The 2022 Can-Am Spyder RT Limited: Above & Beyond Luxury Three-Wheeling
Canadian powersports powerhouse Can-Am developed the RT line to focus specifically on high-performance road touring, and the Spyder RT Limited is one of the most comfortable, luxurious models they offer. That hasn’t changed in 2022—admittedly, little about this machine has since last year, but it still occupies an important place in Can-Am’s 2022 model lineup.
You get all the features of the standard RT with this beast, like the adjustable electronic windshield, additional lumbar support, heated driver grips, UFit footboards, and high-end LED headlights. There’s also the European-manufactured 1330cc Rotax ACE
There are a few features that distinguish the RT Limited from the vanilla RT, though: you get more cargo capacity (thanks to a LinQ-compatible top case), a better sound system (with six speakers instead of the standard four), and a much wider range of color options. Oh, and did we mention the new automatic air adjustment in the SACHS rear shock? That’ll definitely come in handy when your travels take you over bumps in the road.
The 2022 Can-Am Spyder RT Limited starts at $27,499 USD/$33,299 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Can-Am Spyder RT Limited in one place.
Motorcycle Overview
- Price: $27,499 USD/$33,299 CAD
- Adjustable electronic windshield & automatic air adjustment in rear suspension
- Extra lumbar support & heated driver grips
- LinQ-compatible luggage including top case with 47 gallons (177L) of capacity
- Bluetooth-compatible BRP six-speaker keypad-controllable sound system
- Engine: 1330cc Rotax ACE
- Power: 115 hp
- Torque: 96 lb-ft
- Dry Weight: 1021 lbs (463 kg)
- Seat Height: 29.7 in (754.4mm)
2022 Can-Am Spyder RT Limited Specifications
Engine | |
Engine displacement | 1330 cc |
Type | Rotax® 1330 ACE |
Bore & stroke | 3.31 x 3.14 in. (84 x 80 mm) |
Power | 115 hp (85.8 kW) @ 7,250 RPM |
Torque | 96 lb-ft. (130.1 Nm) @ 5000 RPM |
Lubrication | |
Drivetrain | |
Transmission | SE6 |
Type | Semi-automatic with reverse function |
Gears | 6-speed |
Chassis | |
Suspension Front | Double A-arms with anti-roll bar |
Suspension Rear | Swing-arm |
Brakes Front | 270 mm discs with Brembo† 4-piston fixed calipers |
Brakes Rear | 270 mm disc, 1-piston floating caliper with integrated parking brake |
Tires Front | MC165/55R15 55H |
Tires Rear | MC225/50R15 76H |
Fuel Tank Capacity | 7 gal (26.5 L) |
Color | |
Safety and Security | |
ABS | Anti-lock Braking System |
Anti-theft system | Digitally Encoded Security System (D.E.S.S. |
HHC | Hill Hold Control |
Dimensions | |
L x W x H | 111.5 x 61.2 x 57.6 in. (2,833 x 1,554 x 1,464 mm) |
Wheelbase | 67.5 in. (1,714 mm) |
Seat height | 29.7 in. (755 mm) |
Ground clearance | 4.5 in. (115 mm) |
Dry weight | 1,021 lb (464 kg) |
Curb Weight | |
Warranty | |
Warranty | 2-year BRP Limited Warranty with 2-year roadside assistance |
Extension | B.E.S.T. extended service term available from 12 to 36 months. |
2022 Can-Am Spyder RT Limited Features
Features
Premium LED headlights
Rider Touring Floorboards
Adjustable passenger footboards
Ultra comfortable limited seat with lumbar support
Audio control keypad
Glove box with USB
Cruise control
Integrated hard-side luggage
Adjustable Electric Windshield with Memory
Calibrated for towing a Can-Am trailer
Signature LED lights
Driver and passenger heated grips
Driver and passenger heated seats
LinQ compatible top case with passenger backrest
2022 Can-Am Spyder RT Limited Photos
2022 Can-Am Spyder RT Limited Videos
2022 Can-Am Spyder RT Limited Review | MC Commute
2022 RT-LTD Test Ride!! • An Epic Can-Am Spyder! | TheSmoaks Vlog_2367
Can-Am Websites
The post 2022 Can-Am Spyder RT Limited [Specs, Features, Photos] appeared first on webBikeWorld.
