An All-Out Performance Tourer: 2022 Indian Pursuit Limited
The 2022 Indian Pursuit Limited and the Indian Pursuit Dark Horse are the newest additions to the 2022 Indian Motorcycle lineup. The new bikes are based on the Indian Challenger platform with the addition of several luxury touring features. Both models are also available with the American manufacturer’s ‘Premium Package’ trim, adding even more tech and comfort features.
Like the Indian Challenger, the Indian Pursuit Limited is powered by the 1,768cc liquid-cooled PowerPlus engine. Peak output figures are rated at 122 hp and 128 lb-ft of torque, making this one of the most potent engines in the Indan Motorcycle portfolio.
The Indian Pursuit Limited has been designed to tackle long highway journeys and comes with several features to do the job. These features include an adjustable windscreen, vented lower fairings, heated grips, heated seats, a cargo trunk and saddlebags with a total of 133 liters of storage, and the company’s Ride Command infotainment system.
Indian has also equipped the motorcycle with impressive hardware, like an all-new electronically adjustable rear suspension and high-performance radially-mounted Brembo calipers.
The 2022 Indian Pursuit Limited is available in three colorways — Black Metallic, Deepwater Metallic, and Maroon Metallic/Crimson Metallic.
The 2022 Indian Pursuit Limited starts at $29,999 USD / $36,999 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Indian Pursuit Limited in one place.
Motorcycle Overview
- Price: $29,999 USD / $36,999 CAD
- Liquid-cooled PowerPlus V-twin engine
- Radially-mounted Brembo calipers
- Electronically adjustable rear suspension
- Engine: 1,768cc V-twin
- Power: 122 hp
- Torque: 128 lb-ft
- Wet Weight: 912 lbs (413 kg)
- Seat Height: 26.5 in (672 mm)
2022 Indian Pursuit Limited Specifications
Engine | 1768 cc, Liquid-cooled PowerPlus |
Engine Power | 128 ft-lbs |
Bore x Stroke | 4.251 in x 3.799 in (108 mm x 96.5 mm) |
Compression Ratio | 11.0:1 |
Fuel System | Closed loop fuel Injection/ 52mm dual bore |
Exhaust | Split Dual Exhaust w/ Resonator |
Clutch | Wet, Multi-Plate, Assist |
Transmission | 6 Speed |
Final Drive | 2.379:1 |
Suspension Front | 43mm, Inverted Telescopic Fork |
Suspension Rear | Fox Single Shock w/Hyd adjust |
Brakes Front | Dual / 300 mm Semi-Floating Rotor / 4 Piston Radial Caliper |
Brakes Rear | Single / 298mm Floating Rotor / 2 Piston Caliper |
Tires Front | Metzeler Cruisetec 130/60B19 66H |
Tires Rear | Metzeler Cruisetec 180/60R16 80H |
Fuel Tank Capacity | 6.0 gal (22.7 L) |
Color / Graphics | Black Metallic, Deepwater Metallic, Maroon Metallic/Crimson Metallic |
Ignition | |
Headlight | LED Headlamp |
Tail Light | LED Taillight |
Overall Length | 102.7 in / 2609 mm |
Overall Width | 39 in (990 mm) |
Overall Height | 56.8 in (1,444 mm) |
Wheelbase | 65.7 in (1668 mm) |
Ground Clearance | 5.4 in (137 mm) |
Seat Height | 26.5 in (672 mm) |
Weight (Empty Tank / Full of Fuel) | 877 lbs (398 kg) / 912 lbs (413 kg) |
Warranty | 2 Years, Unlimited Miles |
Extension |
2022 Indian Pursuit Limited Features
THE ULTIMATE LUXURY
Both the rider and passenger get a heated seat with premium style. Adjust to your preference with controls on the seat, or from your infotainment screen.UNSURPASSED HANDLING
Electronically adjustable rear suspension preload lets you optimize suspension setting based on exactly who you’re riding with and what you’re hauling. Plus, Smart Lean Technology uses a Bosch Inertial Measurement Unit to tune traction control, ABS, and torque for even more control.BRIGHTER, BOLDER LIGHTING
Along with aggressive running lights and an LED headlight, you also get premium driving lights integrated in the lowers.2022 Indian Pursuit Limited Photos
2022 Indian Pursuit Limited Videos
Indian Pursuit Overview by Indian Motorcycle:
Indian Pursuit Review by MCN:
The post 2022 Indian Pursuit Limited [Specs, Features, Photos] appeared first on webBikeWorld.
