2022 Indian Pursuit Dark Horse [Specs, Features, Photos]
An All-Out Performance Tourer: 2022 Indian Pursuit Dark Horse​
The 2022 Indian Pursuit Limited and Indian Pursuit Dark Horse are the newest additions to the 2022 Indian Motorcycle lineup. Based on the Indian Challenger platform, the two new models bring several luxury touring features to cement themselves as firm favorites in the class. The motorcycles are also available with the American manufacturer’s ‘Premium Package’ trim that includes more tech and comfort features.
The key differentiating factor between both models is that the Pursuit Limited features many chrome elements, while the Pursuit Dark Horse comes with blacked-out bits and styling. Powering the motorcycle is the company’s 1,768cc liquid-cooled PowerPlus engine that produces 122 hp and 128 lb-ft of torque.
Indian Motorcycle has equipped the Pursuit Dark Horse with a long list of features, like an adjustable windscreen, heated grips and heated seats, 35.8 gallons of remote-locking storage, and the Ride Command infotainment system. Hardware features include an all-new electronically adjustable rear suspension and high-performance radially-mounted Brembo brake calipers.
The 2022 Indian Pursuit Dark Horse is available in four colorways — Black Smoke, Spirit Blue Metallic, Silver Quartz Smoke, and Ruby Metallic/Black Metallic.
The 2022 Indian Pursuit Dark Horse starts at $30,999 USD / $39,699 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Indian Pursuit Dark Horse in one place.
Motorcycle Overview​
  • Price: $30,999 USD / $39,699 CAD
    • Liquid-cooled PowerPlus V-twin engine
    • Radially-mounted Brembo calipers
    • 35.8 gallons of remote-locking storage
    • Electronically adjustable rear suspension
Main Specs​
  • Engine: 1,768cc liquid-cooled V-twin
  • Power: 122 hp
  • Torque: 128 lb-ft
  • Wet Weight: 912 lbs (413 kg)
  • Seat Height: 26.5 in (672 mm)
Competitors​
2022 Indian Pursuit Dark Horse Specifications​
Engine1768 cc, Liquid-cooled PowerPlus
Engine Power128 ft-lbs
Bore x Stroke4.251 in x 3.799 in (108 mm x 96.5 mm)
Compression Ratio11.0:1
Fuel SystemClosed loop fuel Injection/ 52mm dual bore
ExhaustSplit Dual Exhaust w/ Resonator
ClutchWet, Multi-Plate, Assist
Transmission6 Speed
Final Drive2.379:1
Suspension Front43mm, Inverted Telescopic Fork
Suspension RearFox Single Shock w/Hyd adjust
Brakes FrontDual / 300 mm Semi-Floating Rotor / 4 Piston Radial Caliper
Brakes RearSingle / 298mm Floating Rotor / 2 Piston Caliper
Tires FrontMetzeler Cruisetec 130/60B19 66H
Tires Rear
Metzeler Cruisetec 180/60R16 80H
Fuel Tank Capacity6.0 gal (22.7 L)
Color / GraphicsBlack Smoke, Spirt Blue Metallic, Silver Quartz Smoke, Ruby Metallic / Black Metallic
Ignition
HeadlightLED Headlamp
Tail LightLED Taillight
Overall Length102.7 in / 2609 mm
Overall Width39 in (990 mm)
Overall Height56.8 in (1,444 mm)
Wheelbase65.7 in (1668 mm)
Ground Clearance5.4 in (137 mm)
Seat Height26.5 in (672 mm)
Weight (Empty Tank / Full of Fuel)
877 lbs (398 kg) / 912 lbs (413 kg)
Warranty2 Years, Unlimited Miles
2022 Indian Pursuit Dark Horse Features​
AMERICAN V-TWIN TOURING REIMAGINED​
The next generation of American touring performance, with an aggressive blacked-out finish to match.
A BIG MOTOR WITH BIG TORQUE​
You’ll crush miles with unimaginable low end torque right off the line and exhilarating top end passing power from the liquid-cooled V-twin PowerPlus motor.
ROCK SOLID STABILITY​
With a chassis-mounted fairing, with optional electronically adjustable Fox rear suspension, inverted front forks, and a cast-aluminum frame, you have the ultimate control.
CUTTING EDGE TECHNOLOGY​
Cruise control, built in audio, keyless ignition and even more ride enhancing tech are combined with a 7 in touchscreen. The touchscreen is powered by RIDE COMMAND with Apple Carplay Integration, turn-by-turn navigation, and RIDE COMMAND+ connected services like live traffic and weather overlays
UNSURPASSED COMFORT​
The frame-mounted fairing provides exceptional wind protection on its own. For even more, adjust the vents in the lowers or simply push a button to send up the windshield. While it’s considerate to check in on a passenger when you have one, you don’t really need to: In this two-up configuration with optional heated seats, they’ll be just as comfortable as you.
High-output speakers in the fairing and trunk deliver 200-watts of crystal-clear audio. It also sports a dynamic equalizer that automatically adjusts for road, wind and engine noise.
LONG-HAUL STORAGE​
More than 35 gallons of weatherproof, remote-locking storage can handle all the gear you’ve got. Or take off the quick-release trunk to drop weight and give yourself a whole new profile.
BRIGHT, BOLD LIGHTING​
You won’t go unnoticed, thanks to LED running lights and a LED headlight with menacing style.
2022 Indian Pursuit Dark Horse Photos​
2022 Indian Pursuit Dark Horse 2022 Indian Pursuit Dark Horse 2022 Indian Pursuit Dark Horse 2022 Indian Pursuit Dark Horse
2022 Indian Pursuit Dark Horse Videos​
Indian Pursuit Overview by Indian Motorcycle:
Indian Pursuit Review by MCN:
Indian Motorcycle Official Websites​
The post 2022 Indian Pursuit Dark Horse [Specs, Features, Photos] appeared first on webBikeWorld.
