The 2022 Harley Davidson Road Glide Special: Blacked-out or Bright
The Road Glide Special is the sweet spot in the 2022 Harley Davidson lineup for fans of a frame-mounted fairing, badass all-American bagger.
Harley Davidson knows just how popular this bike is to the riding public and they make sure to load it with the most desirable options. Starting with the Milwaukee-Eight® 114 which makes 100 HP and 119 lbs-ft of torque. Then add in the Reflex
Good luck choosing between the 5 stunning paint schemes, with either chrome or blacked-out finishes. The Road Glide Special is everything I envision a bad-ass Bagger should be.
10 Color choices for the 2022 Harley Davidson Road Glide Special:
- Vivid Black – Black Finish
- Redline Red – Black Finish
- Gunship Gray – Black Finish
- White Sand Pearl – Black Finish
- Reef Blue/Vivid Black – Black Finish
- Vivid Black – Chome Finish
- Black Denim – Chome Finish
- Gunship Gray – Chome Finish
- White Sand Pearl – Chome Finish
- Reef Blue/Vivid Black – Chome Finish
The 2022 Harley Davidson Road Glide Special starts at $27,449 USD / $33,599 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson Road Glide Special in one place.
- Price: $27,449 USD / $33,599
- Milwaukee-Eight® 114 V-Twin engine
- Prodigy Wheels
- HD Connect
- Two-Tone Paint Option
- Optional RDRS Electronics Package
- Engine: 114 ci V-twin
- Power: 100.5 HP (estimated)
- Torque: 119 lbs-ft @ 3000 RPM
- Wet Weight: 853 lb. (387 kg)
- Seat Height: 25.9 in. (658 mm)
- Indian Challenger Limited
- Goldwing DCT
- Kawasaki Vulcan 1700 Vaquero ABS
2022 Harley Davidson Road Glide Special Specifications
Engine | Milwaukee-Eight® 114 |
Engine Torque | 118 ft-lb |
Bore x Stroke | 4.016 in x 4.5 in. |
Compression Ratio | 10.5:1 |
Fuel System | Electronic Sequential Port Fuel Injection (ESPFI) |
Starter | |
Exhaust | 2-1-2 dual exhaust with tapered mufflers |
Clutch | |
Transmission | 6-speed |
Primary Drive | Gear, 34/46 ratio |
Front Fork | 49mm Dual Bending Valve |
Rear Shocks | Premium Low Hand-Adjustable Rear Suspension |
Wheels, Front Type | Gloss Black Prodigy |
Wheels, Rear Type | Gloss Black Prodigy |
Brakes Front | Dual floating rotors 32 mm |
Brakes Rear | 4-piston fixed |
Tires Front | 130/60B19 61H |
Tires Rear | 180/55B18 80H |
Fuel Tank Capacity | 6 gal. |
Color | Vivid Black (Chrome Finish), Black Denim (Chrome Finish), Gunship Gray (Chrome Finish),White Sand Pearl (Chrome Finish),Reef Blue/Vivid Black (Chrome Finish),Redline Red (Black Finish),White Sand Pearl (Black Finish),Reef Blue/Vivid Black (Black Finish) |
Ignition | |
Headlight | All LED headlamp |
Tail Light | LED |
Length | 95.7 in. |
Trail | 6.8 in. |
Rake | 26 |
Wheelbase | 64 in. |
Ground Clearance | 5.1 in. |
Seat Height | 26.1 in. |
Weight, As Shipped | 818 lb. |
Warranty | |
Extension |
2022 Harley Davidson Road Glide Special Features
MILWAUKEE-EIGHT® 114 ENGINE
The most displacement in standard H-D® Touring models. You get 114 cubic inches of passing and horizon-chasing power.REFLEX
LINKED BREMBO® BRAKES WITH STANDARD ABS
Designed to help prevent the wheels from locking under braking to assist the rider in maintaining control when braking in a straight-line. ABS operates independently on front and rear brakes to keep the wheels rolling and help prevent uncontrolled wheel lock in urgent situations.BOOM!
BOX GTS INFOTAINMENT SYSTEM
An evolved interface experience that offers a contemporary look, feel and function, with exceptional durability and features designed specifically for motorcycling. Every element is optimized to enhance the rider’s interaction with the bike and connectivity with the world.STRETCHED SADDLEBAGS
A sleek look on the outside and roomy on the inside with more than enough space to stash your riding essentials. The lids open with a single touch of one hand.2022 Harley Davidson Road Glide Special Photos
2022 Harley Davidson Road Glide Special Videos
2022 Harley Road Glide Special ride and review:
2022 Road Glide Special Ride And Review [Plus 0-60 Times]:
Harley-Davidson Official Websites
The post 2022 Harley Davidson Road Glide Special [Specs, Features, Photos] appeared first on webBikeWorld.
