The 2022 Harley Davidson Sportster S: The Legacy Continues
Introduced last year and showcasing a new direction for the legendary American-made Sportster, the bike is largely unchanged coming into 2022.
The Revolution Max 1250T engine is a liquid-cooled V-Twin putting out 121hp and a fat torque curve set to add a good stretch to your arms upon a full twist of the throttle. Running a reasonably fat tire both front and rear makes this the most muscular-looking Sportster.
Harley Davidson always nails the details, and on the Sportster S for me, it is the Bronze touches. One of the few models in the 2022 Harley model lineup that takes advantage of modern electronics, the Sportster S has selectable rider modes and lean-sensitive ABS and traction control.
3 color choices exist for the 2022 Harley Davidson Sportster S: Vivid Black, Mineral Green Metallic, and White Sand Pearl.
The 2022 Harley Davidson Sportster S starts at $15,499 USD / $18,499 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson Sportster S in one place.
- Price: $15,499 USD / $18,499 CAD
- Revolution Max Engine
- High Mount Exhaust
- Selectable Rider Modes
- Lean-Sensitive ABS and Traction Control
- Engine: 1,252 cc V-twin
- Power: 121 HP / 90 kW @ 7500 rpm
- Torque: 94 ft-lb (127 Nm)
- Wet Weight: 502 lb. (228 kg)
- Seat Height: 30.1 in. (765 mm)
- Ducati Diavel 1260 S
- Indian FTR S
- Suzuki M109R
2022 Harley Davidson Sportster S Specifications
Engine | 1,252 cc V-twin, Revolution® Max 1250T |
Engine Torque | 94 ft-lb |
Bore x Stroke | 4.134 in. x 2.846 in |
Compression Ratio | 12.0:1 |
Fuel System | Electronic Sequential Port Fuel Injection (ESPFI) |
Exhaust | 2-into-1-into-2; catalyst in muffler |
Clutch | |
Transmission | 6-speed |
Primary Drive | Gear, 49/89 ratio |
FRONT FORK | 43 mm inverted fork with compression, rebound and spring preload adjustability. Aluminum fork triple clamps. |
REAR SHOCKS | Linkage-mounted, piggyback monoshock with compression, rebound and hydraulic spring preload adjustability |
Brakes Front | radially mounted, monoblock, 4-piston caliper |
Brakes Rear | floating, single piston caliper |
Front Tires | 160/70R17 73V |
Rear Tires | 180/70R16 77V |
Fuel Tank Capacity | 3.1 gal |
Color | |
Ignition | |
Headlight | All LED headlamp |
Tail Light | LED |
Length | 89.4 in. |
Trail | 5.8 in |
Rake | 30 |
Wheelbase | 59.8 in. |
Ground Clearance | 3.5 in. |
Seat Height | 28.9 in |
Weight, As Shipped | 487 lb. |
Warranty | |
Extension |
2022 Harley Davidson Sportster S Features
All-new Revolution Max 1250T
The next chapter in a century of legendary V-Twins is here. Revolution Max is a liquid-cooled powertrain with double overhead camshafts and variable valve timing: offering ample torque and an immediate powerband tuned to maximize rider control.High Mount Exhaust
Inspired by the glory days of H-D flat-track racing, the pipes are crafted from corrosion-resistant 304-series stainless steel and engineered to deflect exhaust heat away from the rider’s legs and tail section.Classic Meets Modern: 4” Round Display
Everything you need to know is housed in a Bluetooth -equipped, 4” round thin-film transistor LCD display: digital gauges, indicators, ride modes, and turn-by-turn navigation with the Harley-DavidsonChoose Your Ride Mode
Flick a switch and choose from 3 pre-programmed Ride Modes (Sport, Road, and Rain) or create your own custom mode — tuning your bike with a specific combination of power delivery, engine braking, Cornering Enhanced Antilock Braking System (C-ABS) and Cornering Enhanced Traction Control System (C-TCS) settings.Dual Purpose Powertrain
The Revolution Max 1250T is a structural component of the motorcycle chassis, eliminating a traditional frame — which significantly reduces overall weight and keeps handling precise. This is performance you can feel, with the center of gravity low and the chassis super rigid.2022 Harley Davidson Sportster S Photos
2022 Harley Davidson Sportster S Videos
2022 Harley Davidson Sportster S | First Ride:
Don’t buy a Sportster S until you ride a Fat Bob:
Harley-Davidson Official Websites
The post 2022 Harley Davidson Sportster S [Specs, Features, Photos] appeared first on webBikeWorld.
