2022 Harley Davidson Road Glide [Specs, Features, Photos]
The 2022 Harley Davidson Road Glide: Still The Benchmark
There is no mistaking a Harley Davidson Road Glide coming down the highway at you. The classic “Sharknose” fairing is legendary, and the stance is pure American bagger attitude.
Unchanged from last year’s model, this is the first Road Glide, in the 2022 Harley Davidson lineup. Power comes from the Milwaukee-Eight® 107 engine and one-touch opening hard bags, Dual Daymaker
Reflector Led Headlamps, and floorboards are all standard. The Reflex
Defensive Rider Systems collection of technologies is optional.
With 110 lbs-ft of torque on tap, cruising the boulevard or interstate feels effortless. The high-performing front and rear suspension with easily adjustable rear shocks put you in control of a plush ride, and the standard Brembo ABS brakes can always safely bring you to a halt.
3 Color choices for the 2022 Harley Davidson Road Glide: Vivid Black, Reef Blue, and White Sand Pearl
The 2022 Harley Davidson Road Glide starts at $22,249 USD / $26,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson Road Glide in one place.
  • Price: $22,249 USD / $26,999 CAD
    • Milwaukee-Eight® 107 V-Twin engine
    • Standard Brembo ABS
    • Floorboards
    • Boom!
      Box Gts Infotainment System
Main Specs​
  • Engine: 107 ci V-twin
  • Power: 92.5 HP (estimated)
  • Torque: 110 lbs-ft @ 3000 RPM
  • Wet Weight: 855 lbs (388 kg)
  • Seat Height: 25.9 inches (695 mm)
Competitors​
2022 Harley Davidson Road Glide Specifications​
EngineMilwaukee-Eight® 107
Engine Torque111 ft-lb
Bore x Stroke3.937 in. X 4.375 in.
Compression Ratio
10.0:1
Starter
ExhaustChrome, 2-1-2 dual exhaust with tapered mufflers
Clutch
Transmission6-speed
Primary Drive
Gear, 34/46 ratio
Front Fork
49mm Dual Bending Valve
Rear Shocks
Premium Low Hand-Adjustable Rear Suspension
Wheels, Front Type
Enforcer II Cast Aluminum
Wheels, Rear Type
Brakes Front
32 mm, Dual floating rotors (front)
Brakes Rear4-piston fixed
Tires Front
130/60B19 61H
Tires Rear
BW 180/55B18 80H
Fuel Tank Capacity6 gal.
ColorVivid Black, Reef Blue, White Sand Pearl
Ignition
HeadlightAll LED headlamp
Length
95.7 in.
Trail
6.8 in.
Rake26
Wheelbase
64 in.
Ground Clearance
5.5 in.
Seat Height
25.9 in.
Weight, As Shipped
820 lb.
Warranty
2022 Harley Davidson Road Glide Features​
MILWAUKEE-EIGHT® 107 ENGINE​
A powerful, smooth-running engine with crisp throttle response and a pure, soul-satisfying rumble.
REFLEX
LINKED BREMBO® BRAKES WITH STANDARD ABS​
Designed to help prevent the wheels from locking under braking to assist the rider in maintaining control when braking in a straight-line. ABS operates independently on front and rear brakes to keep the wheels rolling and help prevent uncontrolled wheel lock in urgent situations.
FRAME-MOUNTED SHARK NOSE FAIRING​
A distinctive, menacing, mile-hungry design that cuts through the wind like no other fairing in the world.
BOOM!
BOX GTS INFOTAINMENT SYSTEM​
An evolved interface experience that offers a contemporary look, feel and function, with exceptional durability and features designed specifically for motorcycling. Every element is optimized to enhance the rider’s interaction with the bike and connectivity with the world.
RESPONSIVE SUSPENSION​
High-performing front and rear suspension, with easily hand-adjustable rear shocks put you in control of a plush ride.
2022 Harley Davidson Road Glide Photos​
2022 Harley Davidson Road Glide 2022 Harley Davidson Road Glide 2022 Harley Davidson Road Glide
2022 Harley Davidson Road Glide Videos​
Watch This Before You Buy! 2022 Harley Davidson Road Glide Everything You Need To Know:
2022 Harley-Davidson Road Glide:
The post 2022 Harley Davidson Road Glide [Specs, Features, Photos] appeared first on webBikeWorld.
