2022 Ducati Icon Dark [Specs, Features, Photos]
The 2022 Ducati Scrambler Icon Dark Is Unconventional But Fashionable​
Introduced back in 2020, the Ducati Scrambler Icon Dark remains unchanged for the 2022 Ducati lineup. The Italian Manufacturer still kept the Icon Dark as the most affordable Icon in Ducati Motorcycles range. It’s a base-model Scrambler but it still has plenty of character of its own.
Underneath the Icon Dark’s sleek matte black exterior, it features an 803cc air-cooled Desmodromic L-twin engine, the same powerhouse found on most Ducati Scrambler models. Which produces 73 horsepower at 8,250 rpm and 48.8 lb-ft of torque.
“Don’t judge a book by its price”, said no one ever. Despite the budget price structure, the Icon Dark still gets some nice features including premium LED lighting with DRL, a brand new seat for greater comfort, compatibility with Ducati’s Multimedia System, new hydraulic clutch control, new switch gears, and dual-channel cornering ABS from Bosch.
The matted blacked-out aesthetics and interchangeable brushed aluminum side panels, make it the perfect platform to create a personalized version of the Ducati Scrambler.
The 2022 Ducati Icon Dark starts at MSRP: $8,995 USD / $10,995 CDN
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Ducati Icon Dark in one place.
  • Price:
    • 2022 Ducati Icon Dark MSRP: $8,995 USD / $10,995 CDN
    • Dual-channel cornering ABS from Bosch
    • Premium LED headlight with glass lens and DRL
    • Ducati Multimedia System
    • Improved seat for rider and passenger comfort
    • Hydraulic clutch control
Main Specs​
  • Engine: 803 cc, L-Twin cylinder
  • Power: 73 HP
  • Torque: 48.8 lb-ft
  • Dry Weight: 381 lbs (173 kg)
  • Seat Height: 31.4 in (798 mm)
Competitors​
  • Triumph Street Twin
  • Husqvarna 701 Svartpilen
2022 Ducati Icon Dark Specifications​
Engine803cc, L-Twin, Desmodromic distribution, 2 valves per cylinder, air cooled
Power73 Hp
Bore x Stroke88 x 66 mm
Compression Ratio11:1
Fuel InjectionElectronic fuel injection, 50 mm throttle body
ExhaustExhaust system with single stainless steel muffler, aluminium silencer cover, catalytic converter and 2 lambda probes
Torque6,7 Kgm (66,2 Nm) @ 5750 rpm
ClutchHydraulically controlled slipper and self-servo wet multiplate clutch
Transmission6 speed
Final DriveChain, front spocket 15, rear sprocket 46
Suspension FrontUpside down Kayaba 41 mm fork
Suspension RearKayaba rear shock, pre-load adjustable.
Brakes FrontØ330 mm disc, radial 4-piston calliper with Bosch Cornering ABS as standard equipment
Brakes RearØ245 mm disc, 1-piston floating calliper with Bosch Cornering ABS as standard equipment
Tires FrontPirelli MT 60 RS 110/80 R18
Tires RearPirelli MT 60 RS 180/55 R17
Fuel Tank Capacity13,5 l – 3,57 gallon (US)
ColorBlack
Ignition
HeadlightLED
Max Length2.100 – 2.165 mm (82.7 – 85.2 in)
Max Width855 mm (33,7 in) (mirrors)
Max height1.150 mm (45,3 in) (brake reservoir)
Wheelbase1.445 mm (56.9 in)
Rake24°
Trail112 mm (4,4 in)
Seat Height798 mm (31,4 in) – low seat 778 mm (30,6 in) available as accessory
Dry Weight173 kg (381 lb)
Warranty24 months, Unlimited mileage
2022 Ducati Icon Dark Features​
Riding Comfort​
A brand new seat, flatter and comfortable for the rider and the passenger. Improved suspension set-up.
Engine​
New finishing touches to the engine: black cylinder heads and brushed aluminium fins.
Improved Safety​
Dual-channel Bosch Cornering ABS.
Premium LED Lighting​
Headlight with glass lens and DRL.
Improved Riding Experience​
Ducati Multimedia System ready. Selected gear indicator and fuel level. Handlebar switch controls. Hydraulic clutch control with adjustable lever.
Style Details​
New Matt Black colour. Machine-finished aluminium belt covers. Interchangeable aluminium side panels for the highest degree of personalization.
2022 Ducati Panigale V4 R Photos​
2022 Ducati Icon Dark 2022 Ducati Icon Dark 2022 Ducati Icon Dark 2022 Ducati Icon Dark
2022 Ducati Panigale V4 R Videos​
The post 2022 Ducati Icon Dark [Specs, Features, Photos] appeared first on webBikeWorld.
