2022 Harley Davidson Tri Glide Ultra [Specs, Features, Photos]
The 2022 Harley Davidson Tri Glide Ultra: Oh So Extra!​
One of 3 Trikes in the 2022 Harley Davidson lineup, the Tri Glide Ultra packs The Milwaukee-Eight® 114 engine pounds and its 118 lbs-ft of torque. Behind the iconic Batwing fairing, the rider is treated to Reflex
linked brakes with ABS, an all-new 4-speaker BOOM!
GTS infotainment system, electronic cruise control, and 6.8 cubic feet of storage space.
The Tri Glide showcases Harley Davidson’s high level of build quality with premium paint finishes including two-tone options, Daymaker® LED headlamp and LED fog lamps, and unique Tomahawk
wheels. This American-made machine is set for the long haul.
3 Color choices for the 2022 Harley Davidson Tri Glide Ultra: Vivid Black, Gauntlet Gray Metallic / Vivid Black, Midnight Crimson / Vivid Black.
The 2022 Harley Davidson Tri Glide Ultra starts at $35,699 USD / $43,799 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson Tri Glide Ultra in one place.
  • Price: $35,699 USD / $43,799 CAD
    • Milwaukee-Eight® 114 V-Twin engine
    • Brembo ABS Brakes
    • Tour-Pak
      storage
    • Traction Control
Main Specs​
  • Engine: 114 ci V-twin
  • Power: 100.5 HP (estimated)
  • Torque: 118 lbs-ft @ 3000 RPM
  • Wet Weight: 1,243 lb. (564 kg)
  • Seat Height: 27.1 in. (688 mm)
Competitors​
2022 Harley Davidson Tri Glide Ultra Specifications​
EngineTwin-Cooled
Engine Torque100.5 HP
Bore x Stroke4.016 in. X 4.5 in.
Compression Ratio
10.5:1
Starter
Exhaust2-1-2 dual exhaust with tapered mufflers
Clutch
Transmission6-speed
Primary Drive
Chain, 34/46 ratio
Front Fork
49mm dual bending valve
Rear Shocks
Hand-adjustable emulsion rear suspension
Wheels, Front Type
Black, 7-spoke Cast Aluminum
Wheels, Rear Type
Brakes Front
Dual floating rotors, 32mm 4 piston fixed
Brakes Rearfloating 36mm piston integrated park brake
Tires Front
MT90B16 72H
Tires Rear
P205/65R15 92T
Fuel Tank Capacity6 gal.
ColorVivid Black,Midnight Crimson/Vivid Black, Mineral Green Denim Deluxe
Ignition
HeadlightAll LED headlamp
Length
105.1 in.
Trail
3.94 in.
Rake26
Wheelbase
65.7 in.
Ground Clearance
4.9 in.
Seat Height
27.1 in.
Weight, As Shipped
1,204 lb.
Warranty
2022 Harley Davidson Tri Glide Ultra Features​
TWIN-COOLED
MILWAUKEE-EIGHT® 114 ENGINE​
The most displacement in standard H-D® Touring models. You get 114 cubic inches of passing and horizon-chasing power.
REFLEX
LINKED BREMBO® BRAKES WITH STANDARD ABS​
Designed to help prevent the wheels from locking under braking to assist the rider in maintaining control when braking in a straight-line. ABS operates independently on front and rear brakes to keep the wheels rolling and help prevent uncontrolled wheel lock in urgent situations.
HIGH PERFORMANCE SUSPENSION​
Premium Harley-Davidson touring suspension technology is calibrated specifically for Trike models, delivering a smooth and responsive ride.
6-SPEED CRUISE DRIVE® TRANSMISSION​
Provides smooth, quiet shifting and reduces engine speed on the highway, so you get a better match between engine RPM and road speed.
TRUNK AND KING TOUR-PAK® STORAGE​
The integrated trunk offers 4.4 cubic feet and 50 pounds of storage capacity, while the injection-molded Tour-Pak® luggage carrier adds an addtional 2.4 cubic feet storage capacity, combined giving you 6.8 cubic feet of storage.
BATWING FAIRING & SPLITSTEAM AIR VENT​
Designed to deliver smoother airflow and reduced head buffeting with a pressure-equalizing duct on the front
2022 Harley Davidson Tri Glide Ultra Photos​
2022 Harley Davidson Tri Glide Ultra 2022 Harley Davidson Tri Glide Ultra 2022 Harley Davidson Tri Glide Ultra 2022 Harley Davidson Tri Glide Ultra
2022 Harley Davidson Tri Glide Ultra Videos​
2022 Harley Davidson Tri Glide Ultra – First Look:
Harley-Davidson Tri-Glide | We Picked up a Trike from Eagle Rider!
The post 2022 Harley Davidson Tri Glide Ultra [Specs, Features, Photos] appeared first on webBikeWorld.
