The 2022 BMW S 1000 R: Awaken the Daredevil
The Naked bike started amongst the European manufacturers and has grown to become an extremely popular style of motorcycle, proving what I always knew. We all have an inner daredevil waiting to be let loose. To that end, BMW has you covered with the stunning S 1000 R.
The engine of the S 1000 R comes from the super sports bike, tuned for 165hp similar to others in the 2022 lineup, and fitted with an Akrapovic silencer. Weighing in at just 438 lbs, it can be further lightened with the M Package, dropping the wet weight to just 427 lbs.
When ordering there are 3 main packages. The Dynamic package includes the DDC electronic suspension, the Pro Riding Modes, the Pro Gear Shift Assistant, and the engine spoiler. The Comfort package adds keyless ride, a USB charging interface, and adaptive cruise control. Finally the exclusive M Package boasts not only high-level performance thanks to ultra-light M carbon wheels, M Lightweight battery and other M Performance Parts, it also looks great with the iconic M colors and the M cover kit.
3 Color choices for the 2022 BMW S 1000 R: Racing Red, M Package, Style Sport
The 2022 BMW S 1000 R starts at $14,545 USD / $16,500 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 BMW S 1000 R in one place.
- Price: $14,545 USD / $16,500 CAD
- Full LED lighting
- Three Ride Modes (Rain, Road, Dynamic, incl. HSC)
- Six-axis sensor incl. ABS Pro & DTC
- TFT display with connectivity
- Adjustable handlebar position
- Engine: 999cc In-line 4
- Power: 165 hp (121 kW) at 11,000 rpm
- Torque: 84 lb-ft (114 Nm) at 9,250 rpm
- Wet Weight: 438 lbs (199 kg)
- Seat Height: 32.7″ (830 mm)
- Ducati Streetfighter V4S
- KTM Super Duke R
- Kawasaki Z H2
2022 BMW S 1000 R Specifications
Engine | 999cc, Oil/water-cooled four-cylinder four-stroke in-line engine with four valves per cylinder |
Engine Power | 165 hp at 11,000 rpm |
Bore x Stroke | 80 mm x 49.7 mm |
Compression Ratio | 12.5 : 1 |
Fuel delivery | Electronic port fuel injection, BMS-K+ electronic engine management with RPM cut-off, twin-spark ignition: BMS-O with ride by wire. |
Max Torque | 84 lbs-ft. at 9,250 rpm |
Clutch | Multi-disc oil bath (anti-hopping) with self-reinforcement |
Transmission | Synchromesh six-speed gearbox, built into engine housing |
Drive | Chain 525 17/45 |
Suspension Front | Upside-down telescopic fork with a diameter of 1.8”, spring preload and adjustable rebound and compression stage |
Suspension Rear | Aluminum swingarm, central shock absorber, adjustable rebound and compression damping and adjustable spring preload |
Brakes Front | Twin-disc brake with a diameter of 12.6”, four-piston fixed caliper |
Brakes Rear | Single disc brake with a diameter of 8.7”, one-piston floating caliper |
Tires Front | 120/70 ZR 17 |
Tires Rear | 190/55 ZR 17 (200/55 ZR 17) |
Fuel Tank Capacity | 4.4 gal. |
Color | |
Alternator | Permanent magnet generator with 450 W (nominal capacity) |
Battery | 12 V / 8 Ah |
Headlight | |
Tail Light | LED Tail Light |
Overall Length | 82.3” |
Overall Width | 31.9” |
Overall Height | 43.9” |
Wheelbase | 57.0” |
Castor | 3.8” |
Seat Height | 32.7” (OE seat low: 31.9”, OE seat high: 33.5”) |
Unladen weight, road ready, fully fueled | 438.7 lbs. (with M Package including M Carbon Wheels: 427.7 lbs.) |
Warranty | |
Extension |
2022 BMW S 1000 R Features
LED lighting system
Good visibility now comes as standard thanks to LED technology. Available Headlight Pro and Adaptive headlight.Available M Endurance Chain
Improved efficiency with reduced maintenance requirements thanks to a low-friction DLC coating.M Package with M colors
Up to 11 lbs. less weight with available M Forged wheels and an exclusive accompaniment: the iconic M colors.Engine
Superbike splendor meets roadster punch. With torque-optimized 165 hp.M Carbon Wheels
Minimal mass rotation. Maximum agility. And, thanks to thicker brake discs, braking is no issue even on the most challenging tracks in the world.TFT display
6.5 inch and connectivity is standard. With two core screens. And a third in the M Package – like with the RR. Including route planning via the BMW Connected App.Keyless Ride Light
Ready to start at any time. No more searching in your pockets for the key.Titanium Sports Silencer
For a sportier sound and less weight.2022 BMW S 1000 R Photos
2022 BMW S 1000 R Videos
2022 BMW S 1000 R Motorcycle Review: A Full-On Superbike
Why I Chose the 2022 BMW S1000R Sport
BMW Official Websites
The post 2022 BMW S 1000 R [Specs, Features, Photos] appeared first on webBikeWorld.
