2022 Harley Davidson Road Glide ST [Specs, Features, Photos]
The 2022 Harley Davidson Road Glide ST: 117 Kinds Of Perfect!
The Road Glide ST is the machine many have been aching for Harley Davidson to send us. Everything has been blacked out for a menacing look that never lets you forget that this Road Glide is packing the Milwaukee-Eight® 117 and 126 lbs-ft of torque. Front tire size is 19 inches and the rear stays at 18 inches. With the overall clearances being higher, and this tire combination, the ST should feel more nimble than other Road Glide models in the 2022 Harley Davidson lineup.
This epic American bagger has 2.3 cu/ft saddlebags with one-touch opening. The bags are the smaller set which sits a bit higher for a bit more clearance. The only option available is the package of Cornering Rider Safety Enhancements. Sit back behind the sick-looking Shark Nose frame-mounted fairing, turn up the Boom! Box GTS infotainment system and just roll.
2 Color choices for the 2022 Harley Davidson Road Glide ST: Vivid Black, or Gunship Gray
The 2022 Harley Davidson Road Glide ST starts at $29,999 USD / $36,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson Road Glide ST in one place.
  • Price: $29,999 USD / $36,999 CAD
    • Milwaukee-Eight® 117 V-Twin engine
    • Bronze Prodigy Wheels
    • Boom! Box GTS infotainment system
    • Optional RDRS Electronics Package
Main Specs​
  • Engine: 117 ci V-twin
  • Power: 103 HP (estimated)
  • Torque: 126 lbs-ft @ 3750 RPM
  • Wet Weight: 842 lb. (382 kg)
  • Seat Height: 26.7 in. (715 mm)
Competitors​
2022 Harley Davidson Road Glide ST Specifications​
EngineMilwaukee-Eight® 117
Engine Torque127 ft-lb
Bore x Stroke4.075 in. x 4.5 in.
Compression Ratio
10.2:1
Starter
ExhaustDual, with crossover
Clutch
Transmission6-speed
Primary Drive
Gear, 34/46 ratio
Front Fork
49mm Dual Bending Valve
Rear Shocks
Premium standard height hand-adjustable rear suspension
Wheels, Front Type
Bronze Prodigy
Wheels, Rear Type
Bronze Prodigy
Brakes Front
32mm Dual floating rotors
Brakes Rear4-piston fixed
Tires Front
130/60B19 61H
Tires Rear
BW 180/55B18 80H
Fuel Tank Capacity6 gal.
Color
Ignition
HeadlightAll LED headlamp
Length
94.7 in.
Trail
6.7 in.
Rake26
Wheelbase
64 in.
Ground Clearance
5.5 in.
Seat Height
26.7 in.
Weight, As Shipped
Vivid Black, Gunship Gray
Warranty
2022 Harley Davidson Road Glide ST Features​
MILWAUKEE-EIGHT® 117 V-TWIN​
The new pinnacle of torque and displacement with a factory-installed powertrain. Precision oil/air cooling. 126 ft. lbs. of torque at 3750 RPM. Tuned heavy breather intake and high flow exhaust maximize engine performance, a boost you can feel with every twist of the throttle.
West Coast Styling​
BLACKED OUT EVERYTHING
Front end, controls, powertrain and exhaust. The only bright bits are pushrod tubes and tappet covers, and machined cylinder fins.
SPORT TOURING PROFILE
Standard bag height for a trimmed look and more room to lean.
FIXED SHARKNOSE FAIRING
This frame-mounted fairing keeps the cross-winds and traffic buffeting at bay, with a design that is unmistakably Harley-Davidson.
STANDARD FEATURES​
  • Standard Anti-Lock Braking System (ABS)
  • Boom! Box GTS infotainment system with color touch screen, two fairing-mount speakers and hidden radio antenna
  • Emulsion-technology rear shocks, with a single knob to hydraulically adjust pre-load for optimal ride and control
  • 49mm forks with dual bending valve suspension technology
  • Daymaker LED headlamps
  • Smart Security System with proximity-based, hands-free security fob
OPTIONAL CORNERING RIDER SAFETY ENHANCEMENTS​
  • Cornering Electronically Linked Brakes
  • Cornering-ABS
  • Cornering-Traction Control with modes
  • Drag Torque Slip Control
  • Vehicle Hold Control
  • Tire Pressure Monitoring (TPMS)
2022 Harley Davidson Road Glide ST Photos​
2022 Harley Davidson Road Glide ST 2022 Harley Davidson Road Glide ST 2022 Harley Davidson Road Glide ST 2022 Harley Davidson Road Glide ST
2022 Harley Davidson Road Glide ST Videos​
Harley Davidson Road Glide ST Test Ride!
Review – 2022 Road Glide ST:
The post 2022 Harley Davidson Road Glide ST [Specs, Features, Photos] appeared first on webBikeWorld.
