliveryElectronic port fuel injection
Max Torque85.5 lbs-ft. at 6,000 rpm
ClutchSingle dry plate clutch, hydraulically operated
TransmissionClaw-shifted six-speed transmission with helical-cut splines
DriveShaft Drive
Suspension FrontUpside-down telescopic forks, 46 mm fixed-fork-tube diameter
Suspension RearCast aluminum single swing arm with BMW Motorrad Paralever; central spring strut, spring preload fully adjustable by handwheel, adjustable rebound-stage damping
Brakes FrontTwin-disc brakes, diameter 12.6″, 4-piston calipers
Brakes RearSingle disc brake, diameter 10.4″, double-piston floating caliper
Tires Front120/70 ZR 17
Tires Rear180/55 ZR 17
Fuel Tank Capacity4.5 gal.
Color
AlternatorThree-phase alternator with 720 Watt nominal power
Battery12 V / 12 Ah
Headlight
Tail LightLED Tail Light
Length82.9”
Width34.8”
Height48.8”
Wheelbase58.5”
Castor4.3″
Seat Height31.7”
Unladen weight, road ready, fully fueled
487 lbs.
Warranty
2022 BMW R nineT / Pure / Scrambler / Urban GS Features​
Visible type plate​
Unmistakable origins: With its type plate, the R nineT tells you both where it comes from and what it is made of.
Spoked wheels with mudguard holder​
One single unit: The mudguard is screwed onto the fork feet using two forged aluminum brackets.
Twin-cylinder boxer engine​
Striking and reduced: the newly-designed cylinder head cover and throttle body make the engine even more iconic.
Tank and air box cover​
The compact tank including air box cover blends perfectly with the original BMW Motorrad proportions.
Classic dual round instruments​
The analog speedometer and tachometer characterize the cockpit of the R nineT.
Standard dual-flow exhaust system​
The silencer not only completes the typical roadster look, it also delivers a rich sound.
Modern LED turn signal indicators​
The modern LED turn signals ensure you are visible and help keep you safe.
LED headlight​
Modern LED technology meets classic headlight shape, now enhancing visibility– wherever you are riding.
2022 BMW R nineT / Pure / Scrambler / Urban GS Photos​
2022 BMW R nineT / Pure / Scrambler / Urban GS 2022 BMW R nineT / Pure / Scrambler / Urban GS 2022 BMW R nineT / Pure / Scrambler / Urban GS 2022 BMW R nineT / Pure / Scrambler / Urban GS 2022 BMW R nineT / Pure / Scrambler / Urban GS
2022 BMW R nineT / Pure / Scrambler / Urban GS Videos​
BMW R NineT loaded with 719 options will make you fall in love with it.
A Month on BMW R Nine T Scrambler / 2022 Review
BMW Official Websites​
The post 2022 BMW R nineT / Pure / Scrambler / Urban GS [Specs, Features, Photos] appeared first on webBikeWorld.
Looks like a great bike to ride from one coffee shop to another. The minimal seat makes it impractical in my view, just like all modern bikes with such seats.
For the price of the most expensive one, you can get a second hand, a few years old gs1200 which in my view is a better deal. That bike has just as much poser cred.
