The 2022 Harley Davidson Freewheeler: Make It Yours
The Freewheeler is a popular choice for those wanting to stay with an American-made 3-wheeled hot rod..
One of 3 in the 2022 Harley Davidson lineup, the Freewheeler packs The Milwaukee-Eight® 114 engine pounds and its 118 lbs-ft of torque. Setup for owners to customize, Harley Davidson smartly provides gear such as Reflex
3 Color choices for the 2022 Harley Davidson Freewheeler: Vivid Black, Reef Blue, and Midnight Crimson/Vivid Black
The 2022 Harley Davidson Freewheeler starts at $28,499 USD / $34,599 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson Freewheeler in one place.
- Price: $28,499 USD / $34,599 CAD
- Milwaukee-Eight® 114 V-Twin engine
- Brembo ABS Brakes
- 12” Mini Apes
- Optional RDRS
- Engine: 114 ci V-twin
- Power: 100.5 HP (estimated)
- Torque: 118 lbs-ft @ 3000 RPM
- Wet Weight: 1,118 lb. (507 kg)
- Seat Height: 26.2 in. (665 mm)
- Can-Am Spyder F3
- Polaris Slingshot
- Ural Gear Up
2022 Harley Davidson Freewheeler Specifications
Engine | Milwaukee-Eight® 114 |
Engine Torque | 122 ft-lb |
Bore x Stroke | 4.016 in.X 4.5 in. |
Compression Ratio | 10.5:1 |
Fuel System | Electronic Sequential Port Fuel Injection (ESPFI) |
Starter | |
Exhaust | Shorty slash down-style chrome finish mufflers |
Clutch | |
Transmission | 6-speed |
Primary Drive | Chain, 34/46 ratio |
Front Fork | 49mm dual bending valve |
Rear Shocks | Hand-adjustable emulsion rear suspension |
Wheels, Front Type | Enforcer Cast Aluminum |
Wheels, Rear Type | Enforcer Cast Aluminum |
Brakes Front | 32mm 4 piston fixed Dual floating rotors |
Brakes Rear | Floating 36mm piston integrated park brake |
Tires Front | MT 130/60B19 M/C 61H |
Tires Rear | P205/65R15 |
Fuel Tank Capacity | 6 gal. |
Color | |
Ignition | |
Headlight | All LED headlamp |
Tail Light | LED |
Length | |
Trail | 3.96 in. |
Rake | 26 |
Wheelbase | 65.7 in. |
Ground Clearance | 4.9 in. |
Seat Height | 26.2 in. |
Weight, As Shipped | 1,085 lb. |
Warranty | |
Extension |
2022 Harley Davidson Freewheeler Features
MILWAUKEE-EIGHT® 114 ENGINE
The most displacement in standard H-D® Touring models. You get 114 cubic inches of passing and horizon-chasing power.REFLEX
LINKED BREMBO® BRAKES WITH STANDARD ABS
Designed to help prevent the wheels from locking under braking to assist the rider in maintaining control when braking in a straight-line. ABS operates independently on front and rear brakes to keep the wheels rolling and help prevent uncontrolled wheel lock in urgent situations.HIGH PERFORMANCE SUSPENSION
Premium Harley-Davidson touring suspension technology is calibrated specifically for Trike models, delivering a smooth and responsive ride.BOBTAIL REAR FENDERS
The pair of Harley-Davidson® bobtail rear fenders give the bike classic cruiser lines and styling details.ENFORCER CAST ALUMINUM WHEELS
There’s an Enforcer front wheel leading the way, and you’ve got two more to match in the back. Up front, the brake rotors have been redesigned to show off more of the premium custom look of the wheels.7-PIECE NACELLE
A classic style chrome headlight nacelle is tucked tight against the frame and forks for a tighter, smaller look. It also accommodates a clean-looking windshield mounting system.UNIQUE TRUNK SYSTEM
It’s a one-of-a-kind design that opens left to right (with one hand) and extends the entire length of the body for a clean look. Enough cargo space to easily accommodate two full-face helmets.2022 Harley Davidson Freewheeler Photos
2022 Harley Davidson Freewheeler Videos
2022 Born Free Builds: Speed Kings’ Harley Davidson Freewheeler Trike
Harley-Davidson Official Websites
The post 2022 Harley Davidson Freewheeler [Specs, Features, Photos] appeared first on webBikeWorld.
