2022 Harley Davidson Road Glide Limited [Specs, Features, Photos]
The 2022 Harley Davidson Road Glide Limited: The Touring Icon
With a bike this good, no significant changes were need from Harley Davidson. The Road Glide Limited has everything one could want to make a great 2-up touring ride.
Shared across the 2022 Harley Davidson lineup, the powerful Milwaukee-Eight® 114 engine has 119 lbs-ft of torque to move the Limited with ease, even laden down with gear and humans. The Sharknose fairing looks just right and shows the American Bagger roots at the heart of this bike.
The Tour-Pak
luggage provides ample space that can easily house both rider and passenger helmets along with extra travel essentials. The Road Glide Limited is loaded with features like heated grips, cruise control, and awesome floorboards. The Reflex
Defensive Rider System is an option, but let’s face it, you know you are adding those very useful electronic rider aids, they are well worth it.
Get your gear, crank up the Boom!
Box GTS Infotainment System, and point yourself down the highway..
6 Color choices for the 2022 Harley Davidson Road Glide Limited:
  • Reef Blue / Black Denim – Black Finish
  • Gunship Gray – Black Finish
  • Vivid Black – Black Finish
  • Gauntlet Gray Metallic / Vivid Black – Chrome Finish
  • Mineral Green Metallic – Chrome Finish
  • Vivid Black – Chrome Finish
The 2022 Harley Davidson Road Glide Limited starts at $28,729 USD / $34,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson Road Glide Limited in one place.
  • Price: $28,729 USD / $34,999 CAD
    • Milwaukee-Eight® 114 V-Twin engine
    • Dual Daymaker LED Headlights
    • Two-Tone Paint Options
    • Optional RDRS Electronics Package
Main Specs​
  • Engine: 114 ci V-twin
  • Power: 100.5 HP (estimated)
  • Torque: 119 lbs-ft @ 3000 RPM
  • Wet Weight: 932 lb. (423 kg)
  • Seat Height: 27.2 in. (690 mm)
Competitor​
2022 Harley Davidson Road Glide Limited Specifications​
EngineTwin-Cooled
Engine Torque122 ft-lb
Bore x Stroke4.016 in. x 4.5 in.
Compression Ratio
10.5:1
Starter
Exhaust2:1:2 dual exhaust with 4 in. tapered mufflers
Clutch
Transmission6-speed
Primary Drive
Gear, 34/46 ratio
Front Fork
49mm Dual Bending Valve
Rear Shocks
Premium standard height hand-adjustable rear suspension
Wheels, Front Type
Slicer II cast aluminum with clear coat
Wheels, Rear Type
Brakes Front
32 mm, Dual floating rotors
Brakes Rear4-piston fixed
Tires Front
BW 130/70B18 63H
Tires Rear
BW 180/55B18 80H
Fuel Tank Capacity6 gal.
ColorVivid Black (Chrome Finish), Mineral Green Metallic (Chrome Finish),Gauntlet Gray Metallic/Vivid Black (Chrome Finish),Vivid Black (Black Finish),Reef Blue/Vivid Black (Black Finish)
Ignition
HeadlightAll LED headlamp
Length
102.2 in.
Trail
6.7 in.
Rake26
Wheelbase
64 in.
Ground Clearance
5.1 in.
Seat Height
27.2 in.
Weight, As Shipped
897 lb.
Warranty
2022 Harley Davidson Road Glide Limited Features​
MILWAUKEE-EIGHT® 114 ENGINE​
The most displacement in standard H-D® Touring models. You get 114 cubic inches of passing and horizon-chasing power.
REFLEX
LINKED BREMBO® BRAKES WITH STANDARD ABS​
Designed to help prevent the wheels from locking under braking to assist the rider in maintaining control when braking in a straight-line. ABS operates independently on front and rear brakes to keep the wheels rolling and help prevent uncontrolled wheel lock in urgent situations.
BOOM!
BOX GTS INFOTAINMENT SYSTEM​
An evolved interface experience that offers a contemporary look, feel and function, with exceptional durability and features designed specifically for motorcycling. Every element is optimized to enhance the rider’s interaction with the bike and connectivity with the world.
FRAME-MOUNTED SHARK NOSE FAIRING​
A distinctive aerodynamic shark-nose fairing with triple split stream vents that deliver smooth air flow and reduce head buffeting.
HEATED HANDGRIPS​
Equipped with six settings, so you can easily adjust on the fly for the heat you need.
RESPONSIVE SUSPENSION​
High-performing front and rear suspension with easily adjustable rear shocks put you in control of a plush ride.
PREMIUM TOUR-PAK® LUGGAGE CARRIER​
A sleek yet spacious Tour-Pak® luggage carrier with luggage rack that can easily house both rider and passenger helmets along with extra travel essentials.
2022 Harley Davidson Road Glide Limited Photos​
2022 Harley Davidson Road Glide Limited 2022 Harley Davidson Road Glide Limited 2022 Harley Davidson Road Glide Limited 2022 Harley Davidson Road Glide Limited
2022 Harley Davidson Road Glide Limited Videos​
New 2022 Harley Davidson Road Glide Limited Motorcycle | 10 Things to Know:
The post 2022 Harley Davidson Road Glide Limited [Specs, Features, Photos] appeared first on webBikeWorld.
