The 2022 Can-Am Ryker Sport Edition: Your Ryker for Street Riding
You’ve got to hand it to Can-Am: they’re really trying to offer a three-wheeler for everyone. When it comes to the Can-Am Ryker series, you’ve got the entry-level base model, the Rally Edition for more serious off-roading—and then there’s the new Sport Edition, which is aimed squarely at road riders.
This version of the Ryker features the same 900cc Rotax engine—made in Europe—as the Rally Edition and the larger of the two available vanilla versions, producing 82 hp and 58.5 lb-ft of torque. But the way the engine (and suspension) are tuned makes the machine much friendlier on paved surfaces than either of its siblings—although we also think the relatively plush seat on this model helps.
There’s a “sport” riding mode here too, which will help you go into controlled slides on pavement rather than dirt or gravel—just don’t do it in traffic if you give three wheels about safety. Still, if you’ve ever dreamed of ripping around town on a motorized trike, this is probably the model in the 2022 lineup of Can-Am products you’ll want to check out.
The 2022 Can-Am Ryker Sport Edition starts at $11,599 USD/14,699 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Can-Am Ryker Sport Edition in one place.
Motorcycle Overview
- Price: $11,599 USD / $14,699 CAD
- Sport riding mode
- Upgraded KYB suspension tuned for road riding
- Automatic transmission with reverse mode
- Comfort seat
- Engine: 900cc Rotax three-cylinder engine
- Power: 82 hp
- Torque: 58.3 lb-ft
- Dry Weight: 642 lbs (291 kg)
- Seat Height: 24.7 in (627.4mm)
2022 Can-Am Ryker Sport Edition Specifications
Engine | |
Engine displacement | 900 cc |
Type | Rotax® 900 ACE |
Bore & stroke | 2.9 x 2.7 in. (74 x 69.7 mm) |
Power | 82 hp (61.1 kW) @ 8000 RPM |
Torque | 58.3 ft-lb (79.1 Nm) @ 6500 RPM |
Lubrication | |
Drivetrain | |
Transmission | Automatic (CVT) with reverse function |
Type | Automatic (CVT) with reverse function |
Gears | |
Chassis | |
Suspension Front | Double wishbone |
Suspension Rear | Multi-link – mono swing arm |
Brakes Front | 270 mm discs with Nissin 2-piston floating calipers |
Brakes Rear | 220 mm disc, 1-piston floating caliper |
Tires Front | MC 145/60R16 66T |
Tires Rear | MC 205/45R15 81T |
Fuel Tank Capacity | 5.28 gal (20 L) |
Color | |
Safety and Security | |
ABS | Anti-lock Braking System |
Anti-theft system | |
HHC | Hill Hold Control |
Dimensions | |
L x W x H | 92.6 x 59.9 x 42.2 in. (2,352 x 1,522 x 1,073 mm) |
Wheelbase | 67.3 in. (1,709 mm) |
Seat height | 24.7 in. (629 mm) |
Ground clearance | 4.0 in. (101 mm) |
Dry weight | 642 lb (291 kg) |
Curb Weight | |
Warranty | |
Warranty | 2-year BRP Limited Warranty with 2-year roadside assistance |
Extension | B.E.S.T. extended service term available from 12 to 36 months. |
2022 Can-Am Ryker Sport Edition Features
Features
2 halogen headlamps (55 W)
Front fenders with integrated LED lights
Dual USB port
Glove box
Full rear fender
Sport comfort seat
MAX Mount Structure
Sport style trims and finishes
Cruise control
Rear KYB HPG shock with remote reservoir 4-position compression adjustable damping
Sport mode
2022 Can-Am Ryker Sport Edition Photos
2022 Can-Am Ryker Sport Edition Videos
2022 Can-Am Ryker Sport 900 REVIEW
Can-Am Ryker 900 vs 2022 900 Sport | Ryker Review
Can-Am Websites
The post 2022 Can-Am Ryker Sport Edition [Specs, Features, Photos] appeared first on webBikeWorld.
